Why is this happening?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TruckyTruck, Sep 6, 2012.
Do your new Tacoma's drum brakes squeal?
  1. Yes
    27.1%
  2. No
    72.9%
  1. Sep 6, 2012 at 9:06 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Sorry...didn't mean to ruffle your feathers op. I just never thought of the brakes squeeling (especially on a truck) as being that big of an issue. Good luck with it.
  2. Sep 6, 2012 at 9:08 PM
    Large
    Large Red
    my 11 has done this since mile 1, only in reverse though
  3. Sep 6, 2012 at 9:09 PM
    TruckyTruck
    TruckyTruck [OP] Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    Thanks. Its not you that has my feathers ruffled, its my 30k school bus breaks. :eek:
  4. Sep 6, 2012 at 9:18 PM
    TruckyTruck
    Oh, I think there is a TSB for that... front break squeal?
  5. Sep 6, 2012 at 9:23 PM
    Fienoma
    Fienoma Well-Known Member
    Hieu
    New Mexcio
    2007 double cab Off road 4x4
    BHLM, In bed lights mod, K&N intake,OEM bed extender....more to come?
    I had a friend with a 08 taco, he had a piece of a retaining spring break off inside the drum. the piece was supppppper small..but it was enough to just rub against the drum causing the noise. maybe those techs should take a closer look...
    Edit:
    p.s. most shops over look vehicles that come in for warranty work..most of the time they just want to get them in and out asap..
  6. Sep 6, 2012 at 9:24 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    ya okay good luck with that.
    you have at least 15k more miles to go and hope that your truck is out of service for 30 days... and on top of it them giving you a pile of shit to drive while out of service.
    ya.. defiantly a lemon.
  7. Sep 6, 2012 at 9:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    X2
  8. Sep 6, 2012 at 9:36 PM
    TruckyTruck
    heh. to qualify, it says ONE of the following. I would probably trade it for something else before i ever tried that path. pile of shit? dude, i got a Fiat 500 to drive last time... It was like a go kart with a radio
  9. Sep 6, 2012 at 9:38 PM
    TruckyTruck
    Thanks, isnt yours fairly new? Squeal or no Squeal?
  10. Sep 6, 2012 at 9:43 PM
    OZ-T
    Peter North
    British Columbia
    2009
    Front brakes squeal occasionally
  11. Sep 6, 2012 at 9:57 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    I thought I was only one that had the front brake squealing problem.
    It only happens when I come to a stop slowly and only at the tail end of the stop, never at the beginning. This probably started when the truck only had 20k on it and now it has 33k and still squeals. :mad:
  12. Sep 6, 2012 at 10:02 PM
    TruckyTruck
    Are you sure it's your front brakes? What you are describing sounds like the rear brake squeal. The tail end of stopping.
  13. Sep 6, 2012 at 10:10 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Go to a different dealer. Could've been the same tech looking over your truck for the past few visits. Something like incorrect assembly or a broken part would've been difficult for him to catch.
    Another option is to use aftermarket brake shoes from Raybestos or Wagner. They are only about $50 for the set at RockAuto.com.
    Maybe another member will chime in - is there a proportioning valve or something that can adjust the front/rear brake bias? Seems odd your brake shoes are glazed, when the rear brakes are typically used so lightly. (It's not unusual to go 40k on a set of shoes.)
  14. Sep 6, 2012 at 10:18 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Wow! That would have been the first thing I did. Perhaps you should ask for that specifically. I can't see them fighting you too much......well, maybe I can:(
    If this was out of warranty and you took it to Midas, I bet they would tell you it needs shoes and the drums turned. Why the dealer wouldn't start there is beyond me. If your truck sounds like a "city trash truck", that is.
  15. Sep 6, 2012 at 10:21 PM
    #35
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No brake squeal on the front or back here, 2012 Access Cab SR5 Prerunner.
  16. Sep 6, 2012 at 11:37 PM
    #36
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    No proportioning valve, they use electronic brake force distribution which is integral with the ABS.
  17. Sep 7, 2012 at 12:46 AM
    #37
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Both front and back squeal on mine. But i have to replace the pads and shoes. I know i have to. After, ill get back to you.
  18. Sep 7, 2012 at 12:58 AM
    #38
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Had three NEW Tacomas (Off Road 4WD): 2001, 2005, 2010 and none of them had any rear brake issues or noises.
    The 2005 had a front pad area squeal that started at 8,000 miles and they could never solve it, as it wasn't constant. It went away with the first set of new pads changed, and never made a noise again.
  19. Sep 7, 2012 at 4:19 AM
    #39
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Like the OP said, this sounds like the rear brake squeal. My '09 DCSB did it and I thought it was the front as well. I replaced pads and rotors at 45K miles, but it was still there. Then, listening more closely I realized it was the rear.
    My '12 does it as well.
    It only does it at the tail end of a complete stop, only if I am braking lightly, and it is not very loud. Since my '09 did it as well under the exact same circumstances, I have come to terms with it being a characteristic of the vehicle. Some do it, some don't, and some do it louder than others.
    I had a '77 280Z 2+2 once that had a very similar characteristic on the front brakes. When they stretched the design to fit the rear seats in, it threw something off balance enough to cause a resonant frequency. I had to live with it.
    It's not a safety hazard, but if it's bugging you, going with a different pad might help.
  20. Sep 7, 2012 at 8:22 AM
    #40
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    My rear brakes on my 2011 squeeled since day one. I took the drums off and hit the pads with sand paper. It still does it, its just not too bad. My windshield whistle noise at high speeds and the blower motor noise was much more irritating. Both have since been fixed Via the TSB's.
