Why won't the gears fit
Discussion in '4 Cylinder' started by eclipse22, Feb 8, 2015.
  1. Feb 8, 2015 at 4:58 PM
    eclipse22
    eclipse22 [OP] Well-Known Member
    Marcin
    I've been looking to regear my 2.7 2006 tacoma auto to 4.10 gears but have been told that you need a third member. Why can't I just buy 4.10 gears front Detroit for a 7.5"? I got a spartan locker going in next week.
  2. Feb 10, 2015 at 8:47 PM
    eclipse22
    Marcin
    anyone?:(
  3. Feb 10, 2015 at 8:49 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Need a little more info but the 7.5" is the TRD locker size. The non-locker are 8" ring gear in a 8.4" housing.
    If you go to somewhere like eastcoastgearsupply.com they have a diff wizard that will spit out what parts fit in what years and what diffs
    But really, you should talk to ECGS or randys ring & pinion for their expert advice.
  4. Feb 19, 2015 at 12:45 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    From what I understand, installing gears is not for the shade tree mechanic - hence the 3rd member... Simply pull the axles and remove the third member and swap in the regeared 3rd member - so easy even I could do that!
    In my case, a TTORA member 'gave' me his spare 3rd member which I sent out to be regeared. When I got it back I swapped the new for the old and gave the spare back to him...
    X2 on contacting ECGS or any other forum sponsoring companies..
