why so many A/C’s blowing up now?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Aug 10, 2022.
  1. Aug 11, 2022 at 8:45 AM
    Wesmonster
    Wesmonster Member
    Wes
    2915 access cab
    This is my philosophy. Other than checking the Freon levels, there’s nothing requiring regular maintenance. And when you live in the south, you know as soon as your BTUs start dropping. So if it doesn’t feel off, worry about something else. Like frame rust...
  2. Aug 11, 2022 at 8:56 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    But not really. The system is always under pressure with it shut off or operating, even the low side, so unless those water molecules can swim upstream like salmon it ain't happening. There are certainly some contaminants generated by wear, and maybe from the effects of heat on the oil, refrigerant, hoses, and other parts but the only real opportunity for moisture to get in there is with an open/empty system prior to the evacuation and charge process. That's why they always tell you to replace the receiver/drier whenever the system gets opened. Unfortunately for us that also means the condenser. And that's why a really good leak test and deep evacuation are key to longevity. One of Toyota's few questionable design moves. Although they might say that this eliminates some extra lines and seals that could develop leaks.
    Williston likes this.
  3. Aug 11, 2022 at 10:23 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Yeah, they ran the suction pump for about an hour to evacuate all air, water, refrigerant, and oil. It was the deluxe job.
  4. Aug 11, 2022 at 10:37 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well they can the AC runs on defrost.
  5. Aug 11, 2022 at 10:49 AM
    Raylo
    MD, USA
    Face it, many of our Tacomas are just getting old.
    AJKlug1 and TexasWhiteIce like this.
  6. Aug 11, 2022 at 2:55 PM
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
    I have no problem with my truck getting old...it's me getting old that's annoying. Trucks are fairly easy to fix...old, decrepit bodies aren't.
    TomTwo, PzTank, Gearheadesw and 2 others like this.
  7. Aug 11, 2022 at 4:45 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    I never knew/noticed that the Toyota systems didn't have the receiver/drier as a separately replaceable component. That's beyond questionable: it's ridiculous (IMO) No reason it has to be part of the of the condenser. Every automotive a/c system I have had in a vehicle since the '60s has had a separate rec/drier setup. Definitely GM, Ford, Volvo (GM components after 1992), Chrysler. I'm talking way back to the "site glass" days. Cannot speak to other euro or asian systems.
    One side benefit of the move to R134 as a refrigerant (other than being more friendly to the Ozone layer) was that although it was less efficient than R12, it is a much smaller molecule so required a much more robust system to hold the refrigerant: seals, fittings, compressor, etc. I have had about a 50/50 split in vehicles over the years now between R12 and R134 based systems. The R12 systems seemed to always need a charge, and the fittings, compressor and connections frequently developed a visible oil film around them from leakage.
    Raylo[QUOTED] likes this.
  8. Aug 11, 2022 at 4:51 PM
    Raylo
    MD, USA
    I feel you. I am in the same boat. Or sinking ship!
    shmn[QUOTED] likes this.
  9. Aug 11, 2022 at 5:14 PM
    Raylo
    MD, USA
    I still have a can of R12 in my garage. Bought it maybe in 1982 or so for a Firebird and it traveled with me wherever I moved. Had others but this one was left over.
  10. Aug 11, 2022 at 7:01 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    that also annoyed me. I would rather swap out the receiver/dryer than deal with the entire condenser assembly. I suspect I have a leak on the low side hose pipe and once summer passes here in FL I plan on replacing it, the seals, the condenser, and the little filter thing in the system.
  11. Aug 11, 2022 at 9:02 PM
    Williston
    New England
    Thank you.! It sure annoyed the heck out of me too and my a/c is working fine right now: ice cold in New England (!) of all places where we just had a heat wave of ten days over 90 degrees. Nothing like you poor so-and-so's have in the Southwest, but major up here. I'm fishing in Maine and it's the same thing: icy cold streams??? nah: Wade right in. West Branch Penobscot River. Makes me nervous: and the fish are either hiding or gone.
    Reggie4x4 likes this.
  12. Aug 12, 2022 at 6:04 AM
    Raylo
    MD, USA
    Hearing this annoyed me, too. Understatement. Makes it even more critical to do a perfect leak check and evacuation and to make sure it can hold that vacuum without dropping for awhile before charging.
