WHY READY LIFT AND FAT BOB'S LIFTS ARE A BAD IDEA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johns Taco, Sep 14, 2011.
  1. Sep 14, 2011 at 3:33 PM
    Johns Taco
    Johns Taco [OP] I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    This has been an ongoing dispute here of why they are bad with plenty of pics of what happens when things break due to "bottoming out". I have the Fat Bob's spacer lift. Well I took my 5 lug off road today where 2wd vehicles are not meant to go {really rocky, steep hills and desents, deep grooves in the ground from water runoff} and everything is fine. Things got really ruff quite a few times where I know I bottomed out often, went out to check if everything was ok and things were fine. First off I am stoked my truck did fine, never had a single problem. Second....I noticed every single pic of shock breakage is on the 4wd or prerunner running stock 5100s with this lift, not 1 single pic of the shocks on a 5 lug breaking. What's the deal here.
  2. Sep 14, 2011 at 4:41 PM
    Johns Taco
    Albuquerque, NM
    Bump for comments, good and bad.
  3. Sep 14, 2011 at 4:43 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    You didn't jump it high enough.
  4. Sep 14, 2011 at 4:43 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I would guess that few people run 5 luggers off road vs the 6 lug trucks.
  5. Sep 14, 2011 at 4:44 PM
    JDMcQ
    And, 5100s are not stock. They are an aftermarket replacement.
  6. Sep 14, 2011 at 4:47 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    It's funny that it's always the same 2 or 3 pics out of 1000s of people who run them.
  7. Sep 14, 2011 at 4:48 PM
    Johns Taco
    Albuquerque, NM
    Oh, I didn't know. Just seen every pic of them being broke was a 5100, thought they came stock. If your gonna get a lift kit and 5100's why not just get the right lift. Not so easy for us 5 luggers.
  8. Sep 14, 2011 at 4:51 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    But on a serious note, I did run a procomp 3" spacer for about 1 1/2 years. It rode like a dump truck and would never recommend them to anyone, now saying that I never had a problem with them besides the ride and eventually they started to sag pretty bad. But as far as any thing breaking no I never had a problem and it was wheeled with the spacer.
  9. Sep 14, 2011 at 4:52 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    only pics i've seen of broke shocks w/ spacers were stock yellow billies, not 5100s.
  10. Sep 14, 2011 at 4:52 PM
    JDMcQ
    Me too.
  11. Sep 14, 2011 at 4:59 PM
    Johns Taco
    Albuquerque, NM
    I stand corrected again, but still no 5 lug shock breakage. Should I cool it while off roading or are 5 lug shocks just set up better. Chime in folks.
  12. Sep 14, 2011 at 5:02 PM
    JDMcQ
    Wheel the piss out of it, when they break, take a picture, you can be the first on the interwebz!
  13. Sep 14, 2011 at 5:06 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah I don't think I've seen 5 lug drivers get that much air. most of the guys braking there stock shocks are hucking there trucks or bombing down roads that bottom out the shocks.
  14. Sep 14, 2011 at 5:07 PM
    Johns Taco
    Albuquerque, NM
    Hmmmm, would I be the first? If it's not going to break than the need to upgrade down the road seems less and less important. Somebody please tell me if this system has ever broke, aside from the haters.
  15. Sep 14, 2011 at 5:09 PM
    Johns Taco
    Albuquerque, NM
    Definitely not trying to get air, mid travel suspension is in my sights though.
  16. Sep 14, 2011 at 5:12 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    ive had fat bobs for well over 2 years, ive wheeled it pretty hard. Was holding my ground with some LT guys for a while. never had a single problem. the ride is a little rough but new shocks will fix it.
  17. Sep 14, 2011 at 5:23 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Never seen a 5-Lug personally with the Fat-Bobs lift on it but I'm assuming it's similar to every other spacer lift. The Problems can occur from bottoming out the suspension prior to hitting the bump-stops (as the spacer has pushed the suspension down so you "run out" of up-travel prior to hitting the bumps) or from over extending the joints since the lift pushes the shock downward allowing for more droop.
    On Taco's from what I know there is extra room to accommodate for the extra down-travel, hence the market for Ext. Travel Coilovers (not sure if this applies to 5-Lugs though).
    Since you don't have CV's to bind with travel, you shouldn't have too many problems. Check that when your suspension bottoms out that it is coming in contact with the bump-stop pad. If Yes, then you should be fine. If No, I'd look into extending your bumpstops.
  18. Sep 14, 2011 at 5:26 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    this is the best pic i have of it
  19. Sep 14, 2011 at 5:27 PM
    theduck911
    Max
    Locked and Geared!
    Assuming it is the small Silver Top Plate?!
  20. Sep 14, 2011 at 5:32 PM
    jonny
    jonny Betty White Edition Heep ZJ
    shit...
    I added a winch and bumper and a small dip in the road fckd over my stock shock (fj)
    snapped the shaft and bent the bottom portion. wasn't even going that fast... :laugh:
