Wifi + rain = IRRITATED USER!
Discussion in 'Technology' started by 07TacoRidah, May 6, 2013.
  1. May 6, 2013 at 10:17 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    is there any way to keep my wifi signal from my computer at a level to where I'm NOT feeling I'm on dial up? It drops NASTY and I mean NASTY (raining right now but it sounds like it's just drizzling NOT pouring rain). I have my browser set to Google as my homepage on start up, but even THAT has problems loading. :mad:
  2. May 6, 2013 at 10:19 AM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Is the wifi in your house or are you borrowing it off a neighbor? Who's your provider? If it's in your house you would have a problem with your provider.
    (This will not speed up your internet, but it may feel like it) You can try Googles DNS servers, but that would just speed up DNS lookups. I prefer them over service provider DNS servers.
  3. May 6, 2013 at 10:33 AM
    07TacoRidah
    my house. I think it's Charter. dam, just sucks cause at time I need to do money related things online and when I try to do things, every now and then the signal drops and I'm stuck waiting for something to load/transfer ... or just stuck and I have to do things all over again and then have to verify that nothing was messed up in the process while I had issues. :( thanks though, other than talking to the provider, nothing else I can do huh?
  4. May 6, 2013 at 10:35 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx
    Is it your wifi or your internet? Try to wire a laptop or something into your router through ethernet and see if it does the same thing. If it does, it's your internet.
    edit: if its your wifi, try changing the channel on the router. Sometimes you get signal interference on certain channels.
  5. May 6, 2013 at 10:37 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Can you use Ethernet direct to your Computer? More reliable then WiFi...
  6. May 6, 2013 at 10:37 AM
    07TacoRidah
    I think it's more to do with the router. I used to have one of my old comps wired via ethernet to the router and when it rained I would still have problems with my connection dropping here and there. I broke the mb of my laptop a year ago :( don't really have much to test on (all the comps in the house have been password only .. lil nephew reasons)
  7. May 6, 2013 at 10:39 AM
    97Blk_one
    Memfrica
    not so low
    Best solution...borrow your friend computer...
  8. May 6, 2013 at 10:40 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx
    is the router yours or the cable companies? If yours, look for a firmware update. There may have been a bug and its been fixed since you bought it. If its the cable companies, call and tell them you need a new one cause it keeps dropping. It also could be a modem issue.
    I have FiOS and the router is an all in one type that verizon provides, so if anything goes wrong, they send a new one, but companies are all different.
  9. May 6, 2013 at 10:42 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx
    Also another suggestion. You mention when it rains is the only time it happens? Is there a possibility there may be a bad connection outside your house somewhere and when it rains the water gets into the wiring and causes problems?
  10. May 6, 2013 at 10:52 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    1) hardwire to the router via ethernet
    problem the same or different ?
    2) see 1
    3) #1 problem with wi-fi at home is not rain, it is using a microwave
    they are very dirty EFI sources and can kill wifi. but to be a nuke problem
    would mean someone is only using it when it rains, hence, item 1 is the
    first thing to prove/deny
  11. May 6, 2013 at 10:57 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx
  12. May 6, 2013 at 11:59 AM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    Pretty much, Rain would not interrupt WiFi in your house. If you were borrowing it from a neighbor the story could be different. To rule out the devices in your house get a long ethernet cable and string it from your computer to your Wireless Router. If it still drops connection take the Wireless Router out of the equation and plug your computer directly into your Modem (This assumes they are separate devices). If you find your wireless router is the cause you can try updating the firmware (assuming you own it).
  13. May 6, 2013 at 12:03 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    rain=moisture...
    check all exposed and/or covered connections on the way into the house, more than likely you got some water playing with a connect or three...it could even be on the pole outside, something your provider would have to fix...
    Call them, explain everytime it rains the signal goes wonkers, your paying for the service...
    Good luck....
  14. May 6, 2013 at 12:06 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    Step 1:
    Rule out everything on your end first. This includes Your computer, Wireless card, wireless modem, cable/dsl/satellite modem, wires inside the house. Anything outside the house is not your responsibility and you should not change any fittings or cables outside.
    Step 2:
  15. May 6, 2013 at 12:25 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    OK
    I bet a shitty crimp on the cable, shorting core to shield when wet
    anywhere outside from pole to house
    you can fix all these yourself, except climbing a pole.
    that will get you in trouble
  16. May 7, 2013 at 9:16 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    My guess is it's not your router since that would be inside, unaffected by rain. Unless, of course, you have water dripping on your router. As others have said, plug your computer into one of the ethernet ports on the back of the router. That will elimnate the wifi altogether. If the problem is still there, it's not a wifi issue. Next, if there's a splitter (for tv) try disconnecting the cable from the wall and bringing it directly to the modem. That will eliminate the splitter and indicate that the problem is the feed from the cable company. You could also try connecting directly to the cable modem but there's some configuration you have to do to get it working (http://answers.yahoo.com/question/index?qid=20080723222616AAJy8D8).
    The problem is probably outside though. Since it happens only when it rains, something is getting wet in the cable circuit. It would be best to just call the cable company and register a complaint. They'll usually fix it for free and they have tools to test the line's signal strength. I would not recommend trying to fix it yourself. A friend of mine works for Cox Cable and he has told me many stories about people changing out their splitters and cables with pretty gold-plated crap that made their problems worse.
  17. May 7, 2013 at 9:24 AM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    ^^ TH!S!
  18. May 7, 2013 at 3:36 PM
    khx73
    khx73 Well-Known Member
    Saint John NB, CAN
    11 MGM DCLB TRD Sport +leather
    Rear camera anytime switch, 4x4 Illuminated Switch (from rcbs204) , rear view mirror lift bracket (from ImMrYo), 75 cent tailgate anti-theft. Technically not mods but give me a break I'm trying to fill space here... OEM Leather pkg, keyless unlock & ACC chime silence, BakFlip G2, Ultra Gauge EM, WeatherTech floor mats, OEM roof rack
    The same people who buy Monster cables and $30 gold plated patch cables cause the sales guy said they'll make a big diff.
  19. May 7, 2013 at 5:10 PM
    Yota1
    Yota1 Well-Known Member
    Your problem is outside. Tell the tech your Internet doesn't work when it rains, he will be looking for water damage.
  20. May 16, 2013 at 11:05 AM
    Evil Monkey
    Robert
    Escondido, CA
    Exactly. He'll tell them it's their splitter and they swear up and down it's better until he puts the Cox splitter on and it fixes the problem.
