Wideband AFR Install Help
Discussion in 'Performance and Tuning' started by jeffhorton, Dec 22, 2014.
  1. Apr 2, 2020 at 1:51 PM
    #121
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    AEM sells an exhaust clamp with a bung. Drill a hole into your exhaust, and place the clamp over it. Bung over the hole.
  2. Apr 2, 2020 at 2:00 PM
    #122
    Sirnick88
    Sirnick88 Well-Known Member
    Nick
    2011 TX Pro, 6spd MT, boosted
    URD mk3 s/c, Dobinsons snorkel, Ultragauge, Stoptech rotors, TRD ceramic brake pads, softopper, anytime backup camera, anzo black headlights, oh, and vehicle OCD organizers!!!
    @Torspd, sounds like my kinda bunghole ;)
  3. Apr 2, 2020 at 2:02 PM
    #123
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Whoa whoa whoa! Add a comma after name please!
    :eek:
    RocketTaco808 likes this.
  4. Apr 2, 2020 at 2:40 PM
    #124
    Sirnick88
    Nick
    Noooooooooo! It's not like that! Edited!
  5. Apr 2, 2020 at 7:20 PM
    #125
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  6. Apr 9, 2020 at 5:47 PM
    #126
    Sirnick88
    Nick
    So is the consensus 1" aft of where the y pipe merges? I bought the AEM x series gauge.
  7. Apr 9, 2020 at 6:16 PM
    #127
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I think I did mine like 3 inches so the clamp has room to completely seal. But I went with that clamped bung and have had no issues.
  8. Apr 9, 2020 at 6:33 PM
    #128
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    thats a fine spot just hit the 10 -2 o'clock location area.
  9. Oct 16, 2022 at 1:14 PM
    #129
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    Reviving an old thread. Recently procured an AEM wideband and boost gauge. Got gauges installed, need to put in exhaust sensor.
    I have thoroughly confused myself reading these threads on where to place the sensor. I think the best place reading this right now would be on passenger side behind first cat. I have a standard setup there. I guess the Y would be the second best place. The AEM instructions say in front of CAT, but that seems troublesome and not as big of a deal with tiny output changes.
    I have capability to MIG weld it in at the house. I was thinking I'd just unbolt the second cat and put it in at the 2 o'clock position opposite the factory sensor.
    So questions:
    1) Would the Y be superior to see gas from both sides but cooler and further downstream behind second cat, that seems to be consensus on several threads but then I see URD puts their bung for this sensor on one side...
    2) Are there any gaskets that need to be replaced if unbolt out section with Cat?
    3) Does it have to be TIG welded? It doesn't seem like it has to be pretty...
    Thanks so much.
