Wierd "CLACK" sound when applying brakes!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by THExBUSxDRIVER, Apr 25, 2010.
  1. Apr 25, 2010 at 8:29 PM
    THExBUSxDRIVER
    THExBUSxDRIVER [OP] Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    I've noticed that when I sometimes apply the brakes I hear a "clack" sound, Its not when I press the brake hard, only a tiny bit of pressure needs to be applied and the sound will happen. It doesnt happen every time I press the brakes but here and there.
    ANY IDEAS??
  2. Apr 25, 2010 at 8:43 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    Thats a good question. I hope you get an answer because my 6spd when i am in reverse and press the brakes. BAM theres a little clack sound. SOMEONE give the OP and me an answer lol
  3. Apr 25, 2010 at 8:50 PM
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    x3 thought i was the only one
  4. Apr 25, 2010 at 8:55 PM
    BULLETflight7
    BULLETflight7 Member
    Satsuma, AL
    06 PreRunner
    mine does the same thing... i think it is because the brake calipers "float"... someone feel free to correct me if i am wrong...
  5. Apr 25, 2010 at 8:55 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    i was told there is some sort if cover on the brakes and when going from reverse to forward the cover is shifting from front to back or vise versa. Chris said this noise is totally harmless. well on a 2wd it is, on 4wd's it could be your CV's but Mine does have a distinct "clack". maybe one day Ill climb under the truck and try and tighten up any bolt I can see but from what I was told is that its nothing to worry about
  6. Apr 25, 2010 at 8:57 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Normal. It's just the play in the pads where the pins slide through them (if you don't know what I'm talking about, do a search for pictures of how the front pads mount in the Taco.
    Anyway, you'll find it happens when you switch from going forward to reverse, or vice versa. For example, back up the truck in reverse and come to a stop. Then go forward and you'll hear it when you first use the brakes. Same goes if you were driving forward then come to a stop. Then back up and apply the brakes. You'll hear it then.
  7. Apr 25, 2010 at 8:58 PM
    snowgod06
    Rob
    06 Access Cab
    Well that solves my wonder, thanks. Hope that helps the OP as well.
  8. Apr 25, 2010 at 9:26 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Agreed its just shifting back and forth. If it was CV joints you would notice continuous popping while turning.
  9. Apr 26, 2010 at 12:17 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    I know it happens while driving forward but have not paid attention to the backing up then forward thing.
  10. Apr 26, 2010 at 12:17 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    THANKS for the info guys
  11. Apr 26, 2010 at 12:24 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    I found this thread on TN that might be of help
    LINK
  12. Apr 26, 2010 at 3:54 AM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I had the same problem about 2 months ago. Took it in for a maintenNce service and the tech inspected/cleaned up the brakes and the problem was gone. My service manager (who I trust) said it's fairly common. The pads were not worn too badly. Clacking sound only happened after every forward/reverse transition. The noise is due to the pads shifting inside the calipers.
