Wide Angle Lens
Discussion in 'Photography' started by sammy87, Aug 10, 2010.
  1. Aug 10, 2010 at 7:46 AM
    sammy87
    sammy87 [OP] Well-Known Member
    co
    10 TRD SPORT 4X4
    So I have my camera now, I'm learning the features trying to take better shots. I'm going to the SW in Sept and was wanting to take some sweet pics of the national parks. What type of Lens should I use? I've read that wide angle is the best for landscape pics. Are there anyone recommends for a Canon?
  2. Aug 10, 2010 at 7:55 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Ive used a fisheye lense before and it was cool but I wouldnt use it for "serious" photography. I have a canon that has a panoramic setting that lets me connect several pictures together.
    they have been resized kinda small but you get the idea. I think it was called photo "switch" or "stitch" not for sure but it was on a canon camera
    5960_1084075274923_1617615273_259898_633_b903db8b0ceec8eb37b561f3b99730a61df1dabf.jpg
  3. Aug 10, 2010 at 7:58 AM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    I have a 12-24mm Wide angle that I use and it works great. The bad thing about it ...It cost $1000
  4. Aug 10, 2010 at 8:07 AM
    capslockd
    capslockd Member
    Jeremy
    Topeka, KS
    08 AC TRD Off Road
    I've got a Sigma 10-20mm for Canon. I'm happy with it, but by no means a professional. In my opinion, you're better off stitching photos together to make a pano of a landscape unless you simply can't get back far enough to capture what you want/need.
    Personally, I'd stay away from a fisheye. But then, there's a million opinions on this, and you get what you pay for with all (ok, nearly all) lenses.
    www.dpreview.com
  5. Aug 10, 2010 at 8:34 AM
    sammy87
    co
    10 TRD SPORT 4X4
    $1000 is a bit out of my budget. Canon has Wide Angle in the $300-$600 range I was looking at.
  6. Aug 10, 2010 at 8:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    the two that I posted were just stitched together.
  7. Aug 10, 2010 at 10:39 AM
    sammy87
    co
    10 TRD SPORT 4X4
    Those look pretty cool actually. Ill learn more about my camera in the next few weeks and learn what the capabilities are.
  8. Aug 10, 2010 at 12:02 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    when I got my camera I would take my owners manual with me to work to read through when I wasnt busy. It helped learn all the functions. practice at home so when you get to where your going you wont have to fumble around with the settings to get cool shots.
  9. Aug 10, 2010 at 12:09 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    sigma 10-20 is a pretty good lens and for around $500 its not to expensive. One of the better wide angles your going to find without spending big $$$
  10. Aug 10, 2010 at 12:15 PM
    madisonsfinest
    madisonsfinest Addicted to my DSLR
    Madison, WI
    2010 DC OffRoad 4x4 Debaged
    Factory Roof Rack Avid Offroad Light Bar 16" XD Hoss Truxedo LoPro QT Window Tint Autobot Emblem w/Autobot Shifter Color Matched Grille
    go to flickriver if you have a flickr account. you can always start one. flickriver allows you to look at pictures taken with different lenses. Its pretty awesome. Let me see if I can link it here. Ok check out this link: http://flickriver.com/lenses/canon/
    This is for the Canon lenses but they have other manufacturers on there. Let me know what you think. If you had the money, the Canon EF 24-70mm f/2.8L USM lens is a pretty sick lens. But in your price range you could look at this one: http://www.adorama.com/CA2428AFU.html ....Like I said you can check out the work on a lot of these lenses on the first link. Good Luck. I'm pretty excited as I have the 18-135mm lens coming in tomorrow!
  11. Aug 10, 2010 at 3:14 PM
    capslockd
    capslockd Member
    Jeremy
    Topeka, KS
    08 AC TRD Off Road
    those do look pretty good. you just use the camera software to stitch 'em? i like autopano and it's really not that expensive. for you and OP, you can check out some of my panos here, but some of them are huge so beware... http://tinyurl.com/28u2og8
  12. Aug 10, 2010 at 3:18 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
  13. Aug 12, 2010 at 8:53 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    3" lift, custom rims, snug top shell, shrockworks bumper, warn winch.
    The Canon 10-22 is a pretty good lens and if the body you want to put it on does support it, I'd suggest that over many other things. Good value for the money.
    I have an IR converted Rebel that I use the 10-22 on almost exclusively.
    If you are shooting landscapes, you can always make panos and use almost any lens to get the WA effect.
    Here's an example of that.
    This was shot with an SD780 and is three or four frames stitched together.
    Here is a shot taken with the 10-22:
  14. Aug 13, 2010 at 6:16 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yea my canon had a setting that would show two frames. I would take one picture and it would show up in the first frame and show my next shot in the next frame. I could essentially take a 360 degree photo just by lining up my shot with the last one i took in the side by side view
  15. Aug 13, 2010 at 6:34 AM
    iSTIZO99
    Jax, FL
    Don't see your examples...forgot to attach?
    What Canon model was this?
  16. Aug 13, 2010 at 8:39 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    They are there and the gallery permissions are open enough to read so there shouldn't be problems (they are links, not attachments).
  17. Aug 13, 2010 at 1:47 PM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    There is a big difference between a panoramic shot, and a wide angle shot, you have to decide what it is that you are after. And Wide angle has been used by a lot of professionals... :) Nikon and Canon don't make "Panoramic" lenses they have Wide Angle (aka "Fisheye") lenses
  18. Aug 13, 2010 at 2:14 PM
    iSTIZO99
    Jax, FL
    Yea I see them now...for some reason it wasn't working for me when I was looking at it the first time.
  19. Aug 13, 2010 at 2:17 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Technically, you can make a panorama with any lens. You need to know and rotate the camera around that lenses nodal point for the near focus stuff to line up correctly. For panos that will be shot at near infinity, the nodal point does not matter as much.
    With regard to WA, a fisheye is at the extreme end. If you spend the dough, you can get something like the Canon 14mm which doesn't have near the same level of distortion as say the Canon 15mm.
    I think the biggest thing you want to remember with WA and Ultra Wide Angle is that they are not suited for making landscape shots--at least not sweeping all-encompassing vistas. If you do that, all you'll have is a bunch of tiny stuff in the picture. But if you get all up close and personal, you'll get some cool stuff. Like this:
    This was shot with a Canon 15mm fisheye. I was a few inches away from the poppies.
    HTH
  20. Aug 13, 2010 at 2:26 PM
    iSTIZO99
    Jax, FL
    So basically what you're saying is that a dedicated WA lens (fisheye) is pretty much "gimmicky"? Not saying that it's a cheap or crappy lens, but that its use is rather limited...kind of like a macro lens?
