Why not spacers for small lift?
Discussion in 'Suspension' started by Ready4what, Dec 11, 2011.
  1. Dec 11, 2011 at 12:18 PM
    Ready4what
    Ready4what [OP] Member
    Central AL
    03 Xcab PreRunner
    I have an 03 PreRunner Xcab and it looks like it is about time for some new shoes. I dont offroad per say, but I do travel some unmaintained/abused dirt roads. After rain, some of them are quite the challenge (Alabama red mud). I am currently running stock type "large car tires" as I call them, and am very unhappy. I want something in the 285/33" m/t area and see that a lift will be neccesary. But I see that alot of posters on this forum say to avoid spacer lifts. Why? Is this advice for serious offroaders? Or are spacer lifts just a bad idea? I dont need much articulation and do not abuse the suspension in any way. I just need a tad of clearance.
    The reasoning for the larger tire is to reduce the torque just a tad at the ground. Not to mention that I love the way a Yota looks on 33's.
  2. Dec 11, 2011 at 12:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Ask yourself this.....WHY do you want to hold an expensive vehicle off the ground with a $5.00 parts?
  3. Dec 11, 2011 at 12:20 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
  4. Dec 11, 2011 at 12:20 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
  5. Dec 11, 2011 at 12:21 PM
    08pretaco
    Oliver
    az
  6. Dec 11, 2011 at 12:21 PM
    KPT
    09 Prerunner
    :bowdown: @ ollie
  7. Dec 11, 2011 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    He's slowed down alot since his head injury....
  8. Dec 11, 2011 at 12:22 PM
    KPT
    09 Prerunner
    I've been trying to train at night to get my quickness back....
  9. Dec 11, 2011 at 12:23 PM
    08pretaco
    Oliver
    az
    Well you actually took the time to type a response so theoretically you would have beat me! Ill give you this one
    +1 Keith!
  10. Dec 11, 2011 at 12:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Drinking beer?
    We dont have to coddle the handicapped.
  11. Dec 11, 2011 at 12:25 PM
    08pretaco
    Oliver
    az
    whats this coddle you speak of?
  12. Dec 11, 2011 at 12:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Exactly.
  13. Dec 11, 2011 at 12:39 PM
    Ready4what
    Central AL
    03 Xcab PreRunner
    Not trying to be an a$$ or start any crap, but ALL of our trucks are held off the ground with a bunch of $0.10 bolts... These can shear aLOT easier than a block of aluminum can be crushed...
    Just sayin...:cool:
    Thanks for the links guys. That's the info I was looking for. Now i know.
    What would you suggest? I'm not looking for super duty ruggedness or extreme articulation. Just the clearance. Thanks again.
  14. Dec 11, 2011 at 12:39 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I wouldn't call lifting to fit 33's a small lift on a Taco.
    Might even have to do some cutting and regear depending on what you have.
  15. Dec 11, 2011 at 12:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive seen alot more aluminum blocks break than the bolts. THe moment load is much higher in the perches the truck actually rests on, rather than on the nuts/bolts. ...Just sayin. :cool:
  16. Dec 11, 2011 at 12:59 PM
    Ready4what
    Central AL
    03 Xcab PreRunner
    Why is that? It fits 265/75 stock. That translates to 31.65 inches. I have seen a stock Taco with 32's on it. Moving up 1 inch is as small a move up as I can see. I know that adding 1 inch in tire size will require more lift (thus wanting 3) to clear the larger tire turning radius.
    Truck is totally stock. I've had it for 3 or 4 years, but have done nothing to it. Been waiting for the tires to wear out.
    I've modded YJ Jeeps in the past but am new to modding my Yota.
    I'm not looking for any exteme offraod performance, just better traction on wet unmaintained dirt roads and to cut down on the bottom end torque just a tad. I have to be very tender footed with the V6 to not start the wheelspin when it's wet.
  17. Dec 11, 2011 at 1:04 PM
    Ready4what
    Central AL
    03 Xcab PreRunner
    touche' :D haha You got me on that one.
    My point was merely that I am not looking to run the baja 500 or Crawl the Lions back in Moab and that spacers might be all I needed. I am unfamiliar with them as all of my offroad modding experience was years ago with leaf sprung YJ Jeeps. that's why I asked instead of assuming...
  18. Dec 11, 2011 at 1:06 PM
    08pretaco
    Oliver
    az
    solid axle lifting is a lot different then dealing with IFS
  19. Dec 11, 2011 at 1:09 PM
    Ready4what
    Central AL
    03 Xcab PreRunner
    So what do I need to do? Lift how much (for how much $$) or just lessen my ambitions to a 265/75 or 32" inch tire...
    What are your thoughts on the lift provided by the Bilstein 5100 shocks. I realize that they are probaly not enought for 285/33"s, but they might make 265/32" alot more comfortable in the fenders.
  20. Dec 11, 2011 at 2:42 PM
    jflan
    Vancouver, WA
    The cheat I think would be to go 275's if you don't want to cut for clearance and you want to keep your flaps.
    OZ-T started this thread and you might find it informative for what you are trying to do:
    http://www.tacomaworld.com/forum/wheels-tires/191520-275-70-17-stock-sport-wheels.html
    You will probably have to go at least 2-1/2" and add aftermarket UCA's if you want your caster adjustment restored.
    Lift spring lift - best
    Bilstein lift - good
    Spacer lift - ghetto
