Wife's car got partially flooded this weekend
Discussion in 'General Automotive' started by Hextall, Mar 5, 2018.
  1. Mar 5, 2018 at 6:33 AM
    Hextall
    Hextall [OP] Well-Known Member
    NH
    17 Inferno OR DCSB
    Hi everyone... advise solicitation time.
    We were on vacation the past week (went to lovely San Diego for a few days), and parked our car at an offsite airport parking lot near Logan (Boston). Apparently there was a large storm and unlucky us and our parking at the back of the lot near the Charles river, my wife's Rogue got partially flooded. We had no idea that the water rose into the car, so when we got to the lot late last night (flight delayed because Logan is apparently catching up from the storm) and dropped off from the shuttle, we jumped in and drove away (car started fine, no indication that there was anything wrong). As the shuttle was dropping us off, a woman in the car parked right next to ours was telling the shuttle driver that her car was flooded and she'd need a ride back to the office. I was tired, and it never even clicked she meant water flooding.... I just was thinking in my tired brain... how does someone flood (gas) a modern engine car?
    As we were leaving the parking lot, the speaker in the dash was crackling and popping, even with the radio off, and then a few minutes later the seatbelt indicator started flashing (we were all buckled up), the airbag light started flashing... and my tired brain actually started working... so I reached down and the carpet and mats were soaked. the seats weren't wet, there wasn't water in the lower door compartments.
    We called the lot, they said let us know what to send your insurance... we called our insurance and got a claim started.
    My question... what should we expect from insurance? It's a 2013 Rogue with 58k miles... if they total it, what can we expect to receive (we paid $25k). Do we have any rights to push back and try to get more money if they come back with a really low amount?
    Just curious what other people's experience and advise would be. Thanks.
  2. Mar 5, 2018 at 6:35 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Id get any and all camera footage the parking lot company has that might show the water level and go from there
    TomTwo and DrFunker like this.
  3. Mar 5, 2018 at 9:31 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Unfortunately, it's probably totaled. As noted above, try to see if there is any record of how high the water rose. Also, there are independent valuation appraisal services that can help if you feel the offer is too low.
  4. Mar 10, 2018 at 4:20 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    If safety equipment like airbag electronics need to be repaired, and insurance gives the go ahead to have it fixed, and then there's a failure sometime after the repair, can the insurance company have some liability for that failure? If so, the insurance company would likely total the vehicle rather than chance taking on that liability.
  5. Mar 10, 2018 at 4:25 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Edmonds says its value is about 14k.
  6. Mar 10, 2018 at 4:26 AM
    DrFunker
    DrFunker Well-Known Member
    Not to mention that salt water does a number on electronics too.
  7. Mar 10, 2018 at 4:34 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Document every warning light you see/saw. Take it for a drive with someone following you [if it quits running] Reason is if your insurance company checks it and it's not coding/showing system warnings or failure, they may offer less or do nothing, flooded vehicles can be very problematic down the road, fluids needs to be drained and replaced, connections can corrode and act up due to low voltages and resistance where there should be none, wheel bearings will likely have been contaminated, repairing a flooded vehicle RIGHT can be time consuming and expensive and usually, short cuts are taken. Modern vehicles, with all the electronics and wiring are especially bad. Make yourself a check list of anything that could have had water intrusion, you want to make sure they inspect, OK, and long term cover it if it fails several months down the road.
    If you can get info on how deep the water was at peak, it might help you immensely in your claim. Note all areas that were wet or damp,water can wick much higher then the surface of it with materials that absorb it and it can get inside wiring and cause corrosion and resistance the same way.
    TomTwo likes this.
  8. Mar 10, 2018 at 4:36 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It's totaled. You do not want to hold onto a flood car.
    Subbed.
    TomTwo likes this.
  9. Mar 10, 2018 at 4:41 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Good advice already with footage of the water level and warning lights.
    On the flip side, I've flooded the taco twice to the floor boards (fresh/muddy water). Other than a starter that shit the bed and a squeaky idler pulley I haven't seen any other issues in 6+ years.
  10. Mar 10, 2018 at 4:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Salt or fresh water? I know you said 'river', but is it tidal/brackash?
    How deep? Since seats are dry, I'll assume not to the bottom of the seats.
    The lights you mention have sensors/connectors at levels below the seats. Airbag crash sensors up behind the bumper for example, and seatbelt / airbag activation under the seat.
    Where is the ECU mounted? Suspect it's dry, as the vehicle ran.
    If only to the level of the floor pans, if fresh water, if ECU is dry, it may be a simple disassembly and dry out.
    If it's salt water, its more complex, but it can be done too, again, depending on the depth of intrusion and the quality of the cleanup crew.
    If it's declared a total, it's no different than a wreck. You'll have to work to get a good $ figure in most cases. Keep in mind it doesn't mean a thing what you paid for it, all that matters is what it's worth now.
    Best of luck!
  11. Mar 10, 2018 at 5:38 AM
    Hextall
    NH
    17 Inferno OR DCSB
    Sorry should have updated... Insurance declared it a total loss. Got just shy of $14k.
    I somehow feel I got tricked because we are picking up a bmw x3 (used) today. I am suspicious of some spousal foul play causing the flood but have no evidence. This was a very expensive quick vacation to San Diego
    Wallbright, boynoyce and TomTwo like this.
  12. Mar 10, 2018 at 6:21 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Don't think you were tricked, since the car next to you was flooded also:
  13. Mar 10, 2018 at 6:22 AM
    Hextall
    NH
    17 Inferno OR DCSB
    Maybe that's just a way to throw me off her trail. Do a similar crime nearby to make it look natural. Brilliant!
  14. Mar 10, 2018 at 6:27 AM
    Hextall
    NH
    17 Inferno OR DCSB
    I will say though .. Liberty mutual isn't really giving us a hard time. The only partial roadblock is that we probably aren't getting their check until later next week after we send and they receive the title for the rogue.
    So I don't think we have to prove how bad the flood was into the car or anything like that.
    And to follow up some questions .. This was a tidal river so saltwater/brackish. The collision place we brought it to for assessment didn't dismantle anything as my wife went yesterday to get all her stuff out of it. It stank.
  15. Mar 10, 2018 at 6:36 AM
    Cedar Taco
    Cedar Taco Well-Known Member
    I had a civic get flooded to the bottom of the windows. It was totaled but the adjuster said he had to spend forever listing the various parts that would get replaced in order to total it out.
    I expect they will pay you for repairs to the car. I would have dried it out and traded it in. I’ve had two floods in the past couple years it’s been hell. Now I live on top of a hill.
  16. Mar 10, 2018 at 6:49 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    It would be fresh rain water. There isn't any place with tidal backwash that would risk a parking lot like that near the airport. The "river" on an average day is more like large stream, but with heavy rains, it normally overflows into city streets, etc. Why San Diego hasn't fixed this after having this issue decade after decade is beyond me.
  17. Mar 10, 2018 at 6:58 AM
    Hextall
    NH
    17 Inferno OR DCSB
    This was in Boston.
  18. Mar 10, 2018 at 6:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    The 'event' occurred in Boston.
  19. Mar 10, 2018 at 7:04 AM
    Norsemanvike
    Escondido, CA
    Whoops...
    Woops...
    JKU3000 and Hextall[QUOTED][OP] like this.
  20. Mar 10, 2018 at 7:05 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Look in the door jams and see if you can tell how high the water got to especially if you can't get any video. Might be a hidden waterline in there. Lots of wiring in door sills and under seats.
