wildpeaks SL vs. E rating question.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigBeej, Oct 15, 2018.
  1. Oct 15, 2018 at 3:27 PM
    phsycle
    phsycle Well-Known Member
    CA
    Do you really notice any difference? I've gone from stock to LR C to E (C and E were same size tires). Aside from the ~10% hit going from the stock P-rated 31" tires to LT 32", going from LR C to LR E, I saw no noticeable difference in MPG. Given the same model tire and size, I would think at most, you'd be at 1MPG difference, and that's being very generous.
  2. Oct 15, 2018 at 3:37 PM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    I've never owned E tires but I figured 11 lbs x 4 tires= 44lbs savings of rotational mass has to make some sort of difference. At least on acceleration. I've read comments on people going from stock to 33" tires and them complaining on how heavy those bad boys are and how noticeable it is and they're only 6 pounds more an the LTs.
    SL 265/75/r16 = 44lbs
    LT 265/75/r16 = 55lbs
    LT 285/75/r15 = 61lbs
  3. Oct 15, 2018 at 3:41 PM
    phsycle
    CA
    I did feel a little bit of lag in acceleration when I moved to a LR E (from LR C). But you have to consider you're going from not only a lighter tire, but also a used tire with most of the tread worn off. Which affects the gearing as well. Perhaps the affects of all of those small variables add up to the sluggish feel.
    However, even given that, in real world experience, I noticed pretty much zero difference in MPG.
  4. Oct 15, 2018 at 6:46 PM
    BigBeej
    BigBeej [OP] Well-Known Member
    Bryan
    Vista, Ca
    Im not as worried about the mpg's as I am the quality of the ride. I don't want a extra stiff ride for daily driving.
  5. Oct 15, 2018 at 8:23 PM
    roy326
    roy326 Well-Known Member
    Roy
    Southern California
    2020 Tundra/V8 4Rnner/GX460. I do miss my tacoma
    What’s the recommended psi for SL?
  6. Oct 16, 2018 at 4:47 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    What's on your door tag. A tire's max psi is just that, the maximum. If you inflate to that, you're running around on 4 rocks and the ride will suffer. You'll also tend to wear the center of the tread considerably faster than the shoulders.
    Mountain Minstrel likes this.
  7. Oct 16, 2018 at 4:54 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Depends on the size...whatever it takes to reach a 2,149 lb load rating.
  8. Oct 16, 2018 at 4:57 AM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Thats only true for the OEM tires. Doesn't mean anything for aftermarket tires. Each person should do their own chalk tests and use their own best judgement for each aftermarket tires.
  9. Oct 16, 2018 at 5:18 AM
    Noelie84
    Noel
    Wales, Maine
    That's not necessarily true. Max load capacity is usually attained at max inflation psi.
    Ehh....yes and no.
    Rubber manufacturers all build their carcasses to pretty much the same specs in a given size. There's some variations from one to another but they're very minor differences. So a 265/70R17 BFG will behave pretty much the same as a 265/70R17 Goodyear or Kumho, etc, at least in terms of the shape of the tire at a given psi.
    On the other hand, vehicle manufacturers generally recommend the best average for the vehicle, not necessarily for the tire, so there is likely to be some variation from tire to tire and the chalk test is worthwhile, especially if you're jumping load ranges. But the manufacturer's recommended pressures are a good baseline to start from, and if you aren't chalking your tires it's a better guide than just going by a tire's max inflation pressure.
    All depends on the sort of load you're carrying, as well. If you're running with 600lbs of gear/equipment in the bed all the time then 40psi might be better, etc.
  10. Oct 16, 2018 at 5:33 AM
    shacol
    shacol Well-Known Member
    Florida
    2018 Offroad DCSB
    I have noticed that the Falkens have a 265/65/17 that is rated XL. I know that is for a bit of extra load over the SL rated tires, but I am wondering if I'd notice any difference in noise or comfort.
    They have a 265/70/17 that is rated SL. It is a bit heavier though, by about 5 lbs per tire. Any thoughts?
    Thanks!
  11. Oct 16, 2018 at 7:51 AM
    brownspaceman
    brownspaceman Member
    E-rated peace of mind on the trail is what I care about.
    Also consider the brand/design though because the rating on the tire is exactly that, it doesnt actually mean they are 10-ply tires, it's an equivalent value.
    I'm a Toyo man now, I was convinced over many different situations I put myself into with my old truck, where lesser tires had previously died.
    Ballz and Topanga Taco like this.
  12. Oct 16, 2018 at 8:57 AM
    splitbolt
    NW Arkansas
    Who said anything about max load capacity or max psi?
  13. Oct 16, 2018 at 9:02 AM
    Noelie84
    Noel
    Wales, Maine
    Nobody; I transposed the 1 and the 4 in my brain and thought you were talking about inflating for max capacity. :annoyed:
  14. Apr 2, 2022 at 2:29 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    OP what did you end up getting and how did it turn out?
  15. Mar 17, 2023 at 2:40 PM
    #35
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I have 2 sets of tires, one SL all-terrain and one E mud-terrain. I can subjectively feel the difference in rolling resistance (need to use more skinny pedal) and I get about 6-12% less fuel economy with the mud-terrains. There is also a noticeable difference in ride quality and noise. I’ve never damaged either set of tires.
    I suspect LT tires are a bad option for most taco owners.
  16. Mar 17, 2023 at 3:24 PM
    #36
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Amen. I got them for the same reason. Peace of mind. Like the other day when a sexy gal stood up at the bus stop…yeah I looked until the concrete curb told me to stop looking. And I mean it told me harshly, lol :anonymous:
    Only downside is if you decide to go with the flow of traffic at 80+mph, the Taco chugs the fuel. 75mph and below, and the difference in mpg compared to the stock firestones is damn close. No sluggish feeling around town too(although no camper, etc.)
    EDIT: And the ride is not stiff as people think. At least for me. As a matter of fact, the tapping noise that was coming from underneath the dash is gone over bumps. Strange, but I ain’t complaining!!!
    johnnytwotimes likes this.
  17. Mar 17, 2023 at 4:57 PM
    #37
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    I have always ran E just for peace of mind. Wether I’m at Pismo Dunes and needing to air down, or off-roading somewhere, or meeting the snow and having to take a snowy path because the main road is down, never know what’s underneath that snow pack or powder. It’s a truck. Silly to worry about mpg. Even while running 18lb forged TE37’s and 285/70-17’s that weigh 55 to 61 lbs each I’m still under 80 lbs per wheel.
  18. Mar 17, 2023 at 5:10 PM
    #38
    Bishop84
    Bishop84 Well-Known Member
    I like the added tire life of the E, but everything is compromise.
    Honestly my next set will be LT 245 75 R16, get SOME economy back while retaining the heavier ply.
    Ballz likes this.
