Wideband AFR Install Help
Discussion in 'Performance and Tuning' started by jeffhorton, Dec 22, 2014.
  1. Dec 22, 2014 at 7:48 AM
    jeffhorton
    jeffhorton [OP] Active Member
    Jeff
    GA
    Supercharged 2013 4x4 Offroad
    TRD S/C
    i have recently purchased a wideband AFR, i installed everything up to getting the bung welded in and the sensor hookup.
    i went to the muffler shop where i go often for welding, they quoted me about $240 to weld in the bung after header pipe but before catalytic converter.
    reason being was because they would need to unbolt the manifold to take pipe off and weld in the location per specs of Wideband AFR. there was not enough room for them to weld in location as is and also to eliminate shavings when they had to drill hole near cat.
    $40 for weld in bung
    $200 for manifold/header unbolting and back on
    they also said that toyota's have a habit of snapping header bolts???
    i think they are telling me the truth to this, but was just double checking if this was 100% accurate about est price and header issues?
  2. Dec 22, 2014 at 7:50 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    If you're going to install before the cat I recommend doing it both sides to be accurate. Kinda defeat the purpose if you only do one side of the engine.
    Another easier route would weld the O2 sensor after the catalytic where the Y-pipe merge together. You would only be .2-.4 off. Not a big deal really. Also it would be easier to get to and no need to remove the Y-pipe.
    Just remember to set the bung at either 10 o'clock or 2 o'clock position so the condensation doesn't damage the O2 sensor in the long run.
    Or..... better yet go with a weldless O2 sensor bung. Comes in 2-2.5" and 2.75-3" piping sizes. You just need to drill the hole and bolt the weldless bung to it. Done!
    http://www.summitracing.com/parts/avm-30-2355-300
    It's cheaper on ebay, that's where I got mine from :thumbsup:
  3. Dec 22, 2014 at 7:52 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    I haven't had any issues with any of my Toyota's header bolts snapping off. Sounds like they want to make an excuse just in case they do snap them off. Some PB Blaster or WD40 works wonders. I'd take it to another shop for 2nd quote IMO.
    WorldWar546 likes this.
  4. Dec 22, 2014 at 8:18 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Ive been thru stock manifolds, long tube headers, shorty headers (as 1 knows the install process requires many mount and dismounts) with ZERO issues with the studs.
  5. Dec 23, 2014 at 5:19 AM
    jeffhorton
    Jeff
    GA
    TRD S/C
    Lord Helmet, i think the weldless bung strap is an excellent idea. i did not even think about looking for that option.
    since it'll be only .2-.4 off, i can definitely deal with that.
    i'll repost once the job is complete.
    thanks
  6. Dec 23, 2014 at 4:06 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    No problem. Do post pics when you get the chance :thumbsup:
  7. Dec 23, 2014 at 4:22 PM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Save yourself $200 and remove factory manifold at home. Also, you might want to avoid installing a bung in the stock manifold if you plan to install some aftermarket headers down the road.
    For ease, just go ahead and install into y-pipe. As mentioned, you'll still be in the ball park of afr.
  8. Dec 26, 2014 at 6:16 AM
    jeffhorton
    Jeff
    GA
    TRD S/C
    Installed sensor by using No Weld band clamp. took a few minutes , no leaks and works like a charm.
    the only part i am not happy about is when i am driving and let off the gas (to come to a stop), the sensor will register as 20 lean, and the gauge will start blinking. this will happen for a few seconds until the truck comes back to normal idle. a little annoying specially when it is dark out.
  9. Dec 26, 2014 at 10:36 AM
    Lord Helmet
    Nick
    '24 X3 M40i
    Looks good but how far back did you install the weldless bung? Also which brand AFR gauge kit did you get? That might help us help you :thumbsup:
  10. Dec 27, 2014 at 6:36 AM
    jeffhorton
    Jeff
    GA
    TRD S/C
    right after Y pipe. both gauges are glowshift brand
  11. Dec 27, 2014 at 11:17 AM
    Lord Helmet
    Nick
    '24 X3 M40i
    Not a fan of glowshift anything. Can you see what brand O2 sensor they used? It might be the issues of glowshift using lesser quality parts for this critical item for the AFR kit. Better and accurate wideband brands I would use would be AEM or Innovate. I like this new part by Innovate:
    http://www.innovatemotorsports.com/products/scg1.php
  12. Dec 27, 2014 at 1:11 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    I believe that's normal cause mine does the same Thing. It would go past 17 lean and blank out on my aem gauge. Then go back to the 14.7-15 area when back at idle.
  13. Dec 27, 2014 at 7:37 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    x2 just normal operation of the gauge my full sweep electric autometer does the same thing.
  14. Dec 28, 2014 at 5:36 AM
    jeffhorton
    Jeff
    GA
    TRD S/C
  15. Dec 29, 2014 at 10:13 AM
    jeffhorton
    Jeff
    GA
    TRD S/C
    Here's email response from glowshift. so i guess all is normal.
    Hello Jeff,
    Thank you for contacting us. With the engine in a deceleration mode, the engines does lean out quite a bit and this is normal to see this going to 20 and blinking until you do reapply the throttle.
    Thank you
    Justin
  16. Oct 19, 2015 at 7:35 AM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    So even if I were to go At the y AFTER all 4 cats my number would only be .2-.4 off?
  17. Oct 19, 2015 at 9:10 AM
    Tacoma SS
    Denver
    And would it show more lean then actual or more rich than actual?
  18. Oct 19, 2015 at 12:44 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Mine (innovate) shows 22 AFR and it's absolutly normal. Fuel cut off on decelaration.
  19. Oct 19, 2015 at 12:50 PM
    Tacoma SS
    Denver
    22 at wot correct?
  20. Oct 19, 2015 at 12:52 PM
    Vassily28
    Euhhhh no.
    FUEL CUT OFF ON DECEL.
