Why is my tire sticking out further on one side?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajw1986, Apr 23, 2014.
  1. Apr 23, 2014 at 8:15 AM
    ajw1986
    ajw1986 [OP] Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    http://www.tacomaworld.com/gallery/showphoto.php/photo/400448/size/big/cat/500
    I got new rims a week ago and now I notice that my passenger side rear tire is sticking out quite a bit further than my driver side. I took it back to the tire shop and tbey thought maybe I got one rim with a different offset so they switched the rear tires and it was still sticking out on the same side. I guess I never noticed before with my old rims because theh didnt stick out like they do now. Just curious what could cause this.. I want to get it fixed asap. Couldn't link the pic off my cell, there's the link though
    Edit: this is my rear tires
    JRSCALIFONTA1 likes this.
  2. Apr 23, 2014 at 8:19 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Is your bed aligned straight? I had mine about 3/4" off to the passenger side brand new out of the factory. The only thing that holds it on is the 6 big Torx bolts and if you loosen them up there is a lot of play. Check the gap around your cab, you'll be able to see if it's off.
  3. Apr 23, 2014 at 10:12 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Holy shit!! Looked at your pictures, that's a hell of a difference between the 2.
  4. Apr 23, 2014 at 10:14 AM
    Aw9d
    Aw9d That one guy
    This. My first gen when we put the bed back on did the same thing.. Just loosened it up and adjusted it.
  5. Apr 23, 2014 at 12:55 PM
    Shawster
    Shawster Member
    I noticed it once I changed wheels. My left rear is perfectly flush with the fender edge. My right rear stick out 3/4 of an inch. In looking at my bed, it does appear to be a little out on the cab but perfectly aligned with the rear bumper. If I tweak the bed, how much adjustment is there in the rear bumper and hitch assembly.
    By the way I'm running 265 70 17's on 17x8.5's with +10 offset. These are the perfect fit for these trucks.
  6. Apr 23, 2014 at 5:03 PM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Yeah it was, in mid december. They replaced the passenger side body minus the doors, front axle, brand new front diff. They assured me nothing was wrong with the rear and it was gone over thoroughly and multiple times because I took my truck back to them twice due to something being off. I know that this isn't something thatst just gonna happen out of the blue. Really hoping it's the box being off, gonna check when I get back to our shop soon here. If the box isn't off I guess just take it back to the body shop who fixed it?
  7. Apr 23, 2014 at 5:38 PM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Makes me feel a little better knowing im not alone, and hoping its the same issue! Anxious to get back and check now!
    Edit: I know its nothing to do with a lean of any sort, a month ago when my lift got installed I made sure to get the spacer put in for the taco lean when they assembled my coilovers
  8. Apr 23, 2014 at 6:11 PM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Just checked her out, by eye the box looks straight with the cab then I went to see the gap between the bumper and box, and sure enough the gap is bigger on the drivers side so with the way it has to be shifted it will correct it. Anyone know what sise of torx those are? Also do I just have to loosen them to shift the box a bit or take them right out?
  9. Apr 23, 2014 at 6:24 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    T-55 if memory serves me correctly.
  10. Apr 23, 2014 at 6:50 PM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    It does cause I just stopped to buy it and it's a perfect fit!
    Thanks everyone once again for the help, can't thank the TW community enough for solving any little poblem I've ever had!
    jjgandarillas likes this.
  11. Apr 24, 2014 at 11:20 AM
    TxFireman
    San Antonio, Texas
    Good deal. As for adjusting it, I would just back the bolts out .. way out.. but leave them partially threaded. That way you're not adjusting them away from the holes. That should help you from moving it too much and still allow you to find that sweet spot if it exists. If you can't find a spot where it all lines up, I would suggest at least having the shop that did the body work look it over. Good luck with it.
  12. Apr 25, 2014 at 8:47 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    I loosened them all so they were up about quarter inch from the washers. It did move a little bit but not enough to correct it. I didn't have much time to mess with it yesterday so im gonna try again today after work. I got my cab mount chop done at a 4x4 shop yesterday and had him take a look at it, he said it was definetly my box and not my axle or diff that was off. He suggested taking the bolts right out and then adjusting the box but i figured if its not gonna move anymore with them in then the bolts wont line up again when i get it into the desired spot
  13. Oct 8, 2016 at 4:44 AM
    SilverSkyTRD
    SilverSkyTRD Well-Known Member
    Whatever came of this issue? I have a 2016, just put wheels on and have this exact issue. My bed is lined up fine.
  14. Oct 8, 2016 at 4:55 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Pretty common,misaligned bed,loosen bed bolts,realign,retorque,mine was the same way.
  15. Oct 16, 2018 at 2:34 PM
    QuicksandTaco17
    QuicksandTaco17 Member
    Pro Comp Nitro 3" leveling kit + 285/75R16 BFG AT KO2
    same here... new wheels and one tire sticks out more than the other...
  16. Oct 16, 2018 at 5:12 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Is it possible that with new wheels that one wheel could have different backspacing?
