why is my passenger side higher than the driver.
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmgill2012, Dec 1, 2014.
  1. Dec 1, 2014 at 7:25 PM
    jmgill2012
    jmgill2012 [OP] Active Member
    jonathan
    houston ms
    96 tacoma single cab 4x4
    black bullet hole wheels black lo-pro toolbox
    hey guys. Just put a 2 inch strut spacer under the front of my 1996 Tacoma 4wd. everything went back on (on both sides) like it came off. now I have 8 inches of clearance on my drivers side and 9 on the passenger side. What could be the problem? new shocks? I did tighten the passenger side lower a-arm bolts whithout the tire on and it in the air. I tightened the drivers side while the tire was on and on the ground.
  2. Dec 1, 2014 at 7:51 PM
    Madjik_Man
    Colorado Front Range
    Taco Lean
    Weight of the battery, gas tank, etc makes the driver's side sag a tad bit more than the passenger side.
  3. Dec 1, 2014 at 7:52 PM
    Aerial Tacoma
    Aerial Tacoma Well-Known Member
    Andre
    Kodiak Ak
    2010 TRD Off Road Access Cab
    TRD Cold Air Intake, TRD Catback, Original HomerTaco Raptor Grill, TRD Trail Teams "Black", Duratrac 265/75/16, ALL PRO apex rear bumper, Retrofits W/ BHLM halos and deamon eyes
    ^^X2^^
  4. Dec 1, 2014 at 7:58 PM
    jmgill2012
    jonathan
    houston ms
    so im just going to have to accept the lean? I do have a yellow top 6 pack battery and a full tank of gas.
  5. Dec 1, 2014 at 8:06 PM
    Madjik_Man
    Don't know what all is involved with a strut spacer lift, but many manufacturers offer up a trim piece for the driver's side to account for the lean.
    1" seems like a lot though. Most spacers/trim pieces are 10 mm, which is less than 1/2"
  6. Dec 1, 2014 at 8:25 PM
    jmgill2012
    jonathan
    houston ms
    I do think the struts are needing to be changed. It rides rough in the front. Do you think new struts will fix the lean, or maybe just add a 10 mm spacer?
  7. Dec 1, 2014 at 8:50 PM
    Madjik_Man
    It's weird, I never really had the lean issue pre or post lift.
    When I put the new suspension on, I didn't use the 10mm spacer and I still don't have the lean. :notsure:
  8. Dec 1, 2014 at 9:28 PM
    jmgill2012
    jonathan
    houston ms
    I just ordered a set of Monroe quick struts for 200 bucks. So it will either fix my lean and ride or just ride. I have a buddy who owns a machine shop so I'm sure I can get him to fab up a spacer to fix the lean.
  9. Dec 2, 2014 at 9:22 AM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    Talk to TomTom here - he has some wisdom with this I believe due to a recent lift job he worked on. I think it was him anyway!
  10. Dec 2, 2014 at 1:14 PM
    codyb1
    codyb1 Well-Known Member
    Cody
    Utah
    2015 TRD Sport DCLB
    Toytec Boss Coilovers set at 3" with AAL's,Toytec Boss Rear shocks, LR UCA's, Swaybar Relocate, Diff Drop, 265/70 Nitto Trail Grapplers, 17" KMC wheels, K&N, Limo Tint, 4.7" Shorty Antenna
    It sounds like the famous Taco Lean.. It's usually only a 1/2 inch (2005 to 2015). But i just bought a 1/4 inch spacer from Toytec.com for $23.00 plus shipping. They say a 1/4 spacer will bring it up 1/2 inch. Hope that helps. I'm to OCD to not have it sit level.
  11. Dec 2, 2014 at 1:42 PM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    well, as springs age, they get weak. the added weight on the driver side vs the passenger side causes the springs on that side to compress more. so, how much do you weigh jonathan? i'd go with the last suggestion to get a spacer from toytec.
