Why the 5000 mile synthetic oil change interval?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TEEIAM, Jun 11, 2017.
  1. Jun 11, 2017 at 10:43 PM
    #41
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    Again I don't give a flying fuck what's "ok" if my vehicle consumes anywhere near 1qt per 1000 mi believe me the dealership will hate me so much that my truck will get a free 100k warranty or the more likely option would be another vehicle
    QChawks and Taco1999 like this.
  2. Jun 12, 2017 at 12:39 AM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't believe you. Many before you have attempted to hold GM's feet to the fire and have failed. As far as I know most vehicle manufacturers have this policy.
    jdg and TRDSport10 like this.
  3. Jun 12, 2017 at 12:44 AM
    #43
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    Because it's easier to tell people every 5k and not worry, perhaps? I assume you're talking about 2nd gen. Consider the engine tech is essentially a decade old. This whole 10k interval business wasn't around back when this engine first appeared.
    All in all, I can get a few 5qt jugs of Mobil 1 at wally world for $23 bucks when its on sale. That makes an entire synthetic oil change run me under $30 and 10 minutes of time in my garage. I'm happy to abide by the 5k recommendation.
    Sig45 likes this.
  4. Jun 12, 2017 at 1:38 AM
    #44
    09BlueBeast
    Cody
    Denver
    Well I owned a 4.8 2002 gmc truck and bitched enough until they gave me a 100k warranty on the motor for what I considered to be excessive lifter tap..... soooo yeah I'm willing to bet I'd get a free warranty or new car. If u can't finagle shit like that on something you know is a shit product then I'm sorry
  5. Jun 12, 2017 at 3:28 AM
    #45
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Ford does too. I had a 5.4 F150 that used one every 1500. Ford said gas long as it was north of 1000 there would do nothing.
  6. Jun 12, 2017 at 6:26 AM
    #46
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Back on the topic of TACOMAS....I'm with this guy, I run full synthetic (Mobile 1 Synthetic Extended Protection) for 10k miles. I change the filter every 5k miles and add half a quart during that change since you lose a lot to the old filter. The truck never really consumes oil even over a 10k interval. I bought a pack of 10 OEM filters a long time ago and only use those.
    jdg, TRDSport10 and Oey12[QUOTED] like this.
  7. Jun 12, 2017 at 6:48 AM
    #47
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yep, most owners who check the oil level frequently enough to notice consumption would probably take the practical route and just sell the vehicle.
    This. The carmakers are banking that the cost x probability of catalytic converter replacement within the emissions warranty period will be less.
  8. Jun 12, 2017 at 7:12 AM
    #48
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    He is correct. I know that both Ford and Subaru also state that 1qt per 1k is normal. Hence all the lawsuits for Subaru. The service manager wont tell you that, but their internal tech docs will.
  9. Jun 12, 2017 at 7:15 AM
    #49
    Taco1999
    Taco1999 Well-Known Member
    Jeremy
    Slidell, Louisiana
    2014 Tacoma Double cab 4x4 trd
    I read an article about a study that said extended oil change intervals were fine for the oil but carbon buildup in the oil contributed to premature timing chain wear in overhead cam engines because it is such a long run for the chain
  10. Jun 12, 2017 at 10:41 AM
    #50
    SilverBullet19
    Scott
    Sacramento County
    GM v8 engines are notoriously noisy, many complain it sounds like a sewing machine. It doesn't mean there's an issue with it, such as lifter tap. But hey, if it got you an extended warranty, more power to you.
    guys, manufacturers advise of oil consumption to avoid liability. Every engine goes through oil, whether its by burning it, return through the PVC, etc. As such, they will advise of consumption so that if you run it dry, they can say "I told you to check it." On top of that, back in the day engines tended to leak a lot more. They just leave the oil statement there, even if its exceptionally rare. My GTO doesn't burn oil at 122k, but it sure as hell says it can in the manual!
    Bottom line, it's still good to be checking the oil regularly, even if you don't see a puddle after you park...and especially after your warranty expires lol.
    I would believe this.
    It's amazing how many people want to avoid oil changes. It's cheap (even with synthetic if you're doing it yourself), and an excuse to hang out in the garage, have a beer, and do some wrenching. All good things, I honestly enjoy it.
    Taco1999[QUOTED] and Bebop like this.
  11. Jun 12, 2017 at 11:09 AM
    #51
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I followed this regime as well for many years, but decided it wasn't sufficient.
