Wierd noise coming from engine area...
Discussion in 'Technical Chat' started by Gary_G, Jun 2, 2016.
  1. Jun 2, 2016 at 11:12 AM
    Gary_G
    Gary_G [OP] Member
    Gary
    2007 Toyota Tacoma - Access Cab 4x4
    Has anyone ever run into a intermitant sound like this?
    It has been occurring on and off.
    I may have pinned it down to the A/C compressor...but would like some input if possible.
    https://youtu.be/wqVtgV3xq6Q
    I have attached a link to a video.
    Any help would be great.
  2. Jun 2, 2016 at 6:40 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    You're thinking a/c compresser, but I didn't see the a/c light on in the vid. Does the noise change when you turn on the a/c?
    More info like miles, motor, trans, maint. you've done since buying would be helpful.
    Just a shot in the dark but, my first thought would be idler pulleys.
  3. Jun 2, 2016 at 6:44 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeah Id say pulleys or transmission.
  4. Jun 3, 2016 at 7:01 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    On my 1st gen, the trucks computer turns the compressor on and off (even with A/C off) when the heating control setting is in defrost. I assume the 2007 is the same.
    Gary_G[OP] likes this.
  5. Jun 3, 2016 at 8:27 AM
    VolcomTacoma
    Jeff
    NorCal
    Yeaaah thats not a normal sound lol
  6. Jun 8, 2016 at 3:25 PM
    Gary_G
    Gary_G [OP] Member
    Gary
    Well to make a long story short. The noise subsided by itself "mysteriously".
    Come to find out the a/c is no longer working.
    The condensor blew a hole and system was drained.
    Wondering if it could have been the compressor that cause a possible build up of fragments coming from that sound in the video?
    What confuses me is that I checked the low port and the pressure is high still.
  7. Jun 8, 2016 at 3:27 PM
    Gary_G
    Gary_G [OP] Member
    Gary
    I am aware that if you use the defrost setting even in winter, the compressor will still kick on.
  8. Jun 8, 2016 at 3:30 PM
    Gary_G
    Gary_G [OP] Member
    Gary
    All pulleys seen to be working fine. No play, no grinding bearing noises.
    As for the noise was trying to diagnose it, and was unable to.
    I did bring it in to the dealership to see if they could diagnose it. They said it was a heat shield, rattling.
    Ironic that the noise was still there after they "fixed" the heat shield.
