Wildpeaks or Grabber ATX
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaEli, Jan 7, 2020.
Which Tire?
  1. Falken Wildpeak AT3w
    14 vote(s)
    60.9%
  2. General Grabber ATX
    9 vote(s)
    39.1%
  1. Jan 7, 2020 at 6:35 PM
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    Looking for the best tire for my DD. I want something that has a good tread life and will do good offroad and in the snow.
  2. Jan 7, 2020 at 6:35 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Cooper AT3
    TOMB likes this.
  3. Jan 7, 2020 at 6:46 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I would recommend adding Hankook Dynapro ATMs to the list also. When I swapped them out for Wildpeaks I had 50k miles on them and they still had a lot of life left in them. And they were fantastic in the rain, snow, and off road.
    I have Wildpeaks on my truck now and I've been very happy with them so far as well.
  4. Jan 7, 2020 at 6:48 PM
    tahoeskitaco
    tahoeskitaco Well-Known Member
    KLH
    North Tahoe
    2002 SR5 Xtra Cab + 2019 TRD OR Dbl Cab
    Stock. Custom hettich bed slide
    At2 have worked well on my first gen
  5. Jan 8, 2020 at 4:56 AM
    grrck
    grrck Reluctant Wizard
    Garrick
    Woodbridge, VA
    2015 Super White SR 2.7 5SPD 4WD
    I love my Wildpeaks, but can't really compare them to anything but the all-seasons my truck originally came with.
  6. Jan 8, 2020 at 7:18 AM
    Dizzel
    Dizzel Member
    Eric
    Eastern Ontario
    06 DCLB Silver
    Similar money,
    I just had the same decision to make. My tire guy said the general wears longer but the falken has better grip throughout its life.
    I went with the falken as I’m not running separate tires and rims for winter.
    The falken balance very well. I’m very happy with them. Not e rated tire for me
    grrck likes this.
  7. Jan 8, 2020 at 7:31 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There are a lot of good tires and most of them do what you want to do. Make your decision based on price and what you think looks best.
    Right now the Falkens are the darlings of the internet. I replaced the tires on my F150 in November and seriously considered them. I've used Cooper in the past with very good results. ther t Ohan being expensive you rarely hear any complaints with BGF KO2's. They seem to be the tire everything else is judged against. Michelin is the go-to tire for those wanting a good ride and long life if they don't need an aggressive off road tire. Pricy, but they last so long that they probably come out cheaper in the long run.
    Cooper has changed their marketing approach and prices are up. I ruled them out in November because of price. They used to only sell to small independent shops and ran $50-$75 rebates 3-4 times each year. The low prices combined with a rebate got the prices so low it was hard to justify anything else. They will no longer sell to independent shops, only the bigger chains who charge more and I haven't seen a rebate offered in a while.
    If considering Falken ask you're dealer about these.
    https://www.tirerack.com/tires/tires.jsp?tireMake=Sumitomo&tireModel=Encounter+AT
    They are the same tire as the Falken, made in the same factory with a different name stamped on them. My dealer could have gotten them about $150 cheaper than Falkens for me. This is the tire I had decided to buy for my Ford, but the guy I've been buying tires from for 30+ years closed his shop and decided to retire before I got around to buying them.
    I ended up buying these instead from our Sams Club
    https://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=Scorpion+All+Terrain+Plus
    They ended up being cheaper than Cooper or Falken and only a bit more than Sumitomo. Over $300 less than BFG. They are a lot more aggressive than the photo shows. I've put about 2000 miles on mine so far and am happy.
  8. Jan 8, 2020 at 8:21 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    no experience with the Grabbers but FWIW i went from Duratracs to Wildpeaks a couple weeks ago and after a long trip i can say i am blown away by how much quieter and smoother the Wildpeaks are. i figured there would be an improvement and in all fairness the Duratracs were worn but the difference is almost unbelievable.
    if the Cooper AT3s were available in the size i wanted i would have gone with them but so far so good on the Wildpeaks which were great on a 2.5 week trip that saw rain, snow, sand, coarse gravel and loose rock.
    Crow Horse likes this.
  9. Jan 8, 2020 at 8:54 AM
    chetterthecat
    chetterthecat Well-Known Member
    OR
    13 sport
    Wildpeaks. First set did 70k in 2 years. Lots of gravel roads, PNW rain and snow.
  10. Jan 8, 2020 at 8:58 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    I had two sets of Grabber AT2 when i had my 2013 taco. I liked them, never really had any issue.
    With my new 2020 Taco, I went with the Wildpeaks and I can say that the Wildpeaks ride smoother/quieter
  11. Jan 8, 2020 at 9:01 AM
    TacomaEli
    Eli
    Roanoke, Virginia
    From what I can see both tires get good ratings and they're pretty equal in performance. It just comes down to which you prefer.
  12. Jan 8, 2020 at 10:40 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Falken Wildpeaks FTW!!
  13. Jan 8, 2020 at 10:41 AM
    TACO 12B
    TACO 12B Team Hoyt
    Brody
    Flagstaff, AZ
    2017 DCLB TRD Offroad 4x4
    Toyo A/T II FTMFW
  14. Jan 8, 2020 at 10:43 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Wildpeaks! I am biased though!
