Why synthetic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbp68, Sep 28, 2010.
  1. Sep 30, 2010 at 8:18 AM
    #41
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Now is the time to switch! Synthetic (mobil 1) will run good in your truck. You will notice a big difference in the sounds that come from your engine on cold starts this winter.
  2. Sep 30, 2010 at 8:31 AM
    #42
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Ok...you guys got me thinking. I've never used synthethic but it sounds like pretty good stuff. Is 15,000 miles too late to make the change. Would you use semi synthethic first before going to full synthethic with that many miles?
  3. Sep 30, 2010 at 8:46 AM
    #43
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    no 15,000 miles isnt to late, and ya i would prolly do a semi synthetic for a oil change or 2 then go on to a full synthetic
  4. Sep 30, 2010 at 9:00 AM
    #44
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Well done. :thumbsup: I just performed my first oil change at 8000 kms on my new truck and used Mobil1 full synthetic for the reasons stated above. I also feel that under extreme cold conditions synthetic retains it's viscosity more consistantly than conventional particularily on startup which is where some of the most nasty engine wear occurs.
  5. Oct 10, 2010 at 8:51 AM
    #45
    garrettc134
    garrettc134 Active Member
    I'm at 85k, have always used conventional oil. Should I switch to synthetic or high mileage or keep on using the same stuff? Also any downside to the walmart brand synthetic? Plus what about 0w-20 in an 05 taco?
  6. Oct 10, 2010 at 6:51 PM
    #46
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    0w-20 would not be a good idea. Your manual is going to advise a 10w-30. So, you should have that number range in whatever oil you buy. IE: 0w-30 is fine, so is 10w-40. Both contain the range requested by your manufacturer. 0w-20 is not going to provide you with the high temperature protection you want.
    What your manufacturer is telling you is that you need an oil that will handle everything a weight 10 up to a weight 30 oil can handle. That's a matter of the heat range at which the oil has the right viscosity. Trimming on either side of that range is not a good idea.
    Walmart sells mobil1, which is good oil.
  7. Oct 10, 2010 at 10:40 PM
    #47
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    I switched my moms Acura RL with 150K+ miles on it to synthetic. Straight over no half breed in the middle. And it doesnt burn oil, doesnt leak. Nothing. All the rumors are just that.. rumors.
  8. Oct 10, 2010 at 11:03 PM
    #48
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Switched over at 60k miles. Runs perfect.
  9. Oct 30, 2010 at 5:52 PM
    #49
    USAONE
    USAONE Well-Known Member
    2011 DC Tacoma Prerunner SR5
    Stock
    Is it ok to switch to synthetic after 140,000 miles? I heard it may make the engine start using oil if you have only run regular oil.
  10. Oct 30, 2010 at 6:01 PM
    #50
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Its fine. I switched at 156k and don't burn a drop over my 5k mile oil change intervals.
  11. Oct 30, 2010 at 6:06 PM
    #51
    Mike5150
    Mike5150 New Member
    Virginia
    2017 Tacoma TRD
    I'm around 30,000 miles in my 06 and I've been doing roughly 5000 mile oil changes so if I switch to synthetic how often should I change it, what weight should I use and what brands would you guys recommend?
  12. Oct 30, 2010 at 6:16 PM
    #52
    sloancallaway
    sloancallaway Well-Known Member
    Sloan
    Spruce Grove Alberta Canada
    synthetic oil, I use mobile 1 and have in all of my vehicals here is why
    -your vehical will start regardless of the temperature outside (even when you forget to plug it in)
    -it has been proven to better lubricate by penitrating deeper into your internals
    -cleans better
    -extends oil life (however I do change filters inbetween oil changes most of the time
  13. Oct 30, 2010 at 6:19 PM
    #53
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Any name brand oil in the recommended weight for your engine will do, I personally use Pennzoil Platinum. If you want to extend the oil change intervals past 5k I would get an oil analysis done at 5k to see what kind of life the oil still has. There are people who go 15k on amsoil.
  14. Dec 8, 2010 at 1:23 PM
    #54
    ssiboogie
    ssiboogie New Member
    Dave
    Georgia
    11 4x4 SR5 Double Cab
    Seats Front Leather Camo Rear, ARE Tonneau Cap
    We bought a 50HP centrifugal air comp in 1987. Paid $800.00 extra for synthetic oil since the manufacturer then gave a 5 year replacement warranty instead of 6 months with regular oil. Figuring manufacturers go on a lot of numbers, for a new 93 Ranger we used synthetic. It just got broken up for parts with nearly 400,000 mi on the clock and no engine work. A 98 Ranger now has over 200,000 mi. We change oil every 10,000 mi whether it needs it or not. Just got the Taco, and looked here to find out why it didn't come with synthetic. Remember the old Chevy with noisy sticking valve lifters and the trick to throw in a quart of transmission fluid for a hundred miles before an oil change to free them up? Transmission fluid is synthetic oil and that's what it does for you full time.
  15. Dec 8, 2010 at 1:24 PM
    #55
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    I switched at 25000 miles yesterday 5w-20 Valvoline Synthetic....let's see how she rolls
  16. Dec 8, 2010 at 1:33 PM
    #56
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    I thought about swithching but I heard that if my truck had leaks that the leaks would get worse??? Just a rumor?
    Its got 122K miles
  17. Dec 8, 2010 at 1:41 PM
    #57
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I know about that trick but I thought there were cleaning elements in trans oil that did the deed. Completely wrong ?
  18. Dec 13, 2010 at 12:20 PM
    #58
    ssiboogie
    Dave
    Georgia
    Using oil may not be as bad as it sounds as long as it isn't making smoke, it means the oil is getting places it didn't get before and that may include places not receiving enough lubrication. The classic case was the early 60's Ford Falcon. The oil seals on the valve stems were so good the valve guides got no oil. That engine occasionally dropped a valve into the cylinder. The fix was seals that leaked a bit, when you rebuilt the engine, if there was anything left worth fixing.
  19. Sep 20, 2017 at 12:04 AM
    #59
    WY2015TacomaTDR
    WY2015TacomaTDR New Member
    Brett
    2015 TRD Off Road
    So long story short, switch to synthetic after 30,000 miles. My tacoma has 32000 and conventional has been used the whole time. Getting oil done this week, going for the synthetic after reading through all the BS ha ha.
  20. Sep 20, 2017 at 12:32 AM
    #60
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
