why is my steering wheel so hard to turn
Discussion in '1st Gen. Tacomas (1995-2004)' started by Master96Yota, Sep 28, 2015.
  1. Sep 28, 2015 at 5:25 AM
    Master96Yota
    Master96Yota [OP] Active Member
    1996 red single cab rwd tacoma
    Stock:(...for now
    I have a base model 96 tacoma 5 lug single cab rwd. It doesn't have power steering so i expect it to be a little hard to turn but mine is ridiculous. Its a whole workout just turning a corner. Its so stiff, can anyone tell me what it could be or how to fix it.
  2. Sep 28, 2015 at 5:50 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    He said he had no power steering (personally didn't know that was a choice even in the late 90's haha) I wouldn't know where to start, short of checking all the bushings for anything that would hamper movement.
  3. Sep 28, 2015 at 5:55 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Depends what he meant. Is the power steering out or there never was power steering?
    If it did have it at one time and it just doesnt work now, then itll be hard to turn since you are forcing the fluid theough the pump. Easy way around this is connecting the input/output lines on the rack itself and itll be way easier. Before connecting them together crank the steering wheel each direction a few times.
  4. Sep 28, 2015 at 6:00 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Where the steering shaft meets the steering box is a U joint spray the living shit out of it with a penetrating oil
  5. Sep 28, 2015 at 6:02 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Ermagherd.
  6. Sep 28, 2015 at 8:14 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Low front tire pressure.
  7. Sep 28, 2015 at 8:17 AM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    OP, are you moving while turning the wheel?
  8. Sep 28, 2015 at 8:39 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    agreed ^^^^
    with manual steering you have to use both hands to turn the wheel.
    just to test if the steering is too tight, you need to jack both front wheels off the ground at the same time and then turn the steering wheel, if it turns ok then its a combination of low tire pressures and sitting still. when rolling its not hard to turn the wheel but when not rolling it can be very hard to turn.
  9. Sep 28, 2015 at 10:11 AM
    Master96Yota
    Stock:(...for now
    Im going to try that out because when its sitting still i can barely move the wheel. When im driving i have to get leverage to pull the wheel. Its extremely hard.
  10. Sep 28, 2015 at 10:25 AM
    Master96Yota
    Stock:(...for now
    I can barely turn my wheel when i sitting still and when i drive its still difficult. It takes alot to turn a corner. If a jack it up and its still hard to turn what does that mean. And if the box is too tight how do i loosen it
  11. Sep 28, 2015 at 10:26 AM
    Master96Yota
    Stock:(...for now
    Yes
  12. Sep 28, 2015 at 10:32 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Check the fluid in the pump you don't have.
  13. Sep 28, 2015 at 10:40 AM
    Master96Yota
    Stock:(...for now
    My truck doesn't have power steering at all. Like from the factory
  14. Sep 28, 2015 at 10:53 AM
    Master96Yota
    Stock:(...for now
    It didnt come with power steering at all. Theres no pump or anything.
  15. Sep 28, 2015 at 10:55 AM
    Shelf Life
    Rob
    Central Oregon
    I thought they all did in those years. Maybe not.
  16. Sep 28, 2015 at 11:02 AM
    Master96Yota
    Stock:(...for now
    Yea my truck is the base of the base models lol.
  17. Sep 28, 2015 at 11:07 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I had a '78 2wd with no power steering (back in those days Americans were tough, ps wasn't even available). The steering started to feel weird and have spots where it was harder to turn. I took the steering gearbox out and took it apart (no rack and pinion on a truck in those days, it was recirculating ball bearing). I cleaned it out with solvent, put it back together and filled it up with fresh gear oil. The steering was like new, it took about 2 hours.
    DTFtacoma likes this.
  18. Sep 28, 2015 at 11:25 AM
    Master96Yota
    Stock:(...for now
    Do you think mine has the same type of bearing in it.
  19. Sep 28, 2015 at 11:27 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    you're not eating enough tacos...
    increase your taco and bean intake, then try again.
    Shelf Life likes this.
  20. Sep 28, 2015 at 11:53 AM
    cosmicfires
    David
    Everett, WA
    I don't know if your's has a rack and pinion or recirculating ball bearing steering gearbox.
