why my aux/cig outlet does not work
Discussion in 'Technical Chat' started by beaves, Feb 11, 2011.
  1. Feb 11, 2011 at 10:10 AM
    beaves
    beaves [OP] New Member
    buddy
    folsom, ca
    06 tacoma 2wd
    redi-lift level kit
    Ok, i looked at the fuses and nothing is blown. why can
    i not see anything on getting my outlets to work? i have a
    basic tacoma, old school roll up windows and door locks so,
    i wonder if they left something off. i noticed that the
    100amp a/c fuse was not there in the engine compartment.
    i do not want to sound dumb but DANG! i have lifted my
    truck and done other things. i do not want to dismantle the
    dash. am i missing some.
    :confused:
  2. Feb 11, 2011 at 10:50 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    There's also an accessory socket relay in that circuit. If the 15A PWR OUTLET and 7.5A ACC fuses are OK, the relay might be bad.
    It could also be a wiring problem.
  3. Feb 11, 2011 at 11:16 AM
    beaves
    buddy
    folsom, ca
    06 tacoma 2wd
    redi-lift level kit
    ok, i just checked the fuses and replaced them. i will let you know.
  4. Jul 26, 2011 at 8:34 AM
    electrahog6
    electrahog6 New Member
    Shad
    Clarksville, TN
    1999 Tacoma
    none
    what fixed the problem ??? i got the same thing on my 1999 tacoma
  5. Jul 26, 2011 at 8:43 AM
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    Did you check the connection from the wiring harness to the sockets themselves?
    When I first got my truck, the one was loose.
    Just two little pins to take the lower center console piece off and reach in to see if they are plugged in tight.
  6. Dec 2, 2011 at 4:59 PM
    t3hWIT
    t3hWIT Well-Known Member
    Wit
    Central PA or wherever the wind blows me
    Rusty '98 Tacoma
    I hate to bump an old thread, but I resolved this issue on my truck.
    I had an auxiliary heater plugged into the outlet, which had a 15a fuse built in. After a few minutes of running the heater, it stopped working and the outlet was dead. I checked the fuses of both the heater and the power outlet but they were both ok. I checked the second auxiliary outlet, and that worked... which was odd seeing that they share the same circuit.
    I removed the lower center console panel and pulled the socket. I found that there is a fusible link built into the back of the socket, which had blown. Being that the circuit is rated for 15a, and I was not bypassing any of the other circuit protection, I replaced this built-in fusible link with a piece of wire soldered into place.
    The outlet works perfectly now.
