Why the auto LSD on a 4x4? (non OR)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jv_74, Dec 13, 2018.
  1. Dec 14, 2018 at 5:22 PM
    #41
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Auto LSD is a stronger limited slip than the standard TRAC and easily turns on. Use it any time the truck doesn't move ahead from a stop.
    The rear locker is for emergency only. If Auto LSD doesn't move you, then the locker is there, since you don't have 4WD.
    CaTaco101 likes this.
  2. Dec 17, 2018 at 5:29 PM
    #42
    My White Tacoma
    My White Tacoma Well-Known Member
    Andrew
    Springfield, mo
    2014 White Tacoma double cab, SR5, 4x4
    Thanks David and everyone for the info. I tried reading the manual to get some better understanding. But came away more confused. lol I'm still confused how TRAC OFF = More traction control/stronger LSD with no throttle control, but I'm not a Toyota engineer.
  3. Dec 18, 2018 at 8:40 AM
    #43
    David K
    Crazy, right?
    Trac Off is just a poor name choice because Trac is not off, the engine regulation/cut is turned off. This means no restriction on power going to the traction tire while brakes hold the spinning tire.
    JGO and Sprig like this.
  4. Dec 19, 2018 at 8:14 AM
    #44
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Best explanation and description ever! Thank You!
    David K[QUOTED] likes this.
