Why slotted rotors?
Discussion in 'Wheels & Tires' started by SCFirefighter, Aug 8, 2010.
  1. Aug 8, 2010 at 8:29 AM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Granted, they look cool, but besides that what is the pull? Why do it?
  2. Aug 8, 2010 at 8:32 AM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    When you apply the brakes gases get traped between the pad and rotor. The slotts let the gases escape and the pads make better contact with the rotor.
  3. Aug 8, 2010 at 8:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Additional gas/dust venting capacity thru the slots even when they are "behind" the pads and heat dissipation due to increased surface area iirc.
  4. Aug 8, 2010 at 9:40 AM
    SCFirefighter
    Stephan
    Cary, NC
    I don't really see this as a mod people do a lot on here. Any reason?
  5. Aug 8, 2010 at 9:42 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i like slotted rotors because they are typically stronger..less likely to warp, and there aint no brake fade with them and good pads, pads bite alot better on them...to me anyway.
  6. Aug 8, 2010 at 10:25 AM
    SCFirefighter
    Stephan
    Cary, NC
    So, compared to installing the Toytech coilovers, 5100's all around and an AAL, how complicated is it to replace the rotors if you've never touched a brake system before?
  7. Aug 8, 2010 at 10:27 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    The only thing with them is they will wear out the pads a bit faster. Thats the reason I won't get them.
  8. Aug 8, 2010 at 10:28 AM
    mwild
    Vernon, NJ
    03 2500 Dodge Ram
    Very easy. Just take the calipers off and the rotor slides off and replace the pads. The hardest part is that you have to use a c-clamp to compress the calipers so the new pads fit. Just take the cap off the resivor before you compress them.
  9. Aug 8, 2010 at 10:29 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    really easy.....basically, pulling the pads and caliper bracket, and taking stock rotors off, putting new ones on, and then putting the bracket,caliper and pads back on.
    i dont think they wear the pads out faster honestly, they do keep them alot cleaner tho.
  10. Aug 8, 2010 at 11:30 AM
    Malamute
    Malamute Active Member
    Dan
    CO
    The biggest downside and the reason most that off-road frequently is small rocks can get wedged in them. On a sportscar that may have heavy braking at high speeds I can see the benefit......not on a 4x4.
    As far the the pre-runner people and their speeds I can see a need for increased performance, but the chances of getting small rocks caught in them is high. I never had them on my Jeep and don't see the need on my truck now.
  11. Aug 8, 2010 at 2:56 PM
    SCFirefighter
    Stephan
    Cary, NC
    Thanks for shedding a light on the flipside. Rocks in breaks sounds like a genuinely "bad thing" [tm]
  12. Aug 8, 2010 at 8:19 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Well you know better than me, I have no experience with them.
  13. Sep 1, 2010 at 4:03 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    My brakes pulse. I've read on TW that it is because the rotors were over heated and warped. Would slotted rotors prevent this ?:confused: Curious George
  14. Sep 1, 2010 at 4:57 PM
    george3
    New Jersey
    Thanks, but what would be my best bet ? I'm no hot shot aggressive driver and my brakes pulse.
  15. Sep 1, 2010 at 4:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go for a set of slotteds man. try http://raceshopper.com/ they have the best prices and customer service i have ever seen.
  16. Sep 1, 2010 at 5:05 PM
    george3
    New Jersey
    Thanks. I've read that B 4 but get confused when people post that slotted warp too. I was thinking of going raceshopper and Hawk LT but still undecided about the slotted.
  17. Sep 1, 2010 at 5:10 PM
    george3
    New Jersey
    Thanks. Guess it's the way to go.
