Why LEDs should not be run in Halogen reflectors
Discussion in 'Lighting' started by crashnburn80, Oct 6, 2016.
  1. Jan 8, 2020 at 5:59 PM
    #161
    VoodooPro
    VoodooPro Well-Known Member
    2019 Voodoo blue TRD Pro
    OV 93 tune, TRD pro intake, LED headlights, LED interior lights, tuffskinz interior overlays "RCF", tailgate inlay, Illuminated kickplates, blue interior compartment inlays. Painted voodoo blue interior trim, nitto ridge grapplers, bara 1 inch spacers, redline pro hood struts, trd oil and radiator caps.
    Oh my mistake, yeah I have a 3rd gen. Didnt notice this was for 1st and 2nd gen only.
  2. Jan 14, 2020 at 3:47 AM
    #162
    veleno
    veleno Well-Known Member
    Since this is a couple of years old, has a better halogen bulb been produced? Looking to get more usable lighting in a 1st gen.
  3. Jan 14, 2020 at 4:40 AM
    #163
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    See this thread for H4 bulb recommendations out output intensity charts:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    Best bulbs without a standalone harness:
    IPF Fatboys 60/80w (80w low beam) - While higher wattage low beam the high beam is stock allowing these to run on the factory wiring. They are the highest performing plug and play bulbs that do not require a harness. They are very expensive.
    Philips Racing Vision +150 - These have the highest intensity low beam for a stock wattage bulb, but the high beam has a blue coating over it which will reduce high beam output.
    GE Xenon +120 - These have the highest intensity stock wattage low beam without a performance robbing coating over the high beam.
    See output charts in the above thread for how these compare. Adding a harness to even stock wattage bulbs will increase output by approx 10-15%.
    Norton and steelhd like this.
  4. Jan 23, 2020 at 6:34 PM
    #164
    kperatt09
    kperatt09 Well-Known Member
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    34's with all the fun attached
    So what is the process to put the IPF fatboys in with stock harness? and is it a significant upgrade?
  5. Jan 23, 2020 at 7:12 PM
    #165
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    In short, unplug your OEM bulbs and plug-in the IPF Fatboys; and yes. The longer answer, available in the referenced thread and the post you quoted...
  6. Jan 23, 2020 at 7:16 PM
    #166
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    I've read that thread a bunch... I've been on the fence of putting the wiring harness in. I guess I just didn't realize you could get the same performance from the stock harness as with the higher voltage harness.
    So, since the 3rs gen has a separate low and high beam, does the ipf fat boy go in the projector housing or the high beam location?
  7. Jan 23, 2020 at 7:16 PM
    #167
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    ^ Nailed it.
    Norton[QUOTED] likes this.
  8. Jan 23, 2020 at 7:19 PM
    #168
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Oh! 3rd Gen should see the 3rd Gen headlight thread. Check out post #2 in that thread. Philips H9s are the best performing low beam bulb in terms of output intensity. The H4 2nd Gen thread does not apply to 3rd Gens, since they take H11/H9. And no harness is needed for 3rd Gen.
    kperatt09[QUOTED] and Norton like this.
  9. Jan 23, 2020 at 7:24 PM
    #169
    Norton
    +1.
    Apologies, @kperatt09 - I missed that you're in a 3rd Gen.
  10. Jan 23, 2020 at 8:11 PM
    #170
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    You guys are good, I didn't know if I could go H4s or not.
    I've had Fatboys in a Jeep before and they are awesome, so I was hoping I could get them in my 3rd gen.
    @crashnburn80 I love that 3rd gen lighting thread. I am actually running the H9s right now because of it.
    Thanks guys!
  11. Jan 23, 2020 at 11:43 PM
    #171
    Metallitruck
    Metallitruck New Member
    2019 Tacoma TRD Sport
    3" lift
    Seeing this is disheartening.. :( I wanted some clear HID's because a buddy of mine runs them and his lights are super bright and clear. I would like something better than stock but I'm very inexperienced.
  12. Jan 24, 2020 at 9:08 AM
    #172
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    steelhd likes this.
  13. May 12, 2020 at 12:49 PM
    #173
    CROM123
    CROM123 Love my Tacoma
    Garland
    Virginia
    2010 Tacoma 4x4 2.7 reg.cab. 27-k miles
    265/75/16 coopers at3 4s
    Smart Guy!
  14. Jun 1, 2020 at 12:38 PM
    #174
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    NHK's newest LED projectors are looking up to par compared to HID. Only thing missing is a foreground limiter.
  15. Jul 10, 2020 at 8:40 PM
    #175
    EnriqueG_s550
    EnriqueG_s550 Well-Known Member
    Enrique
    2018 Tacoma TRD OffRoad 4x4 in Cement color!
    I've personally ran a bunch of different LED's and they all worked great... until they all pretty quickly started to dim out. Now I'm on Diode HID's on my 3rd gen and they are awesome!
  16. Nov 25, 2020 at 10:49 PM
    #176
    Dirtrider_141q
    Dirtrider_141q Member
    White 2014 Tacoma TRD Off Road Access Cab Long Bed 4x4
    none so far
  17. Nov 26, 2020 at 3:43 PM
    #177
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Definitely pass on anything TacomaBeast aka Spyder. Some of the worst performing headlights on the market, those will be a huge downgrade. Those are also not LED, they are just a poor quality halogen projector. At this time there are no assembly upgrades for a late model 2nd Gen. Best hope is for Morimoto to release an XB headlight for 2nd Gen. If you are just looking for brighter, follow this:
    Norton likes this.
  18. Nov 26, 2020 at 3:53 PM
    #178
    Dirtrider_141q
    none so far
    Thanks for the heads up
  19. Jan 27, 2021 at 5:43 PM
    #179
    Yodastacotruck
    Yodastacotruck Well-Known Member
    2021 MGM 4x4 trd off road
    Stock
    what’s up with the ball joints I’m curious?
  20. May 13, 2021 at 5:36 AM
    #180
    BenSkiv
    BenSkiv Well-Known Member
    Ben
    Maine
    2019 Tacoma TRD-off-road DCLB
    Imma still run LED’s regardless
    optifree, andersen24 and RedWings44 like this.
