Why is the bottom leaf on our leaf springs turned down?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Oct 23, 2014.
  1. Oct 23, 2014 at 10:24 AM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    on most all other vehicles the bottom main support bar for the leaf springs is turned up in the same manner as the leafs are so why is it on our trucks that it looks to be mounted upside down facing away from the leaf pack?
    like this:
    so wouldn't it be a good idea to flip it over so it engages the leaf pack sooner under heavy loads and if not then why since this is how almost all other leaf packs including some aftermarket ones are designed?
    like this:
    im asking because im about to add a leaf and since I will have the leaf packs all apart anyway, this is the time to flip it if it would be better that way
  2. Oct 23, 2014 at 10:30 AM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    It's the overload spring. There's no arc on them because it has no spring rate other than when engaged with a heavy load
  3. Oct 23, 2014 at 10:35 AM
    keakar
    karl
    louisiana
    well it does have an arc to it, about an inch on each end, but its turned down rather then up which is what confuses me, if it were flat I would understand but if they went to the trouble to create the arc then why is it arcing away from supporting it?
    something about it just doesn't make sense
  4. Oct 23, 2014 at 10:37 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    From my understanding if you flip it upside down you would have a rough ride since the overload isn't suppose to flex like a normal leaf.
  5. Oct 23, 2014 at 10:38 AM
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
  6. Oct 23, 2014 at 10:41 AM
    Fiend13
    Chad
    Yes, it does have a slight arc to it but not like the rest of the leaf pack nor does it have the same spring rate, it's just there to basically help re-enforce the leaf pack if the bed is overloaded
  7. Oct 23, 2014 at 10:41 AM
    keakar
    karl
    louisiana
    ok, so I guess its curve is there to provide something like a progressive feature to the leaf pack until it stops your leafs when they are maxed out.
    that makes sense I guess
    thanks for the insight guys
  8. Oct 24, 2014 at 8:57 PM
    Yota64
    Yota64 Professional Threadjacker
    I have always heard it was to prevent the leaves from bending past that point. More of a guard or brace than a load contribution.
  9. Oct 24, 2014 at 8:57 PM
    Yota64
    Its called the overload leaf
  10. Oct 24, 2014 at 11:52 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The overload is ARC'd & reversed because with extreme loads (or heavy towing) its a buffer of sorts for the entire leafpack as the springs compress & flatten out they need extra surface contact to prevent snapping or permanently bending the main
    If you flipped it not only would it lift about 3" but the ends of the overload would end up breaking leafs as well not to mention the shitty ride...
    This is pretty accurate & why they call it a "spring" is beyond me, that thing isn't flexing anytime soon...
  11. Oct 25, 2014 at 10:25 AM
    keakar
    karl
    louisiana
    thanks for the detailed insight, the ones I saw in the past were always flat but never curved down so it was a head scratcher at first as to why
