WHY?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by willard417, Oct 26, 2010.
  1. Oct 26, 2010 at 1:16 PM
    willard417
    willard417 [OP] Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    Why do i only have driveline vibrations when it's cold outside? it rides perfect when its above 60 F.
  2. Oct 26, 2010 at 1:26 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    metals contract when its cold
  3. Oct 26, 2010 at 1:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I think your truck is just shivering....
  4. Oct 26, 2010 at 1:30 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    x2
  5. Oct 26, 2010 at 1:31 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    x1000
  6. Oct 26, 2010 at 1:31 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    turn the heat on....... is it in the s/wheel or the truck?
  7. Oct 26, 2010 at 1:31 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Its your truck telling you to move somewhere warmer...or metal contracting...one of the two.
  8. Oct 26, 2010 at 2:26 PM
    SubFrozen
    SubFrozen r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    I think its you shivering and blaming the truck
  9. Oct 26, 2010 at 2:39 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Turn the stereo up....you'll never notice.
    Seriously.... Are you absolutely sure that its driveline vibrations?
    Because - we don't have the whole story and it could be a variety of different things that pop up. Need more info.
  10. Oct 26, 2010 at 3:30 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I hear ya. Mine was great up until it got cold here this weekend. I had a tiny bit of take off shudder, but that was at 15-20 degrees C, now it's 0 and below, and I have a bit of vibe at 60 km/h...don't get it?!
  11. Oct 26, 2010 at 4:29 PM
    willard417
    Luke
    beaver county, PA
    well you can hear it and feel it vibrate. it's not a steady vibration its a pattern and it starts right away and you can't feel it after about 60mph. and i'm not talking about freezing weather i'm talking about 50s.
  12. Oct 27, 2010 at 3:59 AM
    Janster
    Jandy
    Lancaster, PA
    Ok....that doesn't tell me anything. You gotta give us more information. Driveline vibes that I refer as - don't just show up because the weather is bad or cold.
    When was the last time you lubricated your u-joints?
    Did you check your tires to make sure you didn't lose a wheel weight?
    Rotate your tires and see if the vibration changes feel or location.
  13. Oct 27, 2010 at 11:55 AM
    willard417
    Luke
    beaver county, PA
    Just changed all the fluids (front end, rear end, tansfer case)
    to see if that was the problem. Also greased all the fitting available
    No fix. It's not a wheel weight be cause it only does it
    Below 60F. So I'm pretty sure that a balance/rotate wouldn't
    Give me better results either. The feeling is coming from the
    Front and you can just barely feel it in the steering wheel.
    I'm not sure if it would be the oil I use in the f/e t/c r/e.
  14. Oct 27, 2010 at 11:57 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    it's probably just your tires, does it go away after you drive it awhile (tires heat up)?
    mine does it when my tires are cold
  15. Oct 27, 2010 at 1:55 PM
    Janster
    Jandy
    Lancaster, PA
    Vibrations are funny things and they develope rythms at certain speeds/rpm's. So, just because it happens below 60mph, doesn't mean you can rule out your tires.
    I still think you should rotate your tires to see if the vibration changes FEEL.
    Now that you mention the steering wheel....that could be a ton of other things.
    What happens when you step on the brake?
    Have you tried putting it in 4WD? Do the vibrations change? Get worse or go away completely?
