wide tires fit on my stock rims?
Discussion in 'Wheels & Tires' started by toyotadude5, Dec 10, 2009.
  1. Dec 10, 2009 at 1:20 AM
    toyotadude5
    toyotadude5 [OP] Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    ok so i lifted my truck 3 inches. I found some procomp mud terrain tires on craigslist with 60 percent tread left for 150 bucks.
    They are 33-12.50-17.
    My question is will these wide tires fit on my stock 2008 tacoma sport rims???
    i have spacers so not worried about rubbing, just need to know if they can be mounted on my rims!!
    thanks all
  2. Dec 10, 2009 at 2:13 AM
    toyotadude5
    chris
    Flagstaff, az
    anybody know??
  3. Dec 10, 2009 at 2:18 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    too big me thinks :thumbsup:
  4. Dec 10, 2009 at 2:33 AM
    toyotadude5
    chris
    Flagstaff, az
    thats what i was thinkin, but if they do fit i would love to get them
  5. Dec 10, 2009 at 12:41 PM
    toyotadude5
    chris
    Flagstaff, az
  6. Dec 10, 2009 at 12:42 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    what the stock rims are 7" wide...12.5 is a little out of my personal comfort zone
    if your looking at those tires im assuming you have 17's.
    if anything get them if you think its a good deal and keep them till you get new rims if you ever do
  7. Dec 10, 2009 at 12:48 PM
    toyotadude5
    chris
    Flagstaff, az
    yes i have 17s.
    whoever changed the title.. Thanks!!!
  8. Dec 10, 2009 at 12:49 PM
    toyotadude5
    chris
    Flagstaff, az
    i have wheel spacers. i just want to know if those wide tires will fit the stock rims. im not worried about rubbing
  9. Dec 10, 2009 at 12:56 PM
    toyotadude5
    chris
    Flagstaff, az
    how are they still gonna rub that bad? i am currently running 285-70-17 without spacers and the only rub the uca at full lock. isnt a 33 about the same size? only difference is its about 1 and a half inches wider then the 285s. so when i put the spacers on, why would they rub so much more then 285s, when essentially its just a wider tire??
  10. Dec 10, 2009 at 1:57 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    aren't the stock wheels 8 inches wide, if this is the case, they'll fit fine
  11. Dec 10, 2009 at 2:23 PM
    toyotadude5
    chris
    Flagstaff, az
    well i think they are 7.5
    but either way im running 285-70-17 on them fine, and i think 33-12.50-17 are only about an inch and a quarter from what the tire size calculator says
  12. Dec 10, 2009 at 3:22 PM
    The Parts Whore
    The Parts Whore Slinging parts since '03
    285/70 is about ~11.2 width
    33/12.5 is ~12.5 width
    You will rub, as a matter of fact, you won't be about to even mount them since they're ~1.4" wider like you said. Either run a 2" spacers or get wheels with a lower back spacing.
    Which bring up the 2nd point: 12.5 on a 7.5" wheel isn't safe, at least I wouldn't risk it.
  13. Dec 10, 2009 at 3:26 PM
    toyotadude5
    chris
    Flagstaff, az
    i just put 1.25 inch spacers on so im not worried about rubbing. Just want to know if they can, or if anybody has, mounted them on stock rims
  14. Dec 10, 2009 at 3:37 PM
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    they'll fit just fine, pull the trigger
  15. Dec 10, 2009 at 4:18 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    If Jedi master "Chris4x4" happens to see this, I am sure he could use the force to give you inner happiness... oh, and he'll know the answer.
  16. Dec 10, 2009 at 4:21 PM
    badguybuster
    Michael
    ccccchhhhrrrriiissss!!!!!
    SAVE US!!!!!
    :help:
  17. Dec 10, 2009 at 6:49 PM
    tacoman101
    scott
    vermont
    he's not answering
  18. Dec 10, 2009 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What everyone else has said. Get a wider rim.
  19. Dec 10, 2009 at 7:27 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I ran 12.5 on my 7 in wide rims, They worked ok but only problem was that they wore on the inside like crazy, only way to fix this was deflate the tires. From 30 psi to about 23 ish. I eventually went and got wider rims (8.5). Rule of thumb for this is you don't want your tires width to be more than 4 inches over the rims width.
  20. Dec 11, 2009 at 1:23 AM
    toyotadude5
    chris
    Flagstaff, az
    hey thanks all for the comme3nts. i will NOT be getting these tires. better safe then sorry!!
