why truck sags with a load in back?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amocat21, Dec 4, 2014.
  1. Dec 4, 2014 at 10:03 AM
    amocat21
    amocat21 [OP] Active Member
    2012 6 cylinder 4x4
    Being I got the base line entry level model that is no frills I noticed when I put a good load of something in the back that it sags easy. Can I up-grade the rear suspension
  2. Dec 4, 2014 at 10:04 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Because the leaf springs are garbage
    Yes , lots of upgrade options
  3. Dec 4, 2014 at 10:07 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Groundhog day.
  4. Dec 4, 2014 at 10:14 AM
    cgs2k2
    cgs2k2 old man
    the stock leaf springs are notoriously weak. you can add a leaf or replace the entire assembly for better hauling.
  5. Dec 4, 2014 at 10:14 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    ^^^this
    AAL
    or
    Air Bags
    or
    Helper Springs
    lots of threads on all
  6. Dec 4, 2014 at 10:29 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    ^^^ Pretty much summons it up :thumbsup:
  7. Dec 4, 2014 at 10:43 AM
    amocat21
    2012 6 cylinder 4x4
    I'll assume adding a leaf is the cheapest way, but Is it a hard process?
  8. Dec 4, 2014 at 10:47 AM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
  9. Dec 4, 2014 at 10:48 AM
    OZ-T
    Peter North
    British Columbia
    Just get a the Wheelers HD leaf pack and pull a leaf if you want to stay at stock height but with better load carrying characteristics
  10. Dec 4, 2014 at 10:59 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    stock packs are designed as a compromise. I just put on a topper. with full tank and bed loaded it rides on bump stops. going with Dakars, because Beavis said so.
  11. Dec 4, 2014 at 11:03 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    Dakars with Camper [​IMG]
  12. Dec 4, 2014 at 11:17 AM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Absolutely love my OME Dakars. I got the constant load packs too and they are smooth as butter. I work my truck on shitty rutted out washboard dirt roads all day every day and I love how much better they ride. Not to mention the lift I got from them. My stockers bottomed out on everything. I couldn't believe how shitty the factory springs were when I changed em out.
  13. Dec 4, 2014 at 11:18 AM
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    mine with topper. no load. half tank. sits level and rides fine. loaded is another story. as i said, stock is a compromise. going Dakars. At least loaded it handles fine
  14. Dec 4, 2014 at 11:18 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Had the leaf spring TSB done when I had my 2011. The stock leafs are pathetic in 2nd gens, more than 300# in the back and you are hitting the bump stops. TSB solved all my issues, no more squeaky sounds, slightly stiffer ride, but could hold anything I put in the bed without complaining. Including a 700lb four-wheeler plus a few more hundred pounds of camping gear.
  15. Dec 4, 2014 at 11:19 AM
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    Beavised
  16. Dec 4, 2014 at 11:20 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Dakars FTW!!!! Dakars and Timbrens for even more WIN!!
  17. Dec 4, 2014 at 11:23 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  18. Dec 4, 2014 at 11:35 AM
    OZ-T
    Peter North
    British Columbia
    Smooth as butter and Dakars do not belong in the same sentence .
  19. Dec 4, 2014 at 2:42 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    Ha ha. Compared to banging off the frame. BUTTERY SMOOOOOOTH
  20. Dec 4, 2014 at 2:55 PM
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    My Taco was sagging way too much with 900 lbs in the bed. Not anymore! I added Dakars + D29XL extra leaf + airbags, couldn't be happier.
