Why so long to turn over?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by br217398, Aug 3, 2009.
  1. Aug 3, 2009 at 11:17 PM
    br217398
    br217398 [OP] Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    It is taking my engine forever to turnover in the mornings, noon, and even right after turning the truck off. the battery has been tested and it says its ok, so that leaves my alternator and starter.
    ANY IDEAS????
  2. Aug 3, 2009 at 11:24 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    What kind of oil do you have in the engine? Type, and weight?
  3. Aug 3, 2009 at 11:34 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I heard that if you turn the ignition on and leave it for a little before turning on, it should start faster. This is because of the fuel pump taking time to get gas or something. Idk im not a mechanic.
  4. Aug 3, 2009 at 11:36 PM
    Blu08Taco
    Blu08Taco Taco™
    Florida
    08 TRD Sport
    Check your battery terminals.
  5. Aug 3, 2009 at 11:54 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I've said this time and time again for most people, you can't just turn the key over. You have to give the fuel pump a second to prime the system. Its only common sense once you understand it. The fuel pump doesn't turn on until you turn the key to 'ON'. Basically you're trying to start it with no gas.
  6. Aug 4, 2009 at 11:00 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Ahhh so your the one I heard it from! good info! :)
  7. Aug 4, 2009 at 11:03 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    He's correct, I usually wait for the beeping to stop then crank. it should fire up instantly.
  8. Aug 4, 2009 at 11:38 AM
    brian
    Elizabeth City, NC
    If that doesn't fix it, get a tune up. That is all :)
    Your alternator has nothing to do with starting your truck unless it completely fails to start. The starter is obviously turning it over, so why would you think that it could be the problem?
    Depending on your mileage, if you're over 50k without a tuneup, I'd reccomend it. The factory toyota spark plugs are copper and wear out fairly quickly.
  9. Aug 4, 2009 at 11:43 AM
    br217398
    Orlando Florida
    sweet this was some quick info that i couldnt find...... ill give it a try today, but i just cleaned the battery terminals, ive got almost 70k with the same spark plugs so those may need changed soon, the fuel pump this does make sense, so well see what happens. The only this is that twice this week it wouldnt even turnover it was just dead.... THanks yall for the help
  10. Aug 4, 2009 at 11:49 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    And remember that the first step in a tune up is a complete battery service. At least that's what it says in my 1947 Motor's Manual.
    That means battery, and cables, and connections get cleaned, inspected, and tested.
    I don't know how many good-looking battery cables I've seen in the last 40 years turned out to be bad due to concealed damage or corrosion.
    Batteries can look fine and test OK, until you do a serious load test.
    Finally, vehicles with digital injection need a certain voltage to operate the computer. They are often very finicky about battery condition/connections.
    I've seen vechicles crank over plenty fast, and they would have started OK if they'd had breaker point ignition. But the voltage fell just 1/10 volt below what the computer wanted to see, & the engine just wouldn't fire.
  11. Aug 4, 2009 at 11:56 AM
    brian
    Elizabeth City, NC
    That's true I forget how much the computer controls things nowadays. Either way, he said he had it tested. If he took it in, I would assume they load tested it. Thats standard nowadays.
    70k on original plugs though, jeezzus, do a tuneup bro, I'd put money on that being your issue. Standard tuneup is around 30k, I let mine go till 45k and the plugs didn't look very healthy anymore. Gaps were inconsistent as well.
  12. Aug 4, 2009 at 12:00 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    i had this problem once, turned out my air filter was dirty as hell after some recent offroading trips. make sure yours is clean see if that works
  13. Aug 4, 2009 at 12:03 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Good info. I'm going to have to start leaving it in the on position longer instead of just cranking it to start.;)
  14. Aug 4, 2009 at 12:40 PM
    coma09
    coma09 Updated avatar
    BC Canada
    2013 taco access cab 4x4
    I find my 4cyl takes 4 or 5 revs before it fires up.
    I'm so used to previous vehicles starting on the first rev.
    Sales person said that Tacomas (and Tundras ... demoed both) are long turnovers.
    Dunno how long your turnover is ..... but I find my situation definitely long compared, as I mentioned to other vehicles I've driven.
    It's pretty new, - so nothing dirty or worn out as yet.
    "normal"
    If it's not running, then a- it's not getting gas, or b- not getting spark
    (or timing ... which is not an issue, since it runs). Suspect strongly - a, and I agree with the posts that suggest waiting on presurization of fuel line to injectors.
    Gas filter?, bad fuel pressure regulator or check valve, fuel pump weak.
    I take it, it's turning over OK .... otherwise battery.
    Spark .. if wires and/or plugs are bad, that'd work against you for sure as well ... however does it idle smooth after starting? Likely not bad wires/plugs. I'd be looking at fuel (or mixture - ie too rich if air filter is heavily clogged) Mixture and weak spart together would certainly cause hard starting.
    Gotta try leaving my key in 'on' a few seconds before starting to see if that reduces the number of revs my starter has to make.
    Edit:
    OK, adding this next day .. as one poster mentioned, turn on until the beep - ~3 sec. Starts on the 2nd rev. (quicker than not 'priming' it) So definitely building fuel pressure from the time you turn the key, and needs to be at a certain pressure to fire.
  15. Aug 4, 2009 at 12:55 PM
    JKD
    JKD Well-Known Member
    How long does it take from when you turn the key to "start" to when the starter engages and cranks the engine?
    And then how long from when it cranks to when it runs?
  16. Aug 4, 2009 at 1:28 PM
    09WhiteTaco4x4
    09WhiteTaco4x4 Well-Known Member
    Washington
    2009 4x4 TRD Off-Road DC
    Removed mud flaps, Borla cat-back exhaust, AFE Pro-Dry S air filter
    I'v noticed that my Tacoma takes longer to start than my previous vehicles. Just one of those things I guess. I'm going to have to try leaving turning to ON first for a second, then starting it.
  17. Aug 4, 2009 at 1:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Keep in mind a "Long time" could mean only a few seconds. If its 5 seconds, or less, thats considered normal.
  18. Aug 4, 2009 at 1:34 PM
    Uhaul-n-azz
    Uhaul-n-azz Well-Known Member
    fayetteville,AR
    4Runner Stock
    Mine used to do that toyota dealership said it was a fuel pressure problem and just reprogrammed it at it was fine.
  19. Aug 4, 2009 at 3:54 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    I wouldn't say mine is slow to start. It starts exactly like our V6 Camry.
    click, 1, 2, 3, vroooom
    They've both started like that since day one.
    Now my Bonneville starts like this;
    click, va, roooom
    Unless it's been sitting without being driven for weeks.
    Which happens since I bought the new Tacoma.
    Then it goes click, 1, 2, 3, vroooom
  20. Aug 4, 2009 at 5:48 PM
    br217398
    Orlando Florida
    Well, it takes 5 seconds to start if it does start.... ive tried a few times this week and it just wont turn over untill i get a jump from a friend....... i tried the hold the ignition and wait but it didnt help at all.
