Why that remote starter?
Discussion in 'Product Reviews' started by skulltacoma, Feb 17, 2010.
  1. Aug 25, 2015 at 10:43 PM
    #41
    Rottenstock
    Rottenstock Member
    Roger
    Oregon
    2015 Magnetic Grey Tacoma TRD Off Road
    I have been looking into getting a remote start for my '15 Taco. All the ones I have seen have the trunk open button. Do any remote start/alarm systems come with a FOB that doesn't include that button?
  2. Aug 25, 2015 at 10:47 PM
    #42
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    The viper 5706? I could be wrong but that's the one I'm looking at and didn't see a trunk button
  3. Aug 25, 2015 at 10:51 PM
    #43
    Rottenstock
    Rottenstock Member
    Roger
    Oregon
  4. Aug 28, 2015 at 10:39 AM
    #44
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I just installed the Viper 5706V last weekend. I bought the iDataLink on ebay for the bypass. The remote start has worked every time. I also installed 2 DEI 535T window modules to control the windows. Everything works pretty well... except that the alarm doesn't trigger when I manually pop the lock. I'm pretty sure it has to do with the wiring I did. In all the online wiring diagrams I found, it said the 2014 Tacoma has a pink/black wire for the rear doors, but mine didn't have that. The rear doors do unlock, but I wonder if it's because the front is unlocking all the doors. I didn't program the remote to double pulse, but that's how it's acting anyways. Double pulse is like the oem configuration for unlocking driver/ all doors.
    Over all, I'm happy with it. I just need to figure out the alarm bit this weekend.
    #44
  5. Aug 28, 2015 at 10:53 AM
    #45
    azhiaziam
    The reef ca
    good to know its on my checklist of things to do.
    #45
  6. Aug 29, 2015 at 9:56 AM
    #46
    Revelations
    2014 MGM DCSB
    I got my wiring worked out and everything works! also, there is a pink and black wire. I had tapped into the wrong harness. haha
  7. Sep 19, 2015 at 11:48 AM
    #47
    Revelations
    2014 MGM DCSB
    The instructions come with the remote start system. They're universal, so check out the alarm install thread for a Tacoma install.
  8. Nov 5, 2015 at 11:59 AM
    #48
    GANBRO
    GANBRO Member
    New Brunswick - Canada
    2013 White Tacoma Double Cab TRD Sport
    Heated Mirrors Kit - AMP Research Steps - CrimeStopper Plug & Play Remote Starter - Pop&Lock Tailgate Lock
    Don't know if you already got yourself a remote starter but I got myself this plug and play kit. So easy to install. There are 3 CrimeStopper Cool Start models, I got the the 2nd one with a one button remote:
    1) http://www.amazon.com/dp/B00T21I5D2...UTF8&colid=GSEZ8KK9A3XG&coliid=I2XSYGOIZ7GSDM
    2) http://www.amazon.com/dp/B015IKICSS...UTF8&colid=GSEZ8KK9A3XG&coliid=I24L8WUDIQ2244
    3) http://www.amazon.com/dp/B00T21RWIQ...UTF8&colid=GSEZ8KK9A3XG&coliid=I1E9JU7OW9JA82
  9. Nov 5, 2015 at 12:22 PM
    #49
    mmcarbo
    mmcarbo Well-Known Member
    Massachusetts
    I ended up with an Audiovox Pursuit. Fantastic range with a small remote.
  10. Nov 14, 2015 at 7:06 AM
    #50
    azhiaziam
    The reef ca
    Is it normal for the first start to sometimes fail? After putting mine in it sometimes doesn't boot right up on the first start cycles then starts on the second. Just wondering to see if it causes any harm on my truck.
  11. Nov 14, 2015 at 7:17 AM
    #51
    GANBRO
    GANBRO Member
    I'm no expert but I had the same issue with my Tacoma. After programming the tachometer option the remote starter gave the engine starter enough time to start the engine "Tach Reference Mode – Monitors Engine R.P.M. - Most reliable method".
    Justinlhc likes this.
  12. Nov 17, 2015 at 11:55 AM
    #52
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    You should set up a poll on here. I would like to see the results
  13. Nov 19, 2015 at 6:12 PM
    #53
    amkaos
    amkaos Well-Known Member
    The trunk button is to be set up for Windows option. Mine has all options..
    Incremental widows down, all the way down/ up..
    Temp start, interval start,
    Proximity sensor that can also operate window option
    Smart phone operation..
    Gps tracking, zone detection, lojack type feature..
    On and o on and on...
    All play nice together,,,,I really really like it
  14. Nov 21, 2015 at 2:44 PM
    #54
    Justinlhc
    Justinlhc Not looking for a relationship
    Most units also have a setting to pick how long the starter engages for. I'd opt for the tach mode so it cranks until it reads rpm.
  15. Nov 10, 2016 at 9:29 PM
    #55
    stlfun88
    stlfun88 Well-Known Member
    St Louis
    10 TRD
    Thank you for the info
  16. Jan 11, 2020 at 5:23 AM
    #56
    belrose
    belrose Active Member
    North end of Toledo Bend Lake
    2019 TRD Off Road
    3'' pro comp lift with pro comp wheels and 285/70/17 Toyo A/T II open country
    Are there any new opinions 2020 I just bought a 2010 tacoma for a hunting truck and was thinking about installing a remote start myself???!!!!
  17. Jan 14, 2020 at 2:00 PM
    #57
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    I have a viper (ds4) I think. Best Buy 279 installed. I had the same one on my 18 for 14 months, no issues good range
  18. Jan 14, 2020 at 2:03 PM
    #58
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Too many rules...
  19. Jan 29, 2020 at 6:22 AM
    #59
    mokman88
    mokman88 Member
    Robert
    253
    2017 Blue Tacoma TRD Sport
    Just had a guy quote me 339$ +tax to install remote start using my factory FOB. Said that since it’s push start, when I open the door the engine will cut off until I actually start it up.
  20. Jan 29, 2020 at 6:55 AM
    #60
    Fishnwiz
    Bill
    It does shut off. No way around it but mine usually times out but truck is cooled down or heated up
