Widest Tire on a 245 Skinny?
Discussion in 'Wheels & Tires' started by Voltron4x4, Jan 13, 2021.
  1. Jan 13, 2021 at 9:58 AM
    Voltron4x4
    Voltron4x4 [OP] Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Tires recommend 8in wide as the maximum. Are you able to go to 8.5-9in wheel with negative offset, past the recommended maximum? Most aftermarket wheels are in the 9in range. Thanks!
  2. Jan 13, 2021 at 1:16 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Offset has nothing to do with rim width when it comes to fitting tires to the rim.
  3. Jan 13, 2021 at 1:17 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    You should edit your title to say "widest wheel". Seems like you should probably follow the manufactures recommendations. If it says 8" is the widest wheel you should use......
  4. Jan 13, 2021 at 2:01 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    245 on a 9? We talking stretch and poke now?
  5. Jan 13, 2021 at 2:15 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Sidewall blow out looking for a location.
  6. Jan 13, 2021 at 2:17 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    ive seen guys run stock tires on 9 inch wheels, looks fine