    I now change engine oil/filter every weekend using only Royal Purple Oil and Royal Purple Oil Filters. While changing oil, I also rotate the tires and change the air filter using a dealer air filter. Windshield wiper blades are also replaced each oil change.
    I change Transmission fluid once a month(filter too) using Royal Purple ATF and coolant every 3 months using Toyota SLL Coolant.
    Brake fluid, Differential Gear oil, Power Steering fluid are also changed every 3 months as well. Toyota Dot 3 is used for the brakes; Royal Purple is used for the differential and Dex-III for the P/S unit.
    Spark plugs are changed every 5K using Iridiums.
    I am presently considering swapping out the A/C Condenser and Evaporator every 6 months. If I go this route, I will also replace the dash each time I replace condenser/evaporator. I presently replace the A/C compressor once a year, but may start changing that component every 6 months.
    syswalla, TacomaMike37, Sig45 and 2 others like this.
  12. Jun 12, 2017 at 11:41 AM
    #52
    scocar
    scocar Patron of the Farts
    1. Hi, this is my first post in the Chevy forum.
    2. 3000 mile OIC are great if you wish to waste money and oil. IMHO, they are irresponsible on all counts.
    3. RTM
    4. Blackstone labs is your friend if (A) you'd like to work with facts pertinent to your specific vehicle and engine or (B) you wish to make it a lot harder than it is.
  13. Jun 12, 2017 at 11:56 AM
    #53
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    For the single VVT-i, Toyota's change interval is every 5K. For the dual VVT-i found on 4Runners and FJ's, the change interval is every 10K. I use synthetic and I still change every 5K. It's so simple in our trucks and cheap enough to do(under $30).
    BTW, 1qt of oil consumed between 900-1200 miles is acceptable per Toyota. They have a TSB out affecting certain years of their 4cyl 2AZ-FE engines found on a few of their models and if your car consumes a quart or less between those miles, it's "acceptable".
    SilverBullet19 likes this.
  14. Jun 12, 2017 at 2:40 PM
    #54
    El Cid
    El Cid Well-Known Member
    South Carolina
    11 Access Cab, 4 cyl, man., SR5
    Six months since last service on my 2011, 4 CYL. Checked a Toyota website and it said synthetic 0W20 is good for 10K or 12 months. Just to be sure I called Toyota since dealer insists it has to have synthetic at about $10 quart and six month changes. Rep. took the party line and said my vehicle came with synthetic and if Maint. Man. says change every six months, that is what it means. Also stated that only certain engines are "certified" for 10K/12mos. Mine isn't certified, whatever that means.
    Nowhere in my Owners Manual or Maintenance Manual does it state synthetic oil is required, only that it be 0W20. Does 0W20 only come in synthetic?
    I put about 500 easy miles on my Tacoma every six months. Checked the oil and it is full on the stick and as clear as new oil.
    I have a 2010 M-B and it uses synthetic oil and manual states 10K or 12 months. Dipstick checked every couple of months since it always reads full.
    Get it serviced once a year and dealer is happy with that.
  15. Jun 12, 2017 at 2:42 PM
    #55
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I had a '07Camry with the 2AZ that used a quart in 3300miles, drove me crazy, but i knew it was considered "acceptable". that sole thing made me glad the car was totaled @ 72k, i liked the car, but having to babysit a vehicle like that makes me crazy. I've NEVER had one use oil like that before.
    Both my '08 DCSB and my '97 4Runner have over 200k, neither use oil at a rate that is noticeable when checking every week. my '11 Camry SE never used a drop either when we had it.
  16. Jun 12, 2017 at 3:36 PM
    #56
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Because it makes them more money. Thats the only reason for the maintinence schedules.
    scocar likes this.
  17. Jun 12, 2017 at 3:43 PM
    #57
    scocar
    Who said PT Barnum is dead?
  18. Jun 12, 2017 at 7:31 PM
    #58
    Jimmyh
    SC
    2012 Prerunner SR5
    What ever there chief. I still don't believe it. ;)
  19. Jun 12, 2017 at 7:48 PM
    #59
    09BlueBeast
    Cody
    Denver
    Dislike
    believe what you want... truth is truth
  20. Jun 13, 2017 at 5:00 AM
    #60
    Taco1999
    Jeremy
    Slidell, Louisiana
    My wife's bmw535i has 10,000 mile change intervals. It burns about 1 quart between changes. I don't think that's too bad for a turbo engine with 139,000 miles. My taco 4.0 gets changed every 5,000. It doesn't burn any oil.
