WHY???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stmpjmpr, Jun 19, 2019.
  1. Jun 19, 2019 at 12:03 PM
    stmpjmpr
    stmpjmpr [OP] Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Hello
    I have a 2014 V6 Sport.Ha 101k miles. Dis tune-up. cleaned MAF/TB, replaced PCV valeve, now it seems to be having a problem I cant figure out. from a stop, give it gas, feel slight hesitation, finally start going. floor it. works ok. but sometimes while on the fwy it will start stuttering, I slow down and it clears. Have switched gas, still no difference, no lights or codes come up. HELP!!!!!!!!!!!!!!!
  2. Jun 19, 2019 at 12:11 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Plugged cat? Faulty coolant temp sensor or CPS? Does yours have a replaceable fuel filter? If so, has it been replaced?
  3. Jun 19, 2019 at 12:12 PM
    Spud2010
    Spud2010 Member
    Z
    2010 White TRD OR DCSB
    Did you disconnect your battery prior to cleaning your MAF?
    outlawtacoma likes this.
  4. Jun 19, 2019 at 12:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check all the vacuum lines, make sure one didnt slip off
  5. Jun 19, 2019 at 4:32 PM
    stmpjmpr
    Jimmy
    I don’t think I have replaceable fuel filter. What’s CPS?
  6. Jun 19, 2019 at 4:32 PM
    stmpjmpr
    Jimmy
    Yes sir I did. Done twice.
  7. Jun 19, 2019 at 6:24 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    One of the coils may be about to go out. I have had those malfunction without throwing any codes on other trucks i have had. Same symptoms. Does it stutter on a hard stop? Like a misfire? How about when it is idling?
  8. Jun 19, 2019 at 8:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like a vacuum line is off.
  9. Jun 22, 2019 at 2:28 PM
    stmpjmpr
    Jimmy
    No sir. It’s smooth when idling
  10. Jun 22, 2019 at 4:41 PM
    FishingPups
    Barry
    Some of the other folks mentioned a vacuum line. Good advice. I'd look to that first if I were you then. Some mechanics have a smoke machine that they can plug up to your vacuum system, if there is a leak or a hose off they will find it pretty quick
  11. Jun 22, 2019 at 4:44 PM
    Bishop84
    Bishop84 Well-Known Member
    Yup, I'd say the vacuum line at the back of the intake box is off.
  12. Jun 22, 2019 at 4:56 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Camshaft position sensor
  13. Jun 22, 2019 at 5:45 PM
    FishingPups
    Barry
    Or that too is a possibility. Have you had cranking problems?
  14. Jun 22, 2019 at 6:01 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    I choose not to answer this question. Haha (no)
    FishingPups[QUOTED] likes this.
  15. Jun 22, 2019 at 6:07 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    What is "Dis tune up"?
  16. Jun 22, 2019 at 6:08 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How old is the battery & alt? Take a voltage reading, should see ~14 volts when charging. ~12 with truck off.
  17. Jun 22, 2019 at 6:10 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    TB gasket in good shape?
  18. Jun 23, 2019 at 5:58 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Problems that occur after fixing something are usually due to something the mechanic did or didn't do and rarely because of a new problem. I would bet back-tracking will reveal the problem. What did you clean the MAF with? Make sure the vacuum line to the Fuel Pressure Regulator is attached and not cracked. Did your PCV valve rattle when you installed it? The rattle indicates the valve is working and isn't a defective new part.
    Taco'09 and Jimmyh like this.
  19. Jul 8, 2019 at 12:54 PM
    stmpjmpr
    Jimmy
    I will tell you WHY???? I purchased OEM plugs from Amazon. Decided to replace with plugs purchased from dealer. problem fixed. turns out plugs from Amazon even though were OEM, the heads were small. contact with coils were not solid, replaced with Dealer plugs, I could feel the difference in how much better it seated, runs great again. Thanks for all the good advice.
  20. Jul 8, 2019 at 1:03 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Amazon has some platinum plug scams going on.
    Friend had a set that were fake and engine ran rough.
