Widest tires with toytec Lift??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DontTryMe, Jul 28, 2009.
  1. Jul 28, 2009 at 7:13 PM
    DontTryMe
    DontTryMe [OP] Well-Known Member
    Atlanta,GA
    07 TRD offroad dbl cab
    Tinted Tail Lights, Fog Light mod, Black Projector Headlights, 8000k HIDs, Grill Craft Grill, Sport Hood
    Hey guys, I'm new to Tacoma World, but I've been checking out the site for quit a while now. My question is can I run a 12.5 wide tire with a 3 inch toytec lift? Im either getting 18 or 20 inch wheels with the 33 Toyo M/T tires. The new wheels will have a 4.5 back spacing so I know that will help some. Also thinking maybe a 1/2 inch spacer? Any suggestions? Anybody running 33 12.50s?
    Thanks guys!:)
  2. Jul 28, 2009 at 7:17 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    you could make them fit... but i'm sure it would require some decent trimming.... especially if you plan to offroad and need to flex them out.
    there was someone who was running 33x12.5's with 3" of lift but cant remember who it was... just remember it was a dark blue double cab with MTZ's... looked really sharp
  3. Jul 28, 2009 at 7:20 PM
    rpparkster
    rpparkster Well-Known Member
    Roger
    Long Beach, CA
    2009 Tacoma TRD 4X4
    TRD FJ Wheels, 285 GY DuraTrac's, Fox 2.5 C/O w/ Res, TC UCA's, Demello Sliders,AllPro 3" Leaf Pack, Walker Evans 2.0 Adj. RR, AllPro Front Bumper & IFS Skid, Timbren Bump Stops, Leather
  4. Jul 28, 2009 at 8:23 PM
    DontTryMe
    Atlanta,GA
    Any idea on how much "trimming would be needed? Just the plastic or major trimming? Im debating on the icon coil over and a leaf pack vs the toytec kit,but considering i dont wheel very often I'll probaly stick with the toytec. Either way I would like to run a 12.50. Any body else have any experience?
    Thanks!
  5. Jul 28, 2009 at 8:59 PM
    rpparkster
    Roger
    Long Beach, CA
    2009 Tacoma TRD 4X4
    Doesn't matter which kit you choose, 3" is the same. You'll probably have to chop the Cab Mount and do something with the Pinch Weld. Cutting the plastic Flares is a given.
  6. Jul 28, 2009 at 9:09 PM
    DontTryMe
    Atlanta,GA
    damn...I was hoping just cutting the plastic would be all that was needed? Does a 6 inch lift remedy the problem or is a pinch weld and cutting the cab mounts still going to have to be done?
    Thanks for all the help!
  7. Jul 28, 2009 at 9:14 PM
    rpparkster
    Roger
    Long Beach, CA
    2009 Tacoma TRD 4X4
    Try to do some searching and you'll find the answers. I don't know a thing about 6" lifts and if they rub. Good luck.
  8. Jul 28, 2009 at 9:31 PM
    FoxRacR17
    FoxRacR17 Well-Known Member
    Kevin
    SoCal
    09 4x4 SR5 DoubleCab Short Bed
    Fox 2.5 C/O's, Fox 2.0 rear shocks, toytec 1.5" AAL, TC UCA's, blue/white dashboard lights, seatbelt chime removed, Synthetic leather armrests, WO seat covers front and back, Goodyear Wranger Duratrac 285/70/17, KMC XD Addict 17x9 rims
    I dont think they would rub with a 6" lift. I had my fox 2.5 coilovers cranked up to 3" and my tires cleared the cab mounts just fine (17x9 4.5BS -12mm offset rims on 285/70/17 tires) but I didnt like the stiff ride so I put them down to 2.5" lift and now I rub pretty badly on the cab mounts when backing up and turning or going over a big bump/incline while turning.
  9. Jul 28, 2009 at 9:51 PM
    DontTryMe
    Atlanta,GA
    What exactly is the pinch weld?
  10. Jul 28, 2009 at 11:15 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Something on the 1st Gens that you don't have to worry about. The only two things you'll rub are the Cab mount and the fender liner.
  11. Jul 29, 2009 at 10:09 AM
    DontTryMe
    Atlanta,GA
    It seems like from what I have read that the 6 inch lift will cause much less rubbing issues.. I'm just gonna go all out and get the 6 inch procomp then, I know I would regret not getting the 6 inch lift if I went with the 3"..
  12. Jul 29, 2009 at 11:47 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    You should pm KROOKZ. He'll tell you the stories of his 35's on 20. Recently switched over to 33" on 18 and i believe couldn't be happier. I believe he has a 6" lift.
  13. Jul 29, 2009 at 11:50 AM
    Padilla1880
    Daniel
    Temecula, CA
    Check this out CLICK ME
    Not 12.50 but could help for reference.
  14. Jul 29, 2009 at 11:57 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2 Getta recip. saw and go nuts! As for the cab mounts you might wanna goto an Off Road Shop to get it done correctly or have a buddy who knows what hes doing do it :rolleyes:
  15. Jul 29, 2009 at 1:12 PM
    Padilla1880
    Daniel
    Temecula, CA
    And looks meaner than an old lady who hasn't had her FiberCon.
  16. Jul 29, 2009 at 1:19 PM
    Fire931
    VA
    00 4Runner
    not entirely true.. most dont have problems with the pinch welds but a few do.. i had to beat mine down flat and i still manage to rub on a large section of the firewall... ofcourse thats at full stuff and turning sharp ....
  17. Jul 29, 2009 at 1:27 PM
    DontTryMe
    Atlanta,GA
    Hey krooks, what width tire were you running with the 35's? I would really prefer 35's over the 33's but if it damn near impossible to do without having an unforgivable amount of problems then idk..
  18. Jul 29, 2009 at 1:54 PM
    DontTryMe
    Atlanta,GA
    Do you think that getting tires that are only 11.5 wide would not rub near as much? aalso did you have wheel spacers on with the 35s?
    Thanks for all your help man!
  19. Jul 29, 2009 at 3:33 PM
    DontTryMe
    Atlanta,GA
    krooks you are very helpful! So the 35's were only a pain in the ass when under full compression, such as taking it offroad? How where they under normal street use?
  20. Jul 29, 2009 at 4:33 PM
    DontTryMe
    Atlanta,GA
    Where did you get your swaybar? My tacoma will not go offroad at all.. I the jeep for that. I love the look of 35's and just want to make sure that on the street I will be okay and wont rub over speed bumps and turning every time. How significant was the power loss with 35's?(assuming you didnt regear)
    Thanks again man. You are saving me from a head ache of trial on error!
