Why Is My Tacoma So Slow and Gutless?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matt Starr, Mar 4, 2013.
  1. Mar 4, 2013 at 7:43 AM
    Matt Starr
    Matt Starr [OP] Active Member
    Lakewood, CO
    2003 3.4 5spd TRD Off Road
    6" Fabtech Lift
    I'm wondering if there's something wrong with my truck. It is so slow compared to my old 2000 4runner, which doesn't make any sense because my 4runner was an automatic, my Tacoma is a 5spd and the 4runner is heavier. Both are 3.4 V6 and I am running the same size tires.
    I don't understand why my truck is so slow. It runs fine and has no CEL.
    Anyone have any ideas?
  2. Mar 4, 2013 at 7:50 AM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Clogged cat?
  3. Mar 4, 2013 at 7:53 AM
    andoskyy
    andoskyy Well-Known Member
    when is the last time you did a good tune up?
    plugs
    wires
    clean MAF
    replace air filter
    clean throttle body
    run seafoam though vacuum line and gas tank
    Is your ebrake stuck (One side of mine was)? Bad wheel bearings?
    let us know what you've checked/replaced and it'll help people come up with ideas.
  4. Mar 4, 2013 at 7:56 AM
    Matt Starr
    Lakewood, CO
    6" Fabtech Lift
    I just got the truck 3 weeks ago. All I've done is new wheels and tires and an alignment.
  5. Mar 4, 2013 at 7:57 AM
    IDtrucks
    IDtrucks My screen name is now slightly incorrect...
    Mark "Buck"
    Jackson Wyoming
    Do you know what the gear ratio in the 4runnder was compared to your truck?
  6. Mar 4, 2013 at 8:02 AM
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    What size tires are you running compared to what they were? Bigger tires = slow movement unless you regear? Can you tell us what your axle code is?
  7. Mar 5, 2013 at 5:53 AM
    Matt Starr
    Lakewood, CO
    6" Fabtech Lift
    My 4runner was a 4.30 and my Tacoma is a 4.10 but my Tacoma should still be quicker because the gear ratios of my 5spd should make up for the taller 4.10. Right?
  8. Mar 5, 2013 at 8:53 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Well you said you replaced your tired? What size in inches did you go from, to what size in inches you had. I.e. I have 32" tires and 4.10 is perfect for that size.
  9. Mar 5, 2013 at 9:00 AM
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    clean the tb and tbs
    clean maf
    change plugs and wires if you haven't
    check cat temp see if its clogged
    Check front bank O2 sensor
    do the deckplate mod
    change oil to full sythetic, as well as gear oil and MT oil
    check if your brakes are dragging,
    put in some injector cleaner
    seafoam the truck for the valves,
    adjust throttle cable
    change pcv valve if dirty
    check egr port to see if clogged
    check vaccume leaks
    Lube the drive shafts
    air up your tire to at least 35psi
    after all that, reflash your truck and start fresh
  10. Mar 5, 2013 at 9:01 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    And that ^ :anonymous:
  11. Mar 5, 2013 at 9:02 AM
    t4r4life
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    every 1st gen taco owner and 3rd gen 4runner ower should do that when they first get their truck.
  12. Mar 5, 2013 at 9:05 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    2nd gen FTW :spy:
  13. Mar 8, 2013 at 12:51 PM
    emeraldtriangle
    emeraldtriangle Well-Known Member
    I literally just joined this site to reply to your thread (okay thats not the only reason:p).
    I got my truck almost a year ago now, and up until a few months ago it was RIDICULOUSLY gutless and had no power. It was getting really frustrating and annoying.
    I know this might not be the case for every situation...but what I found when changing the timing belt and water pump was that the belt was literally off by about 10%. The belt was pretty much fine but I changed it anyway..Upon actually having it put on the RIGHT way it has so much more power and "go". It was literally like I got a whole new truck, it was that big of a difference.
    It really gets it now and I am very happy that it was just a small thing like that. I was starting to get frustrated that I just had a gutless truck.
  14. Mar 8, 2013 at 1:12 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
  15. Mar 8, 2013 at 1:14 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    don't forget about the fuel filter, we just replaced it in our 96 4runner and it's definetly peppier.
  16. Mar 8, 2013 at 8:04 PM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    :pout:
  17. Mar 8, 2013 at 9:38 PM
    trded
    trded Active Member
    CA
    02 PreRunner TRD 2WD
    TRD Catback TRD Headers TRD SuperCharger TRD 7th Injector & ECU
    supercharge ftw as well :)
  18. Mar 9, 2013 at 12:43 PM
    Jefferdy
    Jefferdy Active Member
    HeloTXs
    99 3.4 4x4 5spd XCab
    2x what t4r4life and emeraldtriangle said. I got my 99 at 104K and acceleration was like driving through molasses. After I replaced the timing belt, pulleys and hydraulic tensioner, it was like I was driving a racecar! Seriously, it felt like the damn thing was supercharged, the difference was that great. T4R4LIFE's "baseline" post hits the nail on the head. Keep us posted as to what you end up doing, and your results.
  19. Mar 9, 2013 at 1:30 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Just go drive a first gen pickup or anything with a 22re. You'll feel much better about it.
  20. Mar 9, 2013 at 3:02 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    nope. gear ratios aren't that far off. 5 speeds 1st is shorter but the others aren't that far off and the 5th is much shorter. 70 on stock in an auto is around 2-2200 vs 25-2700 give or take.
    4.30s would give a difference on a 33'' tire yes. 4.10s with a 33s is pretty boggy.
