Wicked big brakes for 17" wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Aug 6, 2020.
  1. Aug 6, 2020 at 4:52 PM
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    This may finally be it, at least for this taco... more brake rotor and caliper than any 17" wheel should have to swallow. And leave it to the OEMs to have come up with the parts, Brembo and Porsche. When these popped up on my radar some years back, I knew a set would have to be placed into some project... that time has come.
    The calipers are massive cast mono block aluminum and forged steel units that hold six 36mm pistons. The total squeeze area should play nice with the Tacoma. The main caliper body is aluminum, and is specially designed to sneak larger brakes into regular sized wheels. The main bridge is cast right in place, a feature that is becoming more common in high performance apps. Being thin in the areas that are critical to reducing flex, created, well, flex! So Brembo added a trick additional forged steel bridge that bolts around the main assembly, it is incorporated into the mounting bracket.
    There's more to come, but for now, here's a 360 x 36mm rotor stuffed into a large barrel TRD 17" forged wheel, it has room to spare.
    Massive pads! Double the size of stock.
    This buggy is going to stop.
  2. Aug 6, 2020 at 4:56 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  3. Aug 6, 2020 at 4:57 PM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    Approximate cost?
    Jowett[OP] likes this.
  4. Aug 6, 2020 at 5:01 PM
    Jowett
    Brian
    North Adams, MA
    Why? TVS1900 and heavy real world use.
    Calipers are $1050 for a pair, new. Pads $50 and up. Rotor and hat cost is up in the air, as it will be custom with bolt on hat. Also adapter is unknown.
    STrooper and uurx like this.
  5. Aug 6, 2020 at 5:04 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    lol subd :popcorn: this the rotor size on my macan, you get these calipers off a cayenne??
  6. Aug 6, 2020 at 5:06 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Stoptech already makes 6piston calipers for Tacos.
    And .. 20% off for TW.
  7. Aug 6, 2020 at 5:09 PM
    uurx
    '12 t|x pro
    well technically this is a bigger big brake kit... 360mm > 355mm lol
  8. Aug 6, 2020 at 5:10 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Correct me if I'm wrong, but won't this just cause your tires to stop and you continue going?
    No offense intended.
    Seems cool though.
  9. Aug 6, 2020 at 5:20 PM
    Plain Jane Taco
    USA
    What about the rear brakes?
    Junkhead, Jowett[QUOTED][OP] and uurx like this.
  10. Aug 6, 2020 at 5:21 PM
    LoveableWerewolf
    Nashville
    Im guessing axle swap?
    Porche brakes would sick though
  11. Aug 6, 2020 at 5:23 PM
    uurx
    '12 t|x pro
    hopefully retrofit the rear 4 pots off the same porsche... :cheers:
  12. Aug 6, 2020 at 5:23 PM
    LoveableWerewolf
    Nashville
    4 hours till friday
  13. Aug 6, 2020 at 5:31 PM
    Jowett
    Brian
    North Adams, MA
    Nice catch. Calipers 08 Cayenne Turbo w/ 18" wheels. One year only in this country. Rotors are Macan.
    Rear brakes will likely be from the same vehicle.
    I have various Stoptech Toyota kits on the shelf, this will offer more capacity and... I like to do my own thing.
    The idea isn't necessarily to stop the vehicle sooner, but to allow repeated heavy applications. No offense taken.
  14. Aug 6, 2020 at 5:31 PM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Any mods to the brake master cylinder required? Proportioning valves etc.?
  15. Aug 6, 2020 at 5:31 PM
    Jowett
    Brian
    North Adams, MA
    The rear axle will likely be a Toyota Tundra 9.5".
    STrooper likes this.
  16. Aug 6, 2020 at 5:34 PM
    LoveableWerewolf
    Nashville
    Ah, wow that gonna work awesome for heavy applications! Gonna be a ton of work to make it fit. Getting stance is interesting me to because the track width is so much wider on the tundra. Good luck!
  17. Aug 6, 2020 at 5:37 PM
    Jowett
    Brian
    North Adams, MA
    These calipers have 6% less piston area than stock, so the master can handle it. If more is required, there are bolt on solutions. Balancing the system will require studying other systems, both OEM and aftermarket.
    The Tundra axle will be narrowed.
    STrooper, uurx and LoveableWerewolf like this.
  18. Aug 6, 2020 at 5:43 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Are you racin'?
  19. Aug 6, 2020 at 5:48 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Because it’s obviously a race truck
  20. Aug 6, 2020 at 5:49 PM
    Jowett
    Brian
    North Adams, MA
    No, I just like as much brake as possible.... occasionally will being towing near max cap.
