Why plano cases on roof?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, May 7, 2021.
  1. Jun 10, 2021 at 8:53 PM
    #61
    TheSupremeReader
    TheSupremeReader Well-Known Member
    Andrew
    TRD OR DCSB
    i keep a CV and recovery gear up there...if i need it i dont want to dig it out.
    tacomavan and Taco 422 like this.
  2. Jun 11, 2021 at 8:30 PM
    #62
    rockin&rollin
    rockin&rollin Member
    2011 Silver Tacoma TRD double cab
    Because it wouldn't make sense to mount them under the truck.
    microsnook likes this.
  3. Jun 11, 2021 at 8:38 PM
    #63
    vtdog
    vtdog Well-Known Member
    NH
    Plano? Is that the same company that makes those cheap divider plastic boxes I buy at Walmart to keep my flies in?
  4. Jun 11, 2021 at 8:48 PM
    #64
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Only you can answer that. I don't know what you bought.
  5. Jun 12, 2021 at 1:16 AM
    #65
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
    https://www.tacomaworld.com/threads/why-plano-cases-on-roof.720434/#post-25648565
    I have one of those boxes in my bed. They are made by pelican under another name just for military use. I got it for $15 at good will, aside from all the rifles I keep in it unlocked, it's just a sand bag to weigh it down and a bunch of 5" round sack attached dildos rubbed down in wheel bearing grease to make some thief's night fun.
    mikalcarbine and Fahrenheit like this.
  6. Jun 12, 2021 at 11:35 AM
    #66
    Evergreen_Offroad
    Evergreen_Offroad Well-Known Member
    Andrew
    2009 Tacoma TRD Offroad Access Cab
    35s, armor, mid travel etc.
    Great storage option if ya don't wheel hard enough to need a good COG or care about aerodynamics :)
    Speedbird and Taco 422 like this.
  7. Jun 12, 2021 at 12:10 PM
    #67
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Generally not submerged up there, in water, mud or gear.
  8. Jun 12, 2021 at 12:11 PM
    #68
    Taco 422
    USA
    And the timeless Johnny and Roy EMT boxes.
  9. Jun 12, 2021 at 1:33 PM
    #69
    captaintofuburger
    I thought for sure I would have to ratchet it down or do something else, sandbag was just in my garage. I've had it in for a few years, and have really cranked it around, somehow it doesn't move. I think sitting on the factory rubber bed liner mat is helping a lot though.
  10. Jun 12, 2021 at 4:31 PM
    #70
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I made Tootsie pop with 3 licks.
    6 gearT444E[QUOTED] likes this.
  11. Jun 25, 2021 at 10:54 PM
    #71
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    They're very very similar 3rd gen has a reengineered rear bulkhead, the different roof line and rear light as well as revised rear pressure equalizing vents they also have a different floor pan if the different shaped edges to the floor mats are any witness.
    Even still a *LOT* of parts are cross compatible between 3rds and 2nds but obviously not everything.
  12. Jun 25, 2021 at 11:11 PM
    #72
    charliehex
    charliehex I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
    OP, are you asking why have them at all or why have them up there all the time? I can see how useful they would be on the trail or on a work truck. Not so much in the city every day.
  13. Jun 26, 2021 at 7:52 AM
    #73
    sprucemica
    sprucemica 2013 DCLB Limited 4.0L 4x4 - Spruce Mica
    I just got a 12-volt 5-ton electric jack and 12-volt impact wrench kit on a Prime Day deal. It was like $40 off. Comes in a hard case with metal clasps. Already used it and it works great. I plan to keep it secured in the bed of the truck as it's much easier than the stock jack.
  14. Aug 17, 2023 at 12:53 PM
    #74
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Looking to put two plano cases on a roof rack
    traction boards in the center
    Why do people get black?
    Black is hotter in the sun
    vs commonly available tan
    I do see used legit Pelican cases for good prices but unfortunately they're black...
