Why recommend OME than coilovers for a 98 Tacoma 4WD DBL Cab 3.4L?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Peternorth, Aug 14, 2009.
  1. Aug 14, 2009 at 7:00 AM
    Peternorth
    Peternorth [OP] Member
    Alberto
    Mexico
    Tacoma 4x4 3.4L Limited
  2. Aug 14, 2009 at 7:01 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    I assume you mean adjustable coilovers. Which ones are you looking at?
  3. Aug 14, 2009 at 7:01 AM
    JDMcQ
    Great User name, by the way!
  4. Aug 14, 2009 at 7:19 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What exactly are you asking?
    Adjustable struts (5100's for example)
    versus
    OME coils & non adjustable struts?
    Ok....here's some thoughts: Your truck can only be lifted about 3" max with a coilover lift.
    How much lift are you looking for?
    How do they compare in cost?
    I had a set of OME 881 coils (2" lift) with OME struts on my 96 many many moons ago. NO complaints at all. 5100's weren't avialable back then. OME makes many different types of coils.
    If I were to lift my truck now - I'd go with the 5100's because of the adjustability. Adjust it for 2" now and adjust it more in the future if you like. Or, for whatever reason...if you ever need to put the truck back to stock, you can do that without buying anything. You can also put the 5100's back down to stock and put lift coils in if you want.
    But again, compare the cost.....
  5. Aug 14, 2009 at 10:09 AM
    Peternorth
    Alberto
    Mexico
  6. Aug 14, 2009 at 10:13 AM
    Peternorth
    Alberto
    Mexico
    Thanks Janster, how about these, what would you recommend?
    http://www.toyteclifts.com/index.ph...ategory_id=63&option=com_virtuemart&Itemid=72
    and
  7. Aug 14, 2009 at 10:17 AM
    JDMcQ
    Chris4x4 would be the one to ask about this. The adjustable coilovers at which you are looking are Bilstein 5100s with an adjustable collar on the top. If you need to adjust your suspension then they are fine choices. If not, then you can get regular Bilstein 5100s and set them at the height you want before installation.
    What are you planning on doing with your truck? Desert running, rock crawling, light off road, just cruising?
  8. Aug 14, 2009 at 1:09 PM
    Janster
    Jandy
    Lancaster, PA
    I don't have personal experience with Toytec or Bilsteins...
    Lots & lots of guys are running Toytec stuff. Do some research on this forum (Search button, top blue bar) and you'll find lots of questions, answers, & feedback about the toytec lifts.
  9. Aug 14, 2009 at 1:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2.
  10. Aug 14, 2009 at 2:07 PM
    pittim
    pittim mittip backwards
    Pink slider.
    IMO Toytec is kinda overrated, since it's 5100s and their springs to make the coilover.
    I'd say either get OME/5100s, or go with a better coilover (Icon, Fox, King)
    If you don't do much offroading the OME/5100 setup will do you fine.
  11. Aug 14, 2009 at 2:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Or OME springs with OME shocks....
  12. Aug 14, 2009 at 8:39 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    am i the only one to notice he said "98 Tacoma 4WD DBL Cab"
    :confused:
  13. Aug 14, 2009 at 9:49 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    ^^^No, I did too... I think he meant Xtra cab.:)
    And I love my Toytec coilovers! they ride great and are good for minor offroading. I basically got them for the adjustability. I could set the hieght were I wanted, and that they have a life time warrenty.
  14. Aug 15, 2009 at 5:36 AM
    Janster
    Jandy
    Lancaster, PA
  15. Aug 15, 2009 at 5:44 AM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. Retro stripes. blacked out front bumper. 265/70/16 Goodyear Wrangler Adventures. NST Lite Pulleys
    i think he knows what truck he has...
    Mexico gets lots of vehicles the states don't
    '98 dbl cab
    2000 Ramcharger for example
    ^ saw one of these in the DFW area about a year after they came out
    sorry to thread jack :eek:
  16. Aug 15, 2009 at 7:09 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    thats a 01-04 dbl cab
  17. Aug 15, 2009 at 1:02 PM
    sockmonkey
    Greg
    oops...shutting mouth
  18. Aug 15, 2009 at 4:37 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    its been said, but basically you want OME 881 coils and OME N91S shocks or Bilstein 5100 shocks.
