Why won’t my drive shaft slide onto the transmission shaft?
Discussion in 'Technical Chat' started by Dustin W, May 25, 2024.
  1. May 25, 2024 at 7:42 AM
    Dustin W
    Dustin W [OP] New Member
    Dustin
    2005 Toyota Tacoma
    Installing drive shaft on 2005 Tacoma why won’t my drive shaft the yolk slide into place on the transmission shaft. Can anyone help me?
  2. May 25, 2024 at 7:49 AM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Hey welcome!! Lots of help here. Attach some pics and someone will be around soon
    Stevie17 likes this.
  3. May 25, 2024 at 7:57 AM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    2nd this , throw up some pictures of the problem and someone else here has probably had the same problem at 1 time or another.
  4. May 26, 2024 at 4:43 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Take a look at your splines on the drive shaft yoke, there is a double spline that has been filled from the factory. Now take a look at the splines on the out put shaft form the trans. There is a double gap on a section of the splines. Those need to be lined up for the shaft to slide on.
    I'm assuming everything else is correct here in terms of the correct drive shaft, angles and positioning.
    I go over it here in this video. Go to the 6:53 mark.
    https://youtu.be/iwRwOmmgdcQ?si=6x9Ku-3NcuGv8rzY
    MR5X5 likes this.