    HFT has the tan ones, but they're not on sale right now
    so they'd cost more than used Pelican and whatnot
    I wonder if it's a negligible difference of temp like maybe 10deg and dependent on what gear you store, if it can handle it
    tan would cool cool, but black wouldn't look horrible either, and be cheaper...
  15. Aug 17, 2023 at 12:55 PM
    #75
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    My how the tune has changed in two years :rofl:
    chuam, jackn7, fiftysix and 7 others like this.
  16. Aug 17, 2023 at 1:05 PM
    #76
    Kwikvette
    Fresno County
    4 run, 2 don't
  17. Aug 17, 2023 at 1:08 PM
    #77
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Exactly, the people who DD their rig around the city with RTT and hi lift jack, shovels and kitchen sink hanging on their car are just being dorks.
    Kwikvette likes this.
  18. Aug 17, 2023 at 1:11 PM
    #78
    Kwikvette
    Fresno County
    4 run, 2 don't
    No kidding
    I even forgot I owned one for a minute :rofl:
    Would have to drive to my storage just to yank it out; we only used it for camping as it helped with room when we brought our chubby boy on 4 legs with us
  19. Aug 17, 2023 at 1:14 PM
    #79
    TacoTuesday1
    FL
    lol
    well if you’re curious what brought about the enlightenment
    I had to live in my truck for a short period of time
    Thankful to those who helped provide info on how to do it
    realized I should’ve asked my coworker more questions on how he set up his built Land Rover with all the overland shit.
    Dude had everything to be self sustaining and used it for camping. ARB fridge, solar, second battery, controller, etc
    the bed was comfortable
    but guess what. I realized quickly what this truck is at the end of the day: small, with limited storage room
    Clothes in drawers underneath
    Recovery gear in back seat cubbies
    My bare feet kicking a Hi Lift jack and my head next to a Heater Buddy
    I realized it could always use more storage room and space. Used cargo boxes are cheap and do look good.
    If that means no more clearing parking garages fine.
    even moving cross country, it will have more room. Off roading, it can include room for a spare CV.
    Don’t need my rack for solar as I already have a Renogy 100w flexible panel adhered to the shell.
    Probably not gonna get a Sherpa Crow’s nest 48” topper rack any time soon as I don’t see any for sale used and they’re pretty expensive to just end up having to redo the solar
    Not to mention I have no idea if the shell is reinforced and can handle putting tracks first (required) or what tracks to put (I believe Sherpa recommends Yakima brand)
    so may as well put traction boards on the center of cab rack (to get it out of the bed) with a Plano case on each side for total of two.
    The more shit you can carry the better. Because the alternative is having a storage unit making trips back and forth to it, or getting some expensive big long diesel truck that breaks requiring cab lift off the frame repairs.
    not to mention the ability such a setup has in other scenarios. Moving cross country pull over at night and sleep.
    Off roading trip actually spend time there days/week self sustaining instead of going there for only one day with nothing to experience 1 or 2 trails in the area far out instead of 7.
    made this mistake in CO. Drove to do Black Bear Pass and Imogene then went home. Would rather have camped out and done the entire Alpine Loop as there’s many more good trails there than just those two. Not to mention if you bring people with you which makes it more fun.
    it looks like Black Bear is still closed for now. For maintenance. but even going there when it opens is a long ass drive and would be better to split it into two stretches with a break.
    I do carry shovel and hi lift. They are cheap. Have used them many times.
    I am not a fan of RTT’s. Get bit by a snake “hold on let me fold my tent”
    “No I can’t move my truck”
    Inability to sleep in a cheap shell you already have stealth camping securely anywhere if you need to, instead of an expensive RTT, when a ground tent likely works the same but significantly cheaper and lighter + portable. Shell can sleep, fit gear, and carry things while RTT cannot and is added weight.
  20. Aug 17, 2023 at 1:21 PM
    #80
    LeakyAC
    Theres a 4Runner near me that must haul 1k lbs of stuff on the sides and roof to wal mart and back every week.
    Kwikvette[QUOTED] likes this.
