Wideband AFR Install Help
Discussion in 'Performance and Tuning' started by jeffhorton, Dec 22, 2014.
  1. Oct 19, 2015 at 12:53 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Ah missed that part. Do you have your Wideband mounted at the end of the Y pipe like previously recommended?
  2. Oct 19, 2015 at 12:59 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    No.
    I dont have any cats. Mine is installed on one cylinder on passenger side. I've tried to install it at the beginning of the Y pipe but had strange error codes and behavior from it so i moved it back and everything is right.
    From my verifications, when installed too far downstream, it was too cold.
  3. Oct 19, 2015 at 1:19 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Wot is more like 10:1
  4. Oct 19, 2015 at 1:32 PM
    Tacoma SS
    Denver
    Dammit, I'm really looking to get some information from someone who still has all of their cats and where they mounted their wideband at.
  5. Oct 19, 2015 at 1:51 PM
    Tacoma SS
    Denver
    And I don't think my wideband has a heater, not sure though
  6. Oct 19, 2015 at 2:01 PM
    Tacoma SS
    Denver
    Do you think that the spot where the Y pipe joints together would be too far down stream?
  7. Oct 19, 2015 at 2:32 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    right where I have mine.... No issues...... I think @StillWill has same spot
  8. Oct 19, 2015 at 2:57 PM
    Tacoma SS
    Denver
    Do you still have all of your cats?
  9. Oct 19, 2015 at 3:03 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I went from no cats, to shorties.
  10. Oct 19, 2015 at 3:04 PM
    Tacoma SS
    Denver
    So you only have two out of your four cats right now?
  11. Oct 19, 2015 at 3:34 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    correct
  12. Oct 19, 2015 at 5:01 PM
    Tacoma SS
    Denver
    I guess I'll just weld it in at the joint in my y pipe and say f**k it. Even if my number is off a little bit it's still better than nothing
  13. Jan 1, 2016 at 3:45 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    I was planning to do the same but after looking at the y-pipe and doing some searching around, I read someone saying the stock y-pipe is stainless. Can anyone say for sure?
  14. May 16, 2016 at 7:31 AM
    01MUD.TACO.SC.V6
    01MUD.TACO.SC.V6 Well-Known Member
    Clive
    MAXWELL AFB
    01 Tacoma 4WD SR5 Supercharged
    TRD Supercharger, URD 7th Injector Kit, 2" Body Lift, Rear Manual Air Bag Suspension, Marlin Crawler Rear Bumper
    That is a cool idea using a no weld band clamp. Where did you get it? Or was it a custom fab thing? :wave:
  15. May 24, 2016 at 4:08 AM
    #35
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
  16. May 27, 2016 at 2:05 PM
    #36
    Erkon
    Erkon Well-Known Member
    Wisconsin
    2012 Pyrite Mica Tacoma TRD Supercharged
    I am in process of installing a boost gauge and wideband. I have a 2012 and I am 100% stock with all cats. I just have a TRD exhaust. The boost gauge is reading 5psi at WOT. Is the stock blower suppose to put out 6psi? Not terribly concerned, just checking.
    Also, I need to get my wideband installed and I will try at the y-pipe. I hope my cats wont throw it off to much. I will keep this thread updated when I get it installed. Not sure if I will do the no weld clamp or take it to my buddies garage with a welder.
    cdelgado14 likes this.
  17. May 27, 2016 at 5:53 PM
    #37
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    5-6 psi is the norm
  18. May 27, 2016 at 6:59 PM
    #38
    Erkon
    Wisconsin
    Ok. I was wondering. I was really only concerned because my auto meter gauge was suppose to come with a tab that holds the needle off zero for storing and shipping and you are suppose to remove the tab before use. My gauge didn't have that tab and I thought maybe it wasn't calibrated correctly.
  19. May 27, 2016 at 8:31 PM
    #39
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    what are the AFR readings that other boosted tacos are getting?
  20. May 27, 2016 at 8:46 PM
    #40
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    It all depends what you are running. Stock everything else will run rich, 10-11.
    I removed the passenger side exhaust manifold myself as it is fairly easy to remove. Then paid a local shop to drill and weld the bung for about 30 bucks. I bought a new manifold gasket just to be on the safe side but my old one was actually in great shape.
    at wide open throttle I am running 11.5. I have the TRD intake and a 2.85 pulley though so I get 7 PSI boost.
