WildLand Studio Custom Signature and Photoshop Thread!
Discussion in 'Photography' started by WildLand, Nov 24, 2014.
  1. Sep 19, 2017 at 12:53 PM
    #1561
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Low angle pics look the best IMO. On my Instagram I've got most of mine that angle :anonymous:
  2. Sep 22, 2017 at 7:49 AM
    #1562
    WildLand
    WildLand [OP] Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Yeah like others have said get low! A rule I use is try to get 3 - 4 wheels in your picture. Like your first round, you can see 3 -4 wheels and makes for a good stance. The second batch a little high which leads to seeing only 2 wheels. Kind of like your signature now, can see two wheels so it is not as aggressive stance like Zac and Josh. I can make one of the first batch ones work if you want a signature within the next couple days, or you can try to take another one this weekend, your call!
    ^^ this. Can see 3 wheels too so makes for a great signature stance
  3. Sep 22, 2017 at 7:50 AM
    #1563
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I tried to take a few more pics like that, but even with a cloudy sky I kept getting the "glare" on the truck. :frusty:
    Guess I suck at taking pics... I have no problem in admitting that.
    WildLand[OP] likes this.
  4. Sep 22, 2017 at 7:52 AM
    #1564
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    LOL I just got some new meats and I have another change or two coming. I'll hit you up after that!
  5. Sep 22, 2017 at 7:52 AM
    #1565
    Cativelense
    Nuno
    CT
    Up to you Josh. I definitely like the pics in the first batch a lot better/more. Whatever you think is best, since you're the expert. I'm in no rush, so whatever you want to do. Might be hard to get better pics with less "glare" in the next few days since it looks like we'll be in the 80s and sunny everyday.
  6. Sep 22, 2017 at 8:00 AM
    #1566
    WildLand
    Josh
    NM
    16T4RSR54WD
    :woot: You know where to find me!
    I will cut out one of the first pictures and see how much I can edit it to make it look clean. If it is too washed out I will ask for another.
    Also another couple things is to take a picture with 'soft light' as in a few minutes before sunrise or few minutes after sunset.
    If taking during day, try to take the picture of the truck with the sun behind you, not behind the truck. This will not allow the truck to be washed out by a bright sun in the background
    Also with that, taking a picture of the truck with bright blue sky behind it can affect the washed outness. Like on your phone if you are taking a picture and press on a dark subject to focus on that, it will expose more light to it making the brighter background wash into the subject
    Cativelense[QUOTED] likes this.
  7. Sep 22, 2017 at 8:01 AM
    #1567
    Cativelense
    Nuno
    CT
    Gotcha. Always learning about everything here on TW. :thumbsup:
    Just let me know, and if need be, I'll try taking some more using your advise/tips. :hattip:
  8. Sep 22, 2017 at 8:02 AM
    #1568
    WildLand
    Josh
    NM
    16T4RSR54WD
    Will do!
    Also it is just not easy to take a picture of a black truck in mid day haha
  9. Sep 22, 2017 at 8:09 AM
    #1569
    Cativelense
    Nuno
    CT
    LOL
    Good point. If it's too bright, it'll shine. If it's too dark, then you can't see it.
    It's a lose/lose battle.
  10. Sep 22, 2017 at 10:27 AM
    #1570
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Cloudy days are actually great days to take photos of you car, as the clouds act as a natural light filter. Most of the glare was on the hood, a lower angle will help that. Also try to position your truck so that the sun is behind you, this will prevent your entire image from being washed out by too much light shining into your lense. A good time to take photos of your truck will be 1 hour before sunset, or 1 hour after sunrise.
    So to recap.... For the best pic
    • Wash your truck first!
    • go 1 hour after sunrise or 1 hour before sunset
    • Make sure the sun is behind you
    • walk around your truck to find the angle you like best (if you can only see 3 wheels it is usually a good angle)
    • bend those knees and get a low angle shot
    • Take multiple shots from different angles and heights.
  11. Sep 22, 2017 at 10:27 AM
    #1571
    Cativelense
    Nuno
    CT
    :thumbsup: :hattip:
  12. Sep 23, 2017 at 1:22 PM
    #1572
    WildLand
    Josh
    NM
    16T4RSR54WD
    I tired, and it just does not look good. The first set has good angles, too much exposure. Second set, not great angles but better exposure that I could work with haha
    When you get a chance take few more. If using a phone, if you have to tap your truck to focus the camera on it, it will probably lead to too much exposure
  13. Sep 23, 2017 at 2:44 PM
    #1573
    Cativelense
    Nuno
    CT
    Gotcha. I'll try to take some better ones then. Thanks a lot for all the tips!
  14. Oct 1, 2017 at 9:09 PM
    #1574
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    You could always just touch them up too. I like to use the snapseed app on my phone
    Before
    After
    Also a good polarized filter really helps cut the glare and make the pictures pop.
  15. Oct 2, 2017 at 2:43 AM
    #1575
    Cativelense
    Nuno
    CT
    That looks pretty good right there.
    I haven't been able to try and take better pics yet. Always something going on... the life with two little ones.
    MotoEd[QUOTED] likes this.
  16. Oct 22, 2017 at 10:29 AM
    #1576
    WildLand
    Josh
    NM
    16T4RSR54WD
    Few recent ones:
  17. Dec 3, 2017 at 10:40 AM
    #1577
    WildLand
    Josh
    NM
    16T4RSR54WD
    Anyone need a sunday signature??
    ChadsPride likes this.
  18. Dec 5, 2017 at 3:06 AM
    #1578
    Cativelense
    Nuno
    CT
    Happy birfday Josh!
    WildLand[OP] and ChadsPride like this.
  19. Dec 5, 2017 at 5:15 AM
    #1579
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks man!!
  20. Dec 5, 2017 at 6:33 PM
    #1580
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
