Why would I want super bright front turn signal bulbs?
Discussion in 'Lighting' started by Ruminator, Sep 11, 2020.
  1. Sep 14, 2020 at 8:02 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Thanks!
    They are actually 10ohm. After alll my testing this resistance proved to be the best app around.
  2. Sep 14, 2020 at 8:03 AM
    Ruminator
    Ruminator [OP] Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    :thumbsup: Thanks again. I post some photos in one of these threads when I get a chance.
    MESO[QUOTED] likes this.
  3. Oct 4, 2020 at 5:19 AM
    FloridaSon
    FloridaSon Well-Known Member
    White SR Gen 3
    @MESO
    Does the 10 ohm resister reduce the light output?
    Thx
  4. Oct 4, 2020 at 6:31 AM
    Ruminator
    Mark
    Why are you shouting?
    No, the resistors go in parallel with the rear turn/reverse leds and increases the amount of current drawn through the blinker circuit so it doesn't think there's a burned out bulb. The amount of light is the same.
    ...but, as I noted in this other thread, the MESO resistor packs didn't solve my hyperflash problem either. I'm currently waiting on a pair of front turn leds from VLEDS that another member says work with no hyperflash with the Stage 1 kit. We'll see. I may be using those resistor packs yet.
  5. Oct 4, 2020 at 6:48 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Here's what I think I've noticed. OEM incandescent, halogen or what ever the non LED signal bulbs are. Those are brighter or at least more noticeable during daylight. Aftermarket LED signal bulbs are more easily noticed in the dark than they are in daylight. I can't tell if LED is actually brighter in the dark, but they are definitely less noticeable in the day. No idea what aftermarket bulbs I've seen other people use. I'm using the front amber turn signal as a reference, and no particular vehicle.
    waterlogged77 and FloridaSon like this.
  6. Oct 4, 2020 at 7:58 AM
    FloridaSon
    White SR Gen 3
    haha, shouting is all caps. When I copied MESO it brought along the bold and I typed it in bold.
    That makes sense. Thanks for the explanation.
    Regards