  13. Aug 12, 2022 at 5:53 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    1. 480,000 miles later and I've never touched anything in the A/C system. Still blows cold. A few years ago I asked a friend of mine who is a career mechanic if it was OK to "re-charge" the system. He said "no, the system is sealed and anytime you open up the system you invite problems. If it's still blowing cold air, leave well enough alone."
    burrito782 likes this.
  14. Aug 12, 2022 at 6:00 PM
    Sarra
    Sarra Well-Known Member
    2007 TRD Off Road 4.0 6MT
    None yet
    While this is true, unless you live in a place that stays really warm in the winter, the AC will maybe only actually be on for 2-3% of the time you drive in the winter. The evaporator will freeze up otherwise, so the AC will kick on and drop that Evaporator down to 30° and then wait for it to warm up.
    In the summer, especially when it's over 110°, your compressor might kick on 100% of the time, and stay on for a number of hours at a time, which is a lot of heat and stress for the system.
  15. Aug 12, 2022 at 8:03 PM
    #35
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    As long as we’re on the AC subject, are these compressors a bit aggressive when they kick in? I can slightly feel a tiny lag in power while cruising when it kicks on. Also at stop lights the truck actually surges forward on the brakes.
  16. Aug 12, 2022 at 8:08 PM
    #36
    Sarra
    None yet
    I don't have an auto, so I can't say what it does to idle engine power, but it sounds pretty normal. Mine surges pretty hard when it kicks in or out, and I certainly feel it if I'm going up a steep hill, and it has scared the crap out of me having it kick in while going up a stupid steep dirt mountain side in 4LO. I thought I broke an axle or driveshaft for a second, then I realized what it was and was able to let my seat back to it's normal place by releasing the pucker...
    It can, and usually does, require quite a bit of torque to move the freon through the system, especially with a piston style compressor. At least we have big heavy rotating assemblies to soak up some of the sudden torque shift, some Subarus feel like they're gonna stall for a second when the compressor on those kick in. D: Oh, yeah, I had a lightweight flywheel in my WRX, which made it even worse. Hah.
    Logger[QUOTED] likes this.
  17. Aug 12, 2022 at 8:17 PM
    #37
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That's why a lot of luxury cars use a variable displacement compressor to minimize rpm changes at idle, no cycling on/off
    In regards to OP's question, compressors fail fairly often because they're the ones doing all the heavy lifting in the system. And the most dependent on lubrication. If a leak develops somewhere often the compressor oil goes out the hole with the refrigerant putting the compressor at risk.
    I've done a ton on lots of different cars. Honda CR-V for some reason and lots of domestic vehicles like GM and Ford
  18. Aug 13, 2022 at 3:46 AM
    #38
    Raylo
    MD, USA
    Fantastic long service for an A/C system. That has to be or be close to a record. I totally agree. Don't touch it unless you have a problem. I don't even put the gauges on mine to avoid cycling and wearing the schraeder valves. Those readings do not really tell you much about determining the precise state of charge anyway since temperature and load conditions vary so much.
  19. Aug 13, 2022 at 8:07 AM
    #39
    Taco'09
    Taco'09 Well-Known Member
    FWIW, around 2012 or so I had a discussion with a guy at Denso (Denso Aftermarket) who stated he was previously employed at the NUMMI plant in Fremont, CA where the Taco was originally produced.
    The NUMMI facility was a joint venture between General Motors and Toyota. That is why so many, and I believe all, of the parts on our HVAC systems are Delphi and not Denso.
    Anyway he said the original AC compressor, produced by "Delphi", was then on the aftermarket but now with a Denso badge.
    Sure enough, I purchased a "Denso" compressor to discover that its "Denso" sticker of information was rather sloppily attached and revealed there was yet another sticker underlying. I peeled of the sticker to find a "Delphi" sticker underneath with all the same specs. I still have the compressor.
  20. Aug 13, 2022 at 8:25 AM
    #40
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like Delphi built all the original compressors, Denso just remanufactured them after they failed or got scrapped.
    Denso makes a good reman product. I use them all the time for starters, alternators, etc
