Wierd noise at driver kick panel under dash
Discussion in '1st Gen. Tacomas (1995-2004)' started by robbymartin, Apr 10, 2011.
  1. Apr 10, 2011 at 8:49 AM
    robbymartin
    robbymartin [OP] Well-Known Member
    Rob
    Yucaipa
    '02 Double Cab 4x4
    When I am at 40 MPH on up to freeway speeds I can here this sound coming from what sounds like behind the in-cab fuse box. It sounds like a speedo cable trying to turn but restricted, but doesn't sound like it's coming from behind the speedo or odometer but left of that and slightly lower. My speedo is dead on so I don't think it's that...plus the sound is too slow for a speedo cable. Any ideas?
  2. Apr 11, 2011 at 5:40 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    It can't be your speedometer cable, because you don't have one. Cable-driven speedometers disappeared as of the 1998 model year.
    Can you give a better description of the sound(s) it's making?
  3. Apr 11, 2011 at 7:40 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check your wheel well for loose stuff.
