wierd electrical issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by apoteker, Mar 3, 2018.
  1. Mar 3, 2018 at 8:35 PM
    apoteker
    apoteker [OP] Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    Here is a puzzling problem: my 2012 tacoma has a lighing issue. The HVAC panel is very dim. but still illuminates. It doesnt matter if i adjust the dimmer switch: all the other panels/radio work fine but the hvac doesn't. Any ideas?
  2. Mar 3, 2018 at 8:41 PM
    tcjacado
    tcjacado Well-Known Member
    Gremlins :confused:
  3. Mar 3, 2018 at 8:46 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Loose ground?
    Have you done anything with wiring under the dash?
    ovrlndkull likes this.
  4. Mar 3, 2018 at 10:52 PM
    apoteker
    yes, i have done a bit of meddling.i tapped into the illumination circuit for the light for my 4runner 4wd switch- this is also dim now. I did that mod about 3 years ago and this is a recent change...but i am wondering why it is the power to the hvac control only
  5. Mar 4, 2018 at 12:05 AM
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    That sounds like it can be the cause but who knows why it took 3 years. I would just undo the tap to see what happens.
  6. Mar 4, 2018 at 6:03 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Since this just started - I'd suspect a ground is bad. If the lights are "two wire" (i.e. 1 power and 1 ground to item) the lights may be getting ground from the next closest ground point and the increased wire length may be causing a voltage drop. IF so try adding a couple ground wire/points near each lighted panel - shortest distance to a good chassis ground.
    2nd is it possible you wired for the light you added is in "series" and not in a parallel connection?? This would dim the lights by dropping the voltage across each incorrectly wired bulb.
    3rd You have a friend that is severely screwing with you.
