Why is my truck eating wheel bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by map_guy, Aug 28, 2022.
  1. Jul 3, 2024 at 7:20 AM
    jcesp
    jcesp Member
    Gary
    Tacoma TRD Off Road 2023
    BFH Please do not Use Abbreviations !
  2. Jul 3, 2024 at 7:29 AM
    Daves31
    Daves31 Member
    Big F-ing Hammer :rofl:
  3. Jul 3, 2024 at 7:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    In the world of texting abbreviations become the norm. Some are old, some are new, some are intuitive.
    This will help with your learning, or be a reference if you wish. (there are lots out there)
    https://www.webopedia.com/definitions/text-abbreviations/
    Please note, you 'woke up' a thread almost 2 years old. Not that that's all bad, its just that often the players in older threads aren't always around any more.
    Captain4x4, YF_Ryan and SR-71A like this.
  4. Jul 3, 2024 at 8:29 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Along the way have you replaced the inner wheel brg seals?
    I recently had my driver's side CV axle out for a ecgs bushing swap and discovered the inner seal was folded in on itself. The axles have never been out so it's been that way since it was new (150K /17yrs). Luckily I live an extremely dry climate and it sounds like at least one of them is just starting to make noise. I agree with the possibility of it being a moisture issue depending on where the OP lives, esp if the inner seals haven't been replaced which is probably a good idea considering the ongoing drama with the brgs. One of the things we do on our dirtbikes to combat wheel brg moisture issues is to pack the area between the seal and the bearing with waterproof grease. It's not for lubrication but acts as another moisture barrier.
    Unless the bearing housing is getting distorted when it's torqued down which would indicate a bent knuckle I have a hard time believing it's an external physical issue without some indication in tire wear.
  5. Jul 3, 2024 at 2:19 PM
    map_guy
    map_guy [OP] Member
    2014 TRD OR DCSB Silver Sky
    Appreciate all the replies. This issue continues to be a mystery. It seems as though the noise is actually coming from a combination of brakes and tires. I have a plan to replace brake rotors, pads and tires in the Fall and also get a good alignment. I will report back what the results are. In the meantime, I have work to do on my FJ60.
  6. Jul 3, 2024 at 2:20 PM
    map_guy
    map_guy [OP] Member
    Also, I am in inland SoCal, so very dry climate.
    ridefreak likes this.
  7. Dec 18, 2024 at 7:03 AM
    map_guy
    map_guy [OP] Member
    Update:
    The noise is back with a vengeance and new tires did not fix it. I got the tires last Friday and am installing new coilovers and wheel bearings this weekend then I will get an alignment. Pretty sure it’s the wheel bearings again. No way it can be brakes. That makes no sense, save for previous bouts where it only made the noise under braking and only after driving for a while.
    Anyway, looks like I just need to budget for new wheel bearings every 30k miles, which sucks.
  8. Dec 18, 2024 at 7:31 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    What brand of bearings are you using? There are tons of inexpensive bearings out there and just as the old saying goes, you get what you pay for. Are you using a complete hub and bearing set or are you pressing the new bearings onto an old hub? There's nothing wrong with pressing the old bearings off and the new ones on - as long as you do it correctly.
  9. Dec 18, 2024 at 7:31 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    I replaced my OEM bearings at 93,320 miles with TRQ bearing/hub assemblies in 2019. The OEM were beginning to make a scraping sound when rounding corners. No issues since then. I am currently at 134,900 miles.
    skee likes this.
  10. Dec 18, 2024 at 11:37 AM
    map_guy
    map_guy [OP] Member
    Last 2 sets were OEM. The set I’m installing rhis weekend are also TRQ. Why buy OEM again if they don’t last?
  11. Dec 18, 2024 at 12:12 PM
    Too Stroked
    Tom
    Speaking as someone who works in a Toyota dealership, I've rarely seen OEM bearings go before 100,000 miles. Aftermarket? I've seen some of the really cheap stuff go at 15,000 miles. As others have said, I think you have something else going on there and the seals that protect area would be high on my list of things to replace no matter what bearings you install.
  12. Dec 18, 2024 at 6:40 PM
    map_guy
    map_guy [OP] Member
    I’ve ordered oem inner and spindle seals and will replace them at the same time as the hubs and get a good alignment after. Hopefully these last longer.
