Wideband AFR Install Help
Discussion in 'Performance and Tuning' started by jeffhorton, Dec 22, 2014.
  1. Jan 21, 2017 at 8:16 PM
    #61
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    What is lambda? I'm using torque pro but i get an afr off the O2 sensors
  2. Jan 22, 2017 at 8:22 AM
    #62
    Pavlik1988
    Pavlik1988 Well-Known Member
    Pavel
    Chicago
    2015 Toyota Tacoma TRD Sport 4X4 V6 SC
    modified
    Basicly same, but show differet parametr. doesn't say afr, it says how many CO2 in our exhaust.
    i will try torque pro today
    mightytacoman[QUOTED] likes this.
  3. Jan 29, 2017 at 4:58 AM
    #63
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Have you got taken out signal from OEM front (wideband) lambda sensors? Or would it mess up the signal for the ECU? It would be an easy AFR gauge install if that's possible.
    Or where do you weld the bung(s)?
    Pavlik1988 likes this.
  4. Jan 29, 2017 at 6:26 AM
    #64
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Lambda is 14.7:1 AFR.
    Here are my manifolds with the bungs welded in. I took the manifolds off myself and drilled the holes where I wanted them. Then took them to a muffler shop and had them weld the bungs on. The pic may be a little too close up to get a good reference, but the bungs are right before the catalytic converters.
  5. Jan 30, 2017 at 6:14 PM
    #65
    Pavlik1988
    Pavel
    Chicago
    modified
    So when i checked mine i had 3 parameters
    most of the time 1.0 (14.7)
    Sometimes 0.8 (rich)
    and 1.2 (lean)
    am i right?
    loginfailed[QUOTED] likes this.
  6. Jan 30, 2017 at 6:25 PM
    #66
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes. Take lambda multiply it by 14.7 and the result is your AFR.
    0.8 lambda = 11.7:1 AFR
    1.0 lambda = 14.7:1 AFR
    1.2 lambda = 17.6:1 AFR
    Just know that if you're getting the readings through a scan tool, the ECU is getting its data from the factory AFR sensors. The factory sensors have a limited range. They're only capable of reading roughly .767 to 1.233.
    If you're pegging it in either direction, it's likely much richer than .767 or much leaner than 1.233. This is why a wideband O2 is needed. They can measure a much wider range than the factory sensors. :thumbsup:
    Pavlik1988[QUOTED] likes this.
  7. Jan 30, 2017 at 6:32 PM
    #67
    Pavlik1988
    Pavel
    Chicago
    modified
    im still waiting for my speedhut gauge((
    BTW, as i remember O2 sensor usually installs in to catalitic. yeserday i found that my afr sensors placed in a perfect spot front of catalitic...
  8. Jan 30, 2017 at 6:33 PM
    #68
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    What O2 sensor did you order?
  9. Jan 31, 2017 at 3:14 PM
    #69
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Here is a handy conversion chart I keep on file.
  10. Feb 1, 2017 at 6:55 PM
    #70
    Pavlik1988
    Pavel
    Chicago
    modified
    same as you sent me
    speedhut.com
    GL-AFWB-09
    2-1/16" Standalone Air/Fuel Wideband O2 gauge 8.5-18
    omg, it is "in production" now, few days ago it was in "art department"
  11. Feb 1, 2017 at 7:56 PM
    #71
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Cool that's the new one Speedhut started offering, recently. It comes with the sensor. When I bought my gauges, they didn't offer that. I had to get the gauges from them and the wideband O2 separately from Innovate Motorsports. Your setup works out to be less expensive. :thumbsup:
    When it says 'in production', it should ship within a couple days. I've ordered from Speedhut a few times. It always seems like the 'art department' portion takes the longest.
  12. Feb 6, 2017 at 8:09 PM
    #72
    SlapChop7
    SlapChop7 Well-Known Member
    Eastern NC
    2019 MGM DCSB OR 4x4
    Just curious. How long ago did you place your order?
  13. Feb 6, 2017 at 11:50 PM
    #73
    Pavlik1988
    Pavel
    Chicago
    modified
    20 days ago
  14. Feb 14, 2017 at 1:14 PM
    #74
    Pavlik1988
    Pavel
    Chicago
    modified
    In my case it is "in production" longer than "in art department"
  15. Feb 14, 2017 at 1:24 PM
    #75
    SlapChop7
    Eastern NC
    Same here... :bored:
  16. Feb 15, 2017 at 5:11 PM
    #76
    Pavlik1988
    Pavel
    Chicago
    modified
    mine was shipped today . will get it next Tuesday :fingerscrossed: (is it express:turtleride: shipping for extra money :facepalm: :censored:???)
  17. Feb 15, 2017 at 5:24 PM
    #77
    SlapChop7
    Eastern NC
    Good to hear. Mine should be pretty close then.
  18. Feb 16, 2017 at 9:29 PM
    #78
    SlapChop7
    Eastern NC
    Shipped today with Monday delivery! :cheers:
  19. Feb 22, 2017 at 8:52 PM
    #79
    Pavlik1988
    Pavel
    Chicago
    modified
    question for @loginfailed : where i can connect green cable from AFR gauge (throttle position sensor)
    loginfailed likes this.
  20. Feb 23, 2017 at 2:31 AM
    #80
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think you're looking for coonector at ECM behind glove box. Toyota calls the wire VTA1. Connector E11 pin 21. G-B means green with a black stripe. Not sure if this is the right diagram but look at page 4:
    http://www.moranbahweather.com/toyota/lc_trj12/rm/rm1017e/m_05_0073.pdf
    My gauge doesn't have the WOT warning light feature like yours so I didn't have to hook up that wire.
