wide tire rock chips
Discussion in 'Wheels & Tires' started by VTYoda, Feb 5, 2021.
  1. Feb 5, 2021 at 8:33 AM
    VTYoda
    VTYoda [OP] Member
    Nick
    2008 Black Tacoma AC
    TRD Off Road Suspension 1.5" front lift Rear Icon RXT leaf pack Falken Wildpeak AT3W 265/70/17 AR172 Wheels 17x8 0mm offset ECGS needle bearing replacement Leer camper shell Camping platform Ditch lights Front bumper hidden light bar Aftermarket tow hitch Sony Double Din D-ring bed tie downs All in one switch blade key fob
    Somewhat new here and looking for some solutions to the rock chips caused by having wider tires/offset. I am running 265/70/17s with basically no lift and minimal trimming.
    Ive seen guys put wider mud flaps on but i am afraid they will make the fronts rub as im not running any mud flaps at the moment. Also, thought about clear protection film... any other ideas?
  2. Feb 5, 2021 at 8:35 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    that the life of having dank stance.
    you could try 3m film on the problem spots but its kinda only a temp fix. mud flaps or go back to stock wheels.
  3. Feb 5, 2021 at 8:44 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Interesting......
    I'm running 265/65-17 on stock Sport rims and mud flaps without rubbing or serious rock chips. The truck does have the protective film on the rocker panels. The wheel offset is +30mm.
    Perhaps your offset will needs a wider mud flap. Or stay off roads with rocks................
  4. Feb 5, 2021 at 8:49 AM
    VTYoda
    VTYoda [OP] Member
    Nick
    yeah the wheels im running have 0mm offset so sticks out quite a bit more than stock. probably 1/4 to 1/2 inch outside the fender. i love the fitment but not so much the consequence..
  5. Feb 5, 2021 at 8:51 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I'm running Husky mud flaps on my front. They stick out a touch more than the factory ones and are more cupped. I did have to cut away the inner part of the flap where it sits on the cab mount because I was rubbing; all good now, and the flaps catch a lot of debris.
  6. Feb 5, 2021 at 8:52 AM
    Knute
    Whenever you shift from stock configuration, there is always a compromise somewhere.
    You could try finding mud flaps with the broom bristles. These would be a bit lower and may offer a bit more protection by deflecting rocks.
    Might be ugly as a mud fence in a hail storm.
    My mud flaps are WeatherTech. Perfect fit, match the stock wheel very well.
  7. Feb 5, 2021 at 8:55 AM
    VTYoda
    VTYoda [OP] Member
    Nick
    Any chance you have pics of what you had to trim? curious if it will be worth buying them. i feel as though the part where it mounts to the truck would be where it'd need trimming and i can't really trim the mounting surface..
  8. Feb 5, 2021 at 8:57 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Mud flaps will do very little. Fender flares are about the only option.
  9. Feb 5, 2021 at 9:00 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    It's raining now but I can snap some pics when it slows down.
    VTYoda[QUOTED][OP] likes this.
  10. Feb 5, 2021 at 9:04 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    Additionally, I've found that my sliders catch a lot of rocks as well. I frequently hear dings from rocks bouncing off of them and the bottoms are riddled with rock chips in the paint. That may be a big investment though just to help prevent rock chips. It was an unexpected bonus.
  11. Feb 5, 2021 at 2:57 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Rokbloks are your best bet if you want mudflaps .
