Wierd problem while filling up with gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Roblit82, Oct 27, 2022.
  1. Oct 29, 2022 at 2:00 PM
    #101
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    you are not supposed to smoke while refueling also - do you do that too?
  2. Oct 29, 2022 at 2:04 PM
    #102
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    It isn't.
  3. Oct 29, 2022 at 2:13 PM
    #103
    saint277
    saint277 Vigilo Confido
    I mean the trucks entire electrical system is a potential ignition source, and your betting you have a fully functional pump that will stop when the tank is full and not spew fuel all over the place. If every thing goes right there is little risk, or you could turn the truck off reduce the risk to 0 even if things go wrong. People be dumb though.
  4. Oct 29, 2022 at 2:17 PM
    #104
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Maybe filling up with the vehicle still running is not excessively dangerous, but there is a sign on every gas pump in the US that says shut the vehicle off so maybe there's something to this?
    This may all just be out of an abundance of caution, I really don't know. But I shut the vehicle off as that's what I was taught to do.
    Oh, I also don't run with scissors.
  5. Oct 29, 2022 at 2:45 PM
    #105
    Doghouse61
    Doghouse61 Well-Known Member
    Paul
    Calgary
    However, gasoline liquid will not burn, it needs oxygen to create combustion. It's the vapour that is dangerous. Just think of trying to run your engine waaaaay rich. You have gasoline and spark but not enough oxygen so it won't run. Lean it down with oxygen (air) and away you go. As to the guys smoking while replacing pumps, I have to agree with you. It's either bs or guys completely flouting OSHA requirements. Just my 2 cents.
  6. Oct 29, 2022 at 4:06 PM
    #106
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I like what you are saying, but I don't see how turning the vehicle off changes anything. And I'm not telling anyone they should leave it running or not. Your electrical scenario would require an exposed ungrounded/positive wire and contact with a ground source, which are admittedly numerous on a vehicle. But what circuit are you closest to while refueling? The tail lights, maybe? That circuit is hot whether or not the car is on, and the switch under the brake pedal has to be closed to energize anything downstream of it anyway, which will occur when you get back in to put it in gear, regardless of whether or not it was running while fueling.
    I addressed static as a result of the fuel pump running in a previous post, as well as hot surface contact by gasoline. I can cite some studies on hot surface gasoline ignition if anyone is interested, we got side tracked with smoking.
    I'm generally curious about the perception of this and enjoying the discourse.
  7. Oct 29, 2022 at 4:12 PM
    #107
    MDFM31
    Chester Co, PA
    16 DCSBOR
    I don't smoke, but cigarettes do not appear to be competent ignition sources for gasoline, in any form. Though I'd not recommend it, because the open flame from a lighter certainly is.
  8. Oct 29, 2022 at 5:03 PM
    #108
    saint277
    Tail lights, fuel pump, locker(if you have it), an ALWAYS HOT when key is on 7 pin trailer plug, 120ac plug. The brake lights aren't the only ones back there also you have running lights. Also the brake lights don't energize when the key is in the off position. Plus if the switch for the fuel pump doesn't stop when the tank is full a puddle can form under the entire truck in short order, the entire trucks electrical system will be exposed to a cloud of fumes an a single short will light it up. You should just be smart and deenergize the whole system, but people be dumb.
  9. Oct 29, 2022 at 5:28 PM
    #109
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Toyota uses negative switching for a lot of circuits. So they're always hot no matter the key position. Hence why people have all these issues changing interior lights.
    shakerhood likes this.
  10. Oct 29, 2022 at 5:32 PM
    #110
    saint277
    This is the part wear people try to say there just as many hot circuits with the key OFF as ON. People be dumb.
  11. Oct 29, 2022 at 5:36 PM
    #111
    RX1cobra
    19 OR
    Can you prove otherwise? The positive is live no matter what. So a short can happen key on or off.
  12. Oct 29, 2022 at 5:37 PM
    #112
    saint277
    lol dude
  13. Oct 29, 2022 at 5:39 PM
    #113
    Buck Henry
    But where there is smoke, there is fire brother! I just think it is unwise to have any unnecessary ignition source near a vehicle when fueling. But there is no way I am going to fault anyone for leaving their truck running while fueling in -30 degree temps to keep their spouse / child warm.
  14. Oct 29, 2022 at 5:40 PM
    #114
    RX1cobra
    19 OR
    I'm open to being wrong. Just please explain how I am.
  15. Oct 29, 2022 at 5:41 PM
    #115
    saint277
    try to turn the radio on with the key off, there's 1. use your brain to find the rest.
  16. Oct 29, 2022 at 5:49 PM
    #116
    RX1cobra
    19 OR
    I see. Do you know why the radio doesn't turn on? Do you know what a short to ground means?
  17. Oct 29, 2022 at 5:59 PM
    #117
    saint277
    Thats perfect if its a short to ground its impossible for it to spark due to a fault, you should turn your key off when pumping. As short to ground is just a way to switch in this case, there is no way the entire entertainment system is shorted, the parasitic draw would be insane. Try to put the windows down next with the key off next bet thats not getting power either of some reason.
  18. Oct 29, 2022 at 6:25 PM
    #118
    MDFM31
    Chester Co, PA
    16 DCSBOR
    Can you explain this a little more to me? Is this a situation where the switch is at the end (grounded) side of the circuit instead of the first thing the ungrounded conductor interacts with (aside from circuit protection)? I am more familiar with structural and appliance wiring, and that situation is a very bad deal in those cases because the appliance is energized even if it is off.
  19. Oct 29, 2022 at 6:38 PM
    #119
    RX1cobra
    19 OR
    You don't understand how our trucks work. The circuits are getting power always. They don't drain because the ground is broken turning them off so there's no drain. But a short creates the ground making the circuit live again.
    Most cars the power is cut to turn the circuit off. Ours the ground is broken. This is why so many people have issues doing something as simple as changing interior bulbs and not disconnecting the battery. They ground the still live positive wire and boom you got issues.
    I think above explains it. But you can choose to break the power or ground to turn the circuit off. Most turn the positive off toyota picks to turn the negative off.
    MDFM31[QUOTED] likes this.
  20. Oct 29, 2022 at 7:06 PM
    #120
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    There are some circuits that switch grounds ( more common in ECM control circuits because it is tougher to induce a ground vs. a power )... But a good portion of lamps are switched powers. The only lamps I found that were switched grounds were the visor vanity mirrors... there may be others..
