Why will my truck not turn off?
Discussion in 'Technical Chat' started by holyfield19, Nov 14, 2016.
  1. Nov 14, 2016 at 3:23 AM
    holyfield19
    holyfield19 [OP] GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    This has happened several times over the last few months.
    2006 Sport, 4.0, 6 speed MT.
    When I get to my destination and go to turn the truck off, it will not shut off. I can turn the key off and it continues to run. If I choke it out, the engine will stop, but the gauges do not turn off (as if it is in the ACC position).
    It will take several attempts to get the truck to shut down completely.
  2. Nov 14, 2016 at 3:32 AM
    perpetualenigma3
    perpetualenigma3 Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    Do you have a portable charger pluged in to your 12V? I had a similar issue with a portable charger, that was back feeding the ECU and making the ECU think the truck was on so my ACC remained on. I have a push button start so it might be different in your case. It might be a bad cylinder in your case. Just sharing my experience.
  3. Nov 14, 2016 at 3:34 AM
    Tacomaman87
    Tacomaman87 Well-Known Member
    Garrett
    Maine
    05 DCLB 4x4 trd sport
    Allpro expo's soft topper 255 80 17 St Maxx
    Sounds like a bad ignition switch. I assume you mess around with the key and it finally shuts down?
    12TRDTacoma likes this.
  4. Nov 14, 2016 at 3:35 AM
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Read a similar story a while back online and this was the guys remedy .. not saying it will fix yours but just putting it out there
    Well, I finally figured it out. It was a bad rectifier in the alternator, probably caused by a loose battery cable. Apparently only one of the diodes in the trio was shorted out so it was still charging, just not as efficiently, I never got a charge light on the dash either. Not only did the short kill the battery overnite, in a running condition it was back feeding power to the ignition circuit causing the engine to continue running after the key was shut off. Crazy....
    After a quick alternator rebuild the car is as good as new.
  5. Nov 14, 2016 at 4:06 AM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    I did have a cell phone charger in for a little while. It quit working and I figured it just died.
    Yes. Off, on, off, on, off. Takes a few tries to get it to finally go off.
    I may start here.
  6. Nov 14, 2016 at 6:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like the ignition switch to me
  7. Nov 15, 2016 at 7:56 AM
    Tacomaman87
    Garrett
    Maine
    Did you find the problem?
  8. Nov 15, 2016 at 7:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Bad ign switch is my assumption as well.
  9. Nov 15, 2016 at 8:36 AM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Didn't have time last night to fool with it. I think first thing I am going to check are the relays.
    When I drove home yesterday it cut off like it should. When I drove to work this morning, I had to f@#k with it to get it shut down.
