Why not have a REAL overdrive 5th gear?
Discussion in 'Technical Chat' started by james, Jun 2, 2010.
  1. Jun 2, 2010 at 7:58 AM
    james
    james [OP] In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    Hi. I'm new here.
    I bought my first Tacoma from my cousin in preparation for moving to teach in Alaska. Needed the four wheel drive. He sold me his well-cared for 1998 Xtracab with a V6 and 31x10.5 tires. Manual transmission.
    Goodness! I've never owned such a vehicle. It's big to me, but, I'm told, will prove puny by Alaska standards. I need to change some things on it to make it as safe a vehicle as I can. But one thing that came to mind was saving in gas mileage. I found a handy speedometer converter gave a range for the trade-offs when you change the highest gear ratio.
    And I noticed that my truck's stock 5th speed gear ration was a 1:4.11. In order to save fuel, I suppose I could make that overdrive fifth gear into a REAL overdrive and change it to something smaller, like a 3.42 gear ratio. Here's my question(s): Why wouldn't I do that? If it's feasible to do for a highway cruising gear, why doesn't everyone do that?
    Here's what I'm starting to work with:[​IMG]
  2. Jun 2, 2010 at 9:46 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    4.1:1 is your *final* gear ratio (at the differential), not the 5th gear ratio.
    With a 1998 V6 4X4 5-speed (R150) you have a 5th gear ratio of 0.838:1.
  3. Jun 2, 2010 at 2:39 PM
    james
    '98 Tacoma V6
    Thanks EnolaG– details I don't know about...
    ...but is it possible to change it to something with a little less ooompf, but lower rpm, hence save gas? How difficult would that be?
  4. Jun 2, 2010 at 5:21 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    In theory, it's do-able by swapping to a higher (= lower ratio number) final gear ratio.
    However, there are two 'gotcha's' ...
    (1) The higher the gearing, the worse your low-speed 'grunt' capability will be ...
    (2) You'd have to do it twice (you've got 2 differentials, and they really need to be geared to match ...).
  5. Jun 2, 2010 at 5:35 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Just put on a little bit taller tire.
