why not a Dodge Ram?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Apr 19, 2020.
  1. Apr 19, 2020 at 6:20 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Here is Last Line Of Defense youtube channel (who I think is a Toyota guy that's owned a Tacoma, 4Runner, and more) touring Mike Glover's Dodge Ram.
    I have been thinking, is it even worth investing into or owning a Toyota or Tacoma?
    Before I end up dumping more money into things like front bumper, camper shell, and so on.
    As a platform, is it even worth it?
    Besides the cost, and hopefully a Ram does not cost too much more,
    they seem like a better base to start out with.
    Are they? Am I wrong?
    Has anyone else had these thoughts?
    a Ram is bigger, so it can carry more. It can get many of the same upgrades, such as armor, suspension lift, and so on.
    However, some major (maybe better) differences:
    -they can come in diesel, for better mpg and more torque
    -the bigger size means you can also put an extended range fuel tank on it, for less stops at the gas station
    and because of the diesel, it can probably easily handle extra weight of upgrades, like armor and stuff that adds weight.
    even in stock form at regular weight, my Taco mpg seems bad.
    smw62891 and I married my tacoma like this.
  2. Apr 19, 2020 at 6:22 PM
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    Nope. Not worth it. Next thread.
  3. Apr 19, 2020 at 6:22 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Size is the biggest reason.
    diesel you’re talking an extra 10-20k for price.
    Tacoma’s are extremely easy to work on and will get you 300k miles. A ram 1500 will get maybe half.
    diesels are a good choice, but again, size weight and price.
  4. Apr 19, 2020 at 6:24 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Every answer in this thread is going to point to one thing. I agree Ram has the nicest truck out right now, but I would never trust all the fancy systems to Chrysler. Adjustable air suspension by Chrysler? Enjoy that repair bill in 5-6 years. There is a whole list of things on that truck in that category.
  5. Apr 19, 2020 at 6:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Lots of hopefully, probably and assumptions in that. You'd be better off sitting down and figuring out each point individually - i don't think they're all true.
    tinker_troy likes this.
  6. Apr 19, 2020 at 6:34 PM
    TacoTuesday1
    FL
  7. Apr 19, 2020 at 7:14 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    The standard v8 hemi Ram that you see all over the roads, well they are for guys that cant afford an f150.
  8. Apr 19, 2020 at 7:34 PM
    UluaHuntah34
    UluaHuntah34 Well-Known Member
    2008 Tacoma 6inch Lift, 2 inch body lift, on 37s
    You need to also consider what you will be doing with your truck? Obviously if your just going out in the woods then you’ll be fine, but if your looking to do a little bit more aggressive off roading, like in the sand and rock climbing then you probably want to go with the Toyota because of its size and how light it is compared to the Ram. You also need to ask your self, what are you planning on hauling? I used to own a 2015 Silverado 1500, but I found that 1 times out of 20 that I needed that longer bed. But most of the things that I used it for I could accomplish with my Tacoma now. Plus a big upside for me what the size and weight of the Tacoma. Since I go fishing a lot being able to crawl in the sand easier and not sink is a huge upside for me. It all just comes down to what you like and what you plan to do with it. A lot of that newer technology I barely used. ‍♂️ So it’s all up to you. Sit down and make a pros and cons list, but I’m more happier with my Tacoma then I’ve ever been with my Silverado.
  9. Apr 19, 2020 at 8:11 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    You’re asking this in Tacoma forum? I’m sure responses will be objective....
  10. Apr 19, 2020 at 8:16 PM
    RobertusvT
    RobertusvT Well-Known Member
    DFW, TX
    2020 White TRD OR
    Recently went from a ram 1500 to a Tacoma and I have to say that the Tacoma is honestly a lot more fun to drive. It also gets better gas mileage than I did in my ram and it has so much more aftermarket support than the ram did when I was trying to build it up. There is a reason it has such a huge following. Tacoma no doubt over the ram.
    Jimmyh and Smokinnuts like this.
  11. Apr 19, 2020 at 8:21 PM
    TacoTuesday1
    FL
    is it not objective of me to ask in the first place?
    The Taco is not my first vehicle,
    and for many others here, I doubt it is their first or only vehicle
    It is not the purpose of a person to serve and be addicted to their vehicle. Cars were created by man, to serve man.
    owning a Tacoma does not mean the word is tattoo'd on your neck
    some people join forums to learn how to fix their vehicle to save money on repairs,
    not because they plan to name their newborn son "Toyota"
    Biscuits, Taco-Grinder and ABNFDC like this.
  12. Apr 19, 2020 at 8:26 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My friend's RAM's engine grenaded. The dealer said it couldn't be fixed and cleverly gave him some credit on another RAM that cost $10,000 more. Apparently he hadn't had his coffee yet or something.
    WrathofZelda likes this.
  13. Apr 19, 2020 at 8:32 PM
    WrathofZelda
    WrathofZelda Well-Known Member
    For sure, it all depends on your needs.
    Obviously, most people here like their Tacomas, enough to join a forum of like-minded individuals.
    If towing, hauling heavy stuff, more family room is your needs then go full size. I drove a Ram 1500 5.7 on a contract a few years back and loved it on pavement. On FS/BLM roads less so.
    Folks like Tacos for reliability, size, out-the-door offroad performance, etc. Mods cost money, same as on a Ram. Just go based on the main purpose of your needs. There is no one perfect vehicle, as there are trade-offs, especcially between mid and full size.
    I hope you find the vehicle that best suits your needs.
    Biscuits likes this.
  14. Apr 19, 2020 at 8:41 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You sound like you're wanting to build a custom overland rig. Why? Where are you going? Full sized trucks are for hauling hay to the feed lot and intimidating teenagers at the mall.
    Ram and other 1/2 tons aren't a great off road platform - fight me. :crapstorm::crapstorm: The wheelbase is too long to have any kind of decent breakover angle, they are too wide to really get into the brush, and way too heavy to float over mud/sand.
    For that matter, the Tacoma isn't exactly super in that category either. I can get places in a two wheel drive Beetle that I wouldn't dare attempt in a modern Tacoma.
  15. Apr 19, 2020 at 8:49 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  16. Apr 19, 2020 at 9:01 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    More flag stickers = bug-out vehicle
  17. Apr 19, 2020 at 9:05 PM
    TexasWhiteIce
    Texas
    I think you should get a Tacoma
    cosmicfires likes this.
  18. Apr 20, 2020 at 12:28 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    fiat....nuff said???
    c212, 68dave, BillsSR5 and 2 others like this.
  19. Apr 20, 2020 at 3:58 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    The stock Power Wagon is a capable option in the heavy 1/2 ton-light 3/4 ton category. They are expensive as fuck, get shit for mileage with a 6.4L 8 cyclinder(nobody buys a truck for gas mileage), and need that big ass sticker removed from the bed though.
    Really depends on what you want to do with the truck.
    I don't know if I would buy a modern diesel these days. I had a couple of Cummins Dodges in the 90s and then early 2000s, but there is way too much in the way of emissions and computer bullshit on them now.
  20. Apr 20, 2020 at 4:03 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Depends what you want. Highway queen and towing, yeah I’d consider the ram. Want to hit the trails and be bouncing around rocks and going between trees? The Tacoma is one of the best. Gladiator and zr2 give it a good challenge in the woods. Otherwise the Tacoma is your off road vehicle of choice.
