why when i disconnect the battery the motor whant's to dye
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rcoronado, Aug 8, 2013.
Thread Status:
Not open for further replies.
  1. Aug 8, 2013 at 8:38 PM
    #41
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    computer relearns the idle maybe??
  2. Aug 8, 2013 at 8:38 PM
    #42
    TailDrag
    TailDrag Well-Known Member
    Anybody think for a second this is a real person with a real question who might not speak english well?
    Kinda lame.
  3. Aug 8, 2013 at 8:38 PM
    #43
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    :cool:
    FU cowboy!
  4. Aug 8, 2013 at 8:38 PM
    #44
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    Ha ha ha. Lmao!!!! This is some funny shit..
  5. Aug 8, 2013 at 8:39 PM
    #45
    cbRC4x4sr5
    cbRC4x4sr5 Well-Known Member
    lewisburg ohio
    2010 mgm reg cab sr5 4x4
    front 5100's set to 2.5", rear 5100's + Add-A-leaf kit, class 3 hitch, yellow wire mod, ventvisors, volant cai, diff breather mod, ranger rci 6900 cb, custom exhaust with magnaflow muffler, hella micro ff fogs, ridgid dually leds
    Just to let everyone know, disconnecting the battery while the engine is running on any vehicle that has a computer controlled can damage the computers on almost all modern vehicles.
  6. Aug 8, 2013 at 8:41 PM
    #46
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    You know swearing at someone makes you seem less intelligent to others? It shows lack of maturity and little comprehension of the English language.
  7. Aug 8, 2013 at 8:42 PM
    #47
    jw1983
    Alberta
    When he disconnects the battery, does it not reset the ECU? So the ECU would have to relearn everything?
  8. Aug 8, 2013 at 8:43 PM
    #48
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Reported
  9. Aug 8, 2013 at 8:43 PM
    #49
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Hey are you part of CT4wd? Ive been meaning to get over to Calgary and do a trail run with those guys.
  10. Aug 8, 2013 at 8:43 PM
    #50
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    But in all seriousness OP........you have to unplug the battery when the truck is off.....when you plug it back and turn the truck on, the truck will turn off almost immediatly after you turn it on........when you turn it back on it should run normally...........THE TRUCK HAS TO BE OFF BEFORE YOU UNPLUG THE BATTERY.
  11. Aug 8, 2013 at 8:45 PM
    #51
    cbRC4x4sr5
    lewisburg ohio
    The problem is it causes a voltage spike to the entire electrical system.
  12. Aug 8, 2013 at 8:46 PM
    #52
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
  13. Aug 8, 2013 at 8:47 PM
    #53
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    :rofl: sucks to suck!
  14. Aug 8, 2013 at 8:47 PM
    #54
    jw1983
    Alberta
    So like a power surge?
  15. Aug 8, 2013 at 8:49 PM
    #55
    cbRC4x4sr5
    lewisburg ohio
    yep
  16. Aug 8, 2013 at 8:49 PM
    #56
    Commie
    Commie Well-Known Member
    G
    Hanford, CA
    TRD Off-Road
    SCS F-5 Black with BFG AT 265/75/16, 2.0 Radfls's w/ top plate, LR UCAs, TSB springs w/ 5160, rear diff breather, blacked out grill/ emblems/ rear bumper/ lower valance, LED map/ dome/ lic plate lights, switchback DTRLs, anytime fogs, WeatherTech DigitalFit liners
    Normally I would stay out of cluster f%@$ed threads like this, however, I'm pretty sure I know what the OP is trying to say since the same thing has happened on my 2011 4.0 before. I have only disconnected my battery a few times while working on electrical stuff. After I plug it back in and go to start the truck up, it will fire up for a second then die on me. Then every start after that is completely normal. I never though of this as a real concern because mine has a dealer installed aftermarket alarm and I just figured it had something to do with the immobilizer. Pretty sure this is what the OP is talking about. If anybody has a better answer, then by all means, lets hear it
  17. Aug 8, 2013 at 8:52 PM
    #57
    jw1983
    Alberta
    A lot of members are trying to figure it out. Some of us are having more fun with it though. We're just trying to make sense of it.
  18. Aug 8, 2013 at 8:53 PM
    #58
    somethinboutayota
    Parker
    Dodge City, Kansas
    Here let me translate-
    Fo real dawg... when yo whip is dead you have to take da thingy off da batttry... when home dawg plugs the battery back in and you hotwire the truck with yo prizon shank, da trck diez asap after you crank it... when ya hotwires it it should run like a bro in da hood...... YO LOW RIDDA GOTTS TA BE OFF BEFORE YOU UNPLUG THE BATT.
  19. Aug 8, 2013 at 8:54 PM
    #59
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    The fuck is going on in here?
  20. Aug 8, 2013 at 8:57 PM
    #60
    jw1983
    Alberta
    I hope that the OP doesn't have the truck running and disconnects the positive terminal first.
    Currently Active Users Viewing This Thread: 58 (30 members and 28 guests)
Thread Status:
